Old 08-04-2010, 06:24 AM   #1
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
How is this supposed to fit?
I am almost finished replacing the bathroom sub-floor but am unsure about this. Is the sidewall supposed to fit tight against the sub-floor or a little away from it. I tried to pull the wall in but it does not seem to move. It is tight at the rear of the floor but not the side. Photo's attached.
ID:	108087   Click image for larger version
ID:	108089   Click image for larger version
Mel
2006 GMC 1500 SLE Crew Cab
5.3L V8 Towing Package
Equal-i-zer E2
AIR # 40365
TAC # OK-3
mwells4654 is offline   Reply With Quote
Old 08-04-2010, 07:39 AM   #2
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
The floor floats in the channel, the through bolting locks it down, not interferance fit with outsides of the channel.
I religiously copied the rotten end floor piece into marine plywood and came up with inch wide gaps for my trouble.
Without making a perfect "before" blueprint of the exact dimensions of the aluminum only and observing how the shell has relaxed after the old floor was removed...
And then accounting for the new floor wood-to-channel insertion friction deflecting the shell outlines...
It turns into a generalized crap-shoot to get the shell centered & side length even.
From the outside use the bumper frame attachment point(s) to benchmark where the shell drifts/drifted to from center and hope there is enough wood to clamp where it lines up at... Remember you can add outriggers if needed!
Old 08-04-2010, 09:11 AM   #3
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
I am sorry - I do not unstand what you mean - I think what you mean is center it and bold it down - and do not worry to much about the gap. If this is not correct please explain.
Mel
Equal-i-zer E2
AIR # 40365
TAC # OK-3
Old 08-04-2010, 09:44 AM   #4
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
Hey folks I need one more thing - if someone could post a picture of how the rear bumper cover is supposed to look when closed - Does it line up with the rear of the bumber? Should have taked a pic before I removed it lol.
Mel
Equal-i-zer E2
AIR # 40365
TAC # OK-3
Old 08-04-2010, 11:41 AM   #5
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Check out my Gt thread, It may answer alot of questions for you
http://www.airforums.com/forums/f416...nte-26902.html
Old 08-04-2010, 12:41 PM   #6
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
Aerowood - I appreciate your help but I went thru 107 post on your link and did not see an answer to my question, if there is one, please tell me which post as I quit at 107.
Mel
Equal-i-zer E2
AIR # 40365
TAC # OK-3
Old 08-04-2010, 01:39 PM   #7
VIKING's Avatar
Boulder Creek , California
Is the frame supported and level?
When you look down the side of your Airstream from front to back, does the wall look like it's bulging out at the rear where the floor replacement is happening? If your floor was tight before you removed it, and you copied it exactly, you should end up with it tight again. If not, the shell has changed shape, and needs to be checked out as throughly as possible for sags and bulges. I was as careful as I could be and still have some places where the subfloor is about 1/2" away from the wall skin, but It's straight and has no bulges.
Best to you,
Rich the Viking
VIKING is offline   Reply With Quote
Old 08-04-2010, 01:49 PM   #8
Wabbiteer's Avatar
1972 29' Ambassador
This is off my parts trailer - don't know if its original, I tore out all that long ago on my project trailer.
Old 08-04-2010, 01:57 PM   #9
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
Thanks everyone -
Mel
Equal-i-zer E2
AIR # 40365
TAC # OK-3
Will it fit? blumob General Interior Topics 2 01-27-2012 06:20 PM
Shower Curtain doesn't fit right. darryl97420 All Argosy Trailers 3 11-06-2011 08:30 AM
1968 GT tires that will fit... RECOMMENDED ALUMINUMINUM Tires 5 10-31-2011 11:30 AM
Will a Zip Dee awning fabric fit on Dometic Awning tube? montanablue Awnings 2 10-24-2011 10:27 AM
will my cookie sheets fit? aluminomad 1966 - 1968 Safari 5 01-22-2011 01:25 PM
