Old 12-20-2007, 06:32 AM   #1
toastie's Avatar
Profile:  1965 17' Caravel
1955 22' Safari
, , Michigan
How much POR-15 Rust Preventive Paint
How much POR-15 Rust Preventive Paint does it take to do 1955 Safari 22', 2 coats...........thanks
toastie is offline   Reply With Quote
Old 12-20-2007, 06:40 AM   #2
1 Rivet Short
Profile:  1989 25' Excella
By The Bay , Rhode Island
Well....the exact answer is...it depends....
how much are you coating?
Exposed frame?
Entire frame?
Top to bottom/inside and out?
More details please...
Life is Good-Camping all around New England
BillTex is offline   Reply With Quote
Old 12-20-2007, 06:47 AM   #3
toastie's Avatar
1955 22' Safari
, , Michigan
Exposed frame?
Entire frame?
2 coasts
entire frame that will not be exposed
Old 12-20-2007, 07:03 AM   #4
byamcaravanner's Avatar
Profile:  1967 28' Ambassador
1963 19' Globetrotter
Waukesha , Wisconsin
I'm hoping to do the frame on my 28 footer with 5 quarts... keep your fingers crossed.
Steve & the crew
'67 Ambassador International Twin
'63 19' Globetrotter
http://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 12-20-2007, 07:12 AM   #5
toastie's Avatar
1955 22' Safari
, , Michigan
So, 1 gallon should do my 55 safari.........
Old 12-20-2007, 08:13 AM   #6
Aerowood's Avatar
Profile:  1971 21' Globetrotter
Arvada , Colorado
It took me 2.5 qts to spray on 2 coats on a 21 ft. entire frame
Old 12-20-2007, 08:32 AM   #7
bedfords's Avatar
Profile:  1972 27' Overlander
1975 29' Ambassador
Littleton , Colorado
I used 2 quarts on my 27' two coats with floor on. I brushed on. Pretty sure the dogs and I had at lest a quart on us. Great stuff will not come off your skin. I suggest long plastic gloves the ones they use to pull a calf and a face shield. Scratch that. A full body suit. The stuff soaks right thru cotton onto your skin.
Master of the Tin-Can
and thats not saying much
bedfords is offline   Reply With Quote
Old 12-20-2007, 09:54 AM   #8
Thumbs up
Great News!
It looks like my gallon and a quart should be plenty for my Ambassador.
Steve & the crew
Old 12-20-2007, 01:41 PM   #9
Zeppelinium's Avatar
Profile:  1970 18' Caravel
1977 23' Safari
1975 31' Sovereign
Palmer Lake , Colorado
Don't buy it in gallons--quarts are less expensive in the long run, since you can ruin an open can very easily with a not so perfect seal.
I have two experiences:
1. Took two weeks to get the skin off (paint does not come off. period.) Yes, gloves and cheap T-shirts at a minimum.
2. Since you're buying in quarts, get half gray/green/brown or any other color than black and the other half black. If you're brushing on, you can't tell the wet from the dry if you do two coats of black. POR-15 has excellent leveling qualities (very smooth, even when brushed) and shiny.
I also agree that 5 quarts is too much. Not more than 4 and more likely 3. Guess it depends on your brushing style.
Zep
Current 6-word memoir: Vintage Airstreams: Four are not enough.
www.mindseyephoto.com www.airstreamdoctor.com
Pingbacks are On
70's AS asphalt-based frame paint prep for POR-15 Wabbiteer Repairing/Replacing Floor &/or Frame 1 10-09-2006 08:23 AM
Black tank preventive maintenance balrgn Waste Systems, Tanks & Totes 0 10-05-2005 04:26 AM
Rust Bullet vs. POR-15? jperryfly Clearcoat, Exterior Paint & Trim 2 05-25-2004 05:45 PM
POR paint inquiry gsymes Clearcoat, Exterior Paint & Trim 8 02-27-2004 06:01 PM
Minor Rust/Paint Missing on Galvanized Parts heyskipper Clearcoat, Exterior Paint & Trim 8 03-04-2003 08:35 AM
SEO by vBSEO 3.1.0
