Old 12-31-2011, 08:09 PM   #1
Film and Fabrication
Eric H's Avatar
1974 23' Safari
1947 25' Spartan , Manor
How much Por 15??
Anyone have a good idea of how much Marine Clean, Prep and Por15 would be good to have for a 24 foot trailer frame?
Thanks!
Eric
Eric H is offline   Reply With Quote
Old 12-31-2011, 09:02 PM   #2
1975 27' Overlander
Lethbridge , Alberta
Based on my limited use (I bought a couple of pint cans earlier this year), I'd say 2 quarts of POR 15 would be plenty. You'd need about a quart of the Metal Ready prep product.
AlbertF is offline   Reply With Quote
Old 12-31-2011, 09:22 PM   #3
Tool Hoarder
marzboy's Avatar
1965 30' Sovereign
West Hills , California
I used about 2 quarts for a 30' frame I would buy it in pints because that stuff is really sensitive to moisture. I bought the Marine Clean in the gallon size because you can use it for a lot of things. I would only use Metal Prep on bare metal or if you are welding. Por 15 works best on rust so get all of the paint off and surface rust.
Behind every great man, there is a woman rolling her eyes.
My Airstream renovation and camping Blog
My frame and floor restoration thread
marzboy is offline   Reply With Quote
Old 01-01-2012, 04:21 AM   #4
touched
62overlander's Avatar
1948 22' Liner
Catonsville , Maryland
Eric, I have always painted it on with a brush so my answer would be buy one quart black and two grey pints. You will use the quart and the pint but not touch the second pint. If you do not buy that extra pint, you will run short. The reason for two colors is because one coat is just not enough and the second color allows you to know you covered everything.
however....
Last time around I sprayed it on. I seriously doubt I will ever brush it on again. I used my siphon feed cup gun. The POR15 is just a little too thick to flow through my gun smoothly so I cut it with a little xylene. The results were actually beyond my expectations. The POR15 dried so quickly that I was doing the second coat within minutes. The surface looked as if it had been wrapped in a film. The finished surface of the brushed on has always looked nice and smooth, but this is one step beyond. If you spray it on, I would say one quart will be plenty.
I wish I had some photos of the just POR15 stage. All the exposed parts were next top coated with a two stage automotive paint to match the client's tow vehicle. The entire reason for spraying was to give a better surface for the auto paint. Had a normal frame paint been used, I probably would still be brushing it on.
Please take this to heart, any, and I mean ANY, exposed skin will be hit by the POR15. Once it is on you, it will be there until the skin under it falls off(literally). If you spray it, make sure everything is masked off. The overspray will float in the air and it will fuse to anything it falls on, FOREVER! Keep your air pressure low and mask everything off.
Frank Yensan The Airstreamer's Club USA-1 "we're dead serious about having fun"
http://annalumanum.blogspot.com/http://frankstrailerworksblog.blogspot.com/
www.frankstrailerworks.com
62overlander is offline   Reply With Quote
Old 01-01-2012, 12:59 PM   #5
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
I have a silver driveway. One quart thinned 8% covered all of the frame generously except two center spars. The next quart was thinned by the addition of 5% thinner and the second coat went on much thinner and easier and really brought out all the highlights an asphalt driveway is capable of.
I had four 8-ounce cans nabbed from a closing hardware store but filled the HVLP paint cup for the second coat then decanted the rest into the 1/2 pint cans, for about 6-oz per can. I still have three of them. Plus, did I mention, a bright aluminum colored driveway less the frame lift blocks outlines.
Old 01-01-2012, 01:20 PM   #6
Maniacal Engineer
barts's Avatar
Menlo Park , California
One way to get better shelf life after opening the can is to fill it with propane (I used my torch (NOT lit )) and to place a piece of Saran wrap under the lid. The propane displaces the air in the can and along with it, any moisture. The Saran wrap provides a good seal... I've had cans of similar stuff (a silver moisture cured polyurethane called Aluthane) last for more than a year sealed in this manner.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 01-01-2012, 01:35 PM   #7
1981 31' Excella II
Orlando , Florida
How do you get the stuff out of your spray gun when you are finished? If the stuff starts to setup in the gun you are going to need a new one.
Perry
Old 01-01-2012, 02:19 PM   #8
Wabbiteer's Avatar
1972 29' Ambassador
I did not clean the gun between coats (intentional. POR needs to be dry before it fires) and the exterior parts were merely trying to set up, but relative humidity that day was only 20% that day and it was still gummy and cleanable eight hours later. When it came time after dark to clean the HVLP gun I used POR-15 thinner and carb cleaner - Berryman Chemtool B-12 aerosol chocked full of toluene and a couple of other solvents.
Clean the cup and pickup, add solvent and spray the solvent out until it ran clear, that cleaned all the air ports and the exterior parts took a couple of soaks with the B-12. I thought I'd run the HF $20~ gun but it all cleaned up like new, except the pressure gauge glass face surface that semi-melted from the aerosol solvents... The gun comes with a bristle brush, that and a terry cloth rag were just right to get all the hidden spots...
Old 01-01-2012, 02:30 PM   #9
RGates
Randy Gates's Avatar
1968 20' Globetrotter
Thousand Oaks , California
I used 2 pints of POR-15, a jug of marine clean and one bottle of the metal ready. I used the grey POR and silver paint. Although I only used the paint on exterior not the undercarriage on my 20' Globetrotter. I am so happy I chose to paint it on. It is an ugly job on your back but you assure yourself to not miss a spot that way. Long sleeve shirts-double them up, it can bleed through a single shirt. You WILL get it on yourself. Get ready to scrub it off. Cover the ground with the blue tarps-best to save your driveway or shop. Good Luck.
Randy
Randy Gates is offline   Reply With Quote
Old 01-01-2012, 04:04 PM   #10
Eric H's Avatar
1974 23' Safari
Thanks all! This is very helpful!
Old 01-16-2012, 03:03 PM   #11
1972 31' Sovereign
1973 31' Sovereign
MMMM
this sounds tempting....So after applying the POR 15 you guys just painted over with automotive paint? So the POR 15 is perfectly paintable?
Still One Nation Under GOD
VeggieBullet is offline   Reply With Quote
Old 01-16-2012, 03:23 PM   #12
touched
1948 22' Liner
I dropped a hammer on the tongue by accident, it didn't chip. I think the key is timing. If the POR 15 cures too much it will make the bond difficult...
Old 01-16-2012, 03:24 PM   #13
Alumaholic's Avatar
Albuquerque , New Mexico
POR is Not Paintable
POR is not paint.
POR is degraded by exposure to sunlight.
Surfaces that will be exposed to direct sunlight must be topcoated with a POR topcoat.
Automotive paint will cover and dry beautifully, put it will begin to peel and flake in 2-4 years.
Don't ask me why I know this.
P.S. I have used gallons of the stuff.
Ken
2007Chevy 2500 HD Duramax/Allison
NM Unit WBCCI #8654, Affiliate Four Corners Unit
"Those Airstream photos on the internet that fuel your fantasies will always capture the gleam of aluminum, but rarely all the blemishes, and never the smell."
Alumaholic is offline   Reply With Quote
Old 01-16-2012, 03:26 PM   #14
touched
1948 22' Liner
Originally Posted by Alumaholic View Post
POR is not paint.
Guess I will be fixing it for free in 2-4 years. Was this two stage you used or a one stage paint?
