Old 09-05-2014, 04:00 PM   #1
Alcoa Roller's Avatar
Dallas , Texas
Houston We Have A Problem
Ok so call me senile or lets just say my once photographic memory is out of film. Anyway, of all my reading on here, I never caught the part about not using treated plywood for a subfloor due to corrosion with aluminum.
Yes, I did it. Installed the last 2 feet in my batroom due to rot with treated. The good news is everything is still out so replacement though still a pain will be relatively easy. Of course everything is bolted up.
Anyway, just want to confirm that yes I did dump in my Wally Byam beanie and need to replace asap.
Alcoa Roller is offline   Reply With Quote
Old 09-05-2014, 05:19 PM   #2
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
You would have to take a look at the specifics of the chemicals used to treat the wood you used. There are many different types and classifications of treating these days.
I don't ever use treated wood in sub-floor replacement, but that isn't to say it is wrong.
Lance
Top is offline   Reply With Quote
Old 09-05-2014, 05:51 PM   #3
1981 31' Excella II
New Market , Alabama
If you coat the wood with something like polyurethane it may not be an issue. Also if you put an strip of thin plastic between the floor and the aluminum and the floor and the frame, you will probably be fine. If the wood stays dry it does not cause corrosion. Fasteners need to be stainless steel.
Perry
Old 09-05-2014, 06:25 PM   #4
StingrayL82's Avatar
San Angelo , Texas
Images: 37
This is a pretty good site to peruse, if you're concerned with using treated wood: Treated Wood Products
Frederic
1971 Sovereign International - SOLD
2004 F-350 King Ranch
AIR # 8239
EX-WBCCI # 8371
StingrayL82 is offline   Reply With Quote
Old 09-05-2014, 06:33 PM   #5
robert claus's Avatar
2000 19' Bambi
mt. Prospect , Illinois
I think the problem may be more related to exposure to the treated wood chemicals in a small, enclosed space than it is to chemical reaction with aluminum. Of course, if you can fix the leak, and eliminate the moisture, it wouldn't matter what you use. But then, if that were easy, none of us would be having these issues.
robert claus is offline   Reply With Quote
Old 09-05-2014, 06:37 PM   #6
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I had to use pressure treated plywood several years ago in our trailer's bathroom area. It wasn't my first or second choice, but it did get the job done. So far, it has caused no trouble. Sometimes you get lucky, and I'd rather be lucky than good.
Old 09-05-2014, 08:10 PM   #7
Dallas , Texas
Thanks for the replies guys. Ill look into it a bit further. I guess the sure thing is to replace with untreated on the other hand if its a 50 year issue then what the hell. Bottom line is I don't want to be replacing panels and c channel a few year from now cause i didn't take the step of pulling what I now know was wrong.Im not a perfectionist per se but not into knowingly being an idiot.
Old 09-05-2014, 09:57 PM   #8
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I think if I were in your position I would just pretend that I never even saw treated plywood, and I would just finish the build.
Old 09-05-2014, 10:03 PM   #9
Bob Thompson's Avatar
Corpus Christi , Texas
Images: 67
The problem occurs when you use treated wood which has been treated with copper based wood preservatives. When copper comes into contact with aluminum, it tends to make a battery. Non copper based wood treatments work fine. I have used Olympic Stain's wood preservative to preserve the OEM plywood floor and works perfectly. Doesn't show any additional aging after 10 years.
So Long!
Bob Thompson is offline   Reply With Quote
Houston We Have a Problem! The Flintstones Winterizing, Storage, Carports & Covers 13 12-05-2009 12:36 PM
Houston, do I have a problem? Becky B. Belly Pans & Banana Wraps 25 03-08-2009 03:46 PM
Houston... We have a problem! mabuofh Member Introductions 5 02-12-2007 01:04 PM
Houston we have air pressure! ALANSD Airstream Motorhome Forums 27 12-09-2003 05:35 PM
CP in Houston Dwight Our Community 0 01-14-2003 07:42 AM
