Old 10-15-2016, 11:12 AM   #1
SkatiePower's Avatar
beecher , Illinois
How do you attach bracing for shell off?
Hello,
My wife and I are new to the Airstream community. We are getting close to lifting the shell on our 1991 34' limited. The only thing we aren't sure about is how to attach the bracing to the ribs. Do you have to drill holes horizontally through the ribs to put bolts through?
Thanks!
Here is a picture from the day we picked it up last week It's not missing a window, that's just the picture.
SkatiePower is offline   Reply With Quote
Old 10-15-2016, 11:27 AM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
How are you lifting the shell? If hoisting from above, no bracing is required.
Old 10-15-2016, 03:07 PM   #3
beecher , Illinois
Lifting from above seems like the ideal method for shell removal, but adding braces and jacking it up a few inches while we replace the subfloor is the most economical option for us, so we were going to use that method.
Old 10-16-2016, 09:33 AM   #4
Central , Mississippi
Yes, cut 2x6" boards so they span the width and bolt them thru the ribs. Bolt a board across the door opening so it doesn't get wider during the process.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 10-16-2016, 10:36 AM   #5
beecher , Illinois
Great! That's all I needed to know! Thanks!
Old 10-16-2016, 11:08 AM   #6
HowieE's Avatar
Princeton , New Jersey
Images: 12
I would use a piece of plywood at least 12 in wide at the bottom of the door and use many bolts on each side. The 34s are pron to a crack in the skin in the upper right corner of the door even while on the frame. No need to help that along.
If you are going to jack the body rather than lift through the windows I would position the only 2 braces 1/4 from each end using only 3 jacks, 2 at one end and 1 at the other. You may have to move the brace to get under the original jacking points if the floor need replacing there but moving the brace one rib may be OK.
2004 Excursion 4x4
Old 10-16-2016, 06:38 PM   #7
beecher , Illinois
Thanks for the advice! We are lifting the shell to replace the subfloor. We will be getting going on it on Tuesday. Wish us luck!
Old 10-16-2016, 08:09 PM   #8
1973 31' Excella 500
Calgary , Alberta
I used metal studs and #6 self taping screw to brace from side to side.
This was more for just keeping it the same width.
Oh just to be clear I screwed the studs to the ribs.
DaKs is offline   Reply With Quote
Shell off - How do I secure the shell once it's off? gronlampa Repairing/Replacing Floor &/or Frame 8 10-30-2015 12:22 PM
How much bracing for a shell off? 195Pilot Repairing/Replacing Floor &/or Frame 2 05-05-2012 10:23 PM
Bracing for 'Shell-Off' on 60s safari Knoxvegas Repairing/Replacing Floor &/or Frame 12 06-01-2011 08:36 PM
'74 Excella - bracing shell for removal question DanielB Repairing/Replacing Floor &/or Frame 96 12-30-2010 04:27 AM
pics of shell bracing pinkflamingoes Repairing/Replacing Floor &/or Frame 0 05-29-2007 10:13 PM
