Old 03-09-2016, 07:23 AM   #1
Opelika , Alabama
How subfloor and shell fit together....
The aluminum piece that sits directly on top of the outriggers has an opening where the subfloor slides right in and then carriage bolt goes through the outrigger, through the aluminum, through the subfloor, and through the piece of aluminum again. The problem in this puzzle is that I can't pull the shell off and install the subfloor. I have to install the subfloor with the shell on so I can fit it into this groove. I do realize some of the outriggers in the photos need to be replaced.
So am I looking at this correctly?
ID:	258463   Click image for larger version
ID:	258465   Click image for larger version
racecannon is offline   Reply With Quote
Old 03-09-2016, 04:06 PM   #2
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
You can still pop the shell if you want. It actually may help you repair the frame. I believe you slide them in from the front and back where the channel just sit on the floor
Matt
rugjenkins is offline   Reply With Quote
Old 03-10-2016, 08:31 PM   #3
AlbertaBound's Avatar
1975 Argosy 28
1975 Argosy 22
1978 Argosy Minuet 6.0 Metre
Camrose , Alberta
If you are doing a shell off, you must remove the channel from the shell by drilling out the hundred or so buck rivets on the outside.
AlbertaBound is offline   Reply With Quote
Can't take shell off... want to work on the frame and replace subfloor paulitee Repairing/Replacing Floor &/or Frame 15 04-09-2013 12:27 PM
Removing subfloor with shell on Stupidnoob Repairing/Replacing Floor &/or Frame 33 10-24-2012 09:36 PM
1975 Sovereign, shell-on subfloor repair... FunTimesWoo Repairing/Replacing Floor &/or Frame 8 08-16-2012 02:25 PM
Replace Subfloor without removing shell? Phrunes Repairing/Replacing Floor &/or Frame 8 05-07-2012 11:11 AM
alternative shell to subfloor to frame interface? benWa Repairing/Replacing Floor &/or Frame 2 01-07-2009 07:56 PM
