Old 06-15-2015, 05:52 PM   #1
Noob
JazzDad's Avatar
2009 22' Sport
Columbus , Texas
How thick is the floor?
I need to mount something to the floor. (I can't say what it is, because I'm sworn to secrecy by a major government.) I need to know how thick the floor is, so I don't run a screw into the fresh water tank below. We're talking about a 2009 Sport, 22 foot. There is stock vinyl floor covering.
Thank you, and your (possibly) government thanks you for your service.
All kids are gifted; some just open their packages earlier than others. - Michael Carr
JazzDad is offline   Reply With Quote
Old 06-15-2015, 05:55 PM   #2
2013 20' Flying Cloud
Between Here and There and Nowhere , what have you got?
What I saw at the factory was 3/4" plywood.
openroad118 is offline   Reply With Quote
Old 06-17-2015, 11:20 AM   #3
Noob
JazzDad's Avatar
2009 22' Sport
Columbus , Texas
3/4" would be normal, but the one place I have slight access it seems to be 5/8 or even 1/2 inch (which would explain the squeaks in the floor).
Old 06-17-2015, 11:22 AM   #4
txdxrider's Avatar
1976 31' Excella 500
Providence Village , Texas
In mine is a 1/2 in subfloor with 1/4 in on top then the flooring.
Let's party with Pirates and Ninja's.....
txdxrider is offline   Reply With Quote
Old 06-18-2015, 11:47 AM   #5
gr.austin's Avatar
2009 27' FB Classic
Sioux Falls , South Dakota
The factory has only 1 flooring material and it is 5/8. I have had to replace some of the flooring in my 2009 classic at it was 5/8.
gr.austin is offline   Reply With Quote
Old 06-18-2015, 11:55 AM   #6
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
5/8 has been the thickness of the Airstreams that we've owned. However if you are sworn to secrecy by whatever your "major" government is, I don't think I'd be discussing that sort of thing on Air Forums...
Just sayin'
Larry
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Old 06-18-2015, 12:35 PM   #7
1974 Argosy 20
Kooskia , Idaho
A machine gun mount is just too much for the floor of an Airstream. And the water tank will not last long to cool the thing. Re think your plan, and inform your handlers that other options need to be looked at.
I fear no Airstreams, but... maybe this one.
Old 06-18-2015, 02:07 PM   #8
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
It is true that Airstream used 5/8 plywood - with flooring total thickness under the channel is 3/4
Ken J
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 06-18-2015, 02:20 PM   #9
ericpeltier's Avatar
Superior , Colorado
Space Alien Containment Vessels are best held down with construction adhesive and Gorilla Tape.
ericpeltier is offline   Reply With Quote
Old 06-18-2015, 06:21 PM   #10
Sodbust's Avatar
1972 27' Overlander
Penokee , Kansas
Just what I was thinking.
My head was just flowing in this direction.. Thanks I feel more normal now.
2012 Ram 1500 Tradesman Hemi, 4x4, 6 speed
20mpg empty, 14 mpg with 27' Overlander.
Today is the first day of the rest of your life!
Sodbust is offline   Reply With Quote
Old 06-18-2015, 07:46 PM   #11
1967 26' Overlander
Spartanburg , South Carolina
Speaking of AS floors, would someone explain to me why AS did not use marine plywood which was available back in the 50's?
Jacob D is offline   Reply With Quote
Old 06-18-2015, 08:38 PM   #12
1994 30' Excella
Mississauga , Ontario
Because it is not supposed to get wet! )
Al and Jean
TAC ON-3
Old 06-18-2015, 10:02 PM   #13
1974 Argosy 20
Kooskia , Idaho
Marine plywood is simply a better grade of plywood with no voids in the internal core layers. It also (in the old days) used a water resistant glue, when regular plywood used glue which was water soluble and came apart when wet. But glues in plywoods are now are all water resistant and that has not been an issue for many years.
But marine plywood is still wood, and still rots. Now, and in the old days. So, there is not a real advantage to using it for a sub flooring by Airstream.
Pressure treated plywood would not rot, but it is hazardous to health and also can cause corrosion from what I understand. In any event it is not to be used for flooring.
Old 06-18-2015, 10:51 PM   #14
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
My sub floor is 5/8" thick.
Hi, when I did my living room remodel, My gaucho had like 3 or 4 inch long screws holding it down. When I relocated our gaucho, I noticed that the new screw holes were above my gray tank. I drilled the holes, stuck a small screw driver in the holes, and measured the depth from the top of my floor to the top of my tank. Now buy new screws at least a 1/2" shorter. [my experience] Hope this helps you.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
How thick are the brake shoes supposed to be? deauxrite Brakes & Brake Controllers 9 12-21-2009 12:46 AM
Cozy Tyme 3" Thick Memory Foam campcollector Our Community 0 05-17-2005 07:28 PM
Thick or thin walls? malconium Interior Restoration Forum 9 05-28-2004 02:43 PM
Plywood - How thick is the original? Marlboro Mafia Repairing/Replacing Floor &/or Frame 11 04-08-2004 10:09 AM
brake lining how thick remcolent Brakes & Brake Controllers 0 03-20-2004 02:32 PM
