Old 10-31-2011, 10:13 AM   #1
Unity , Maine
How much rust is too much?
Hi there,
My wife and I have been looking at Airstreams for a while now. We would like to get one from the 70s , prep it up a bit and live full-time in it.
We are not really Airstream experts yet, but we try to be as diligent as possible checking out the Airstreams using the checklist from this site.
We hardly come across Airstreams without any rust on the frame/hitch area. Browsing through the posts of replacing floors/lifting shells to get the frame back in order, we get a little scared buying a "lemon"...
So to make a long story short:
How much rust is too much rust? Can you kinda guess the frame condition by the parts which are visible or is it kinda a 50/50 chance if u dig deeper?
I attached some pics of one Airstream we consider buying. Any advice or help is welcome.
Thank you
Georgie
ID:	144176   Click image for larger version
Sendaman is offline   Reply With Quote
Old 10-31-2011, 10:20 AM   #2
1969 27' Overlander
Albuquerque , New Mexico
Looks like mostly surface rust, and ANYTHING can be replaced, welded, riveted, or polished, as you will soon learn in the Airstream World.
Too much rust is when you can see the Oxygen on the other side of the metal. That's too much rust.
Jump in! You'll love it!!
You can't go wrong with an American Icon.
edglenn is offline   Reply With Quote
Old 10-31-2011, 10:42 AM   #3
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
The black tank area with those long-term salts & acids should be looked at closely, plus the electric ground pad & fresh city water inlet area is another place to look, the stray grounds etc. can chew up the iron pretty fast. Another place to gauge more of the frame is the step area.
For a little more confidence - sight down the shells sidewall, the wheel well area should not have pucker out more than 1/2" or so - and sighting along the trim seams should not show more than 1/2 to 3/4" droop front to rear.
Also - often the belly sheets will corrode around the rivets even to the point of just dropping off the rivets - kind of shows the long term exposure to the elements, acid rain, snow melt chemicals etc. there.
Use every cheat you can think of to view iron, peek in through the trunk locker, go to the inspection with aluminum rivets, rivet gun and a cordless drill and explore a little if the owners are agreeable...
Old 10-31-2011, 12:28 PM   #4
Rust is rust.
Any amount of it can be bad, depending on where it's at.
If the metal is used for strength, then the strength is weakened by the rust.
Old 10-31-2011, 02:01 PM   #5
Splitrock's Avatar
Sioux Falls , South Dakota
Originally Posted by Sendaman View Post
Hi there,
Are you going to make a trailer into a park model and set it up on a site? Or travel the highways and byways?
Old 10-31-2011, 02:29 PM   #6
Unity , Maine
We definitely plan on traveling in it too, so it's not gona be set up permanently in a park.
Old 10-31-2011, 02:48 PM   #7
Splitrock's Avatar
Then axles will be a big deal . . . bad frame will be a HUGE deal.
Old 10-31-2011, 05:38 PM   #8
1981 31' Excella II
New Market , Alabama
It does not look like anything a can of POR 15 won't cure. It is the part above the skins where there might be some surprises. I would be more concerned about leaks around the rear of the trailer. This area is prime for floor rotting leaks that lead to frame separation and sagging rears. Old age can also cause saggin rears but not in your trailer.
Perry
frame repair
Rust spots already on rock guards - 2011 Airstream wendywoods Cleaning, Stripping & Polishing 38 03-09-2012 09:34 AM
Rust on the interior door panel Mike Steele Doors & Locks 0 09-14-2011 01:16 PM
Rust under clearance lights saburkha All Argosy Trailers 4 09-13-2011 10:16 AM
Stopping Chassis Rust on 2009 AS tmarquis Repairing/Replacing Floor &/or Frame 2 04-02-2011 09:53 PM
Internal frame rust mikeandnora Repairing/Replacing Floor &/or Frame 0 03-02-2011 10:47 AM
