Hey got the Por15 yesterday and sprayed today. I don't know why I would even think about brushing it on. It would take forever. I put two coats on and only thinned the first 1/2 quart. I didn't thin it after that. It didn't need it.
2 quarts was enough to do my 28' frame with 2 coats. And this stuff sprays nice. I've sprayed a lot of stuff lacquer to car paint and this stuff is hard to make run.... I tried.
anyway pics with be with my restoration thread. This stuff is the best. frame looks great.
I sprayed with a low pressure spray gun from harbor freight. The top feed purple one 10 psi. I didn't use my nice one just incase it messed it up. It did fine with proper cleaning after.
Jason
2008 5.7 L V8 Sequoia AIR # 31243 WBCCI # 6987
FOUR CORNERS UNIT
It's been about two weeks and I still have paint on my ankles and feet. Some left on the finger nails... Don't get it on you if you are going anywhere.... IT REALLY DOESN"T COME OFF..
Jason
FOUR CORNERS UNIT
