Old 10-25-2005, 05:51 AM   #1
1977 27' Overlander
Huntsville , Alabama
Send a message via Yahoo to dustyrhodes
Holy floor
While we never reallly meant to do it, one thing lead to another and I am glad we gutted my 77 Overlander international. I found 3 small holes in the floor. I know that we have to address the leaks that caused them and have bought new vents and will reseal everything on top and follow up with the windows. I am not sure how to address the holes in the floor themselves. Do I need to pull the entire piece of plywood and replace or are these small enough to be dealt with in another way?
dustyrhodes is offline   Reply With Quote
Old 10-25-2005, 06:51 AM   #2
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
I had good luck pieceing in a section.
http://www.balrgn.com/Airstream/airs...oject_2004.htm
Good Luck
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 10-25-2005, 12:12 PM   #3
1977 27' Overlander
Wink Forum gratitude
Thanks for the information. I have alot of work to do and was hoping that I could just patch the plywood. Your repairs looked great! I need to get the Airstream into the air and pull off the belly skin to see if there is frame damage but have no idea where to get ramps or how to get my Overlander up onto them. There are many missing rivets and a tear where one of the leveling jacks was. This forum has been a lifesaver for a newcomer. I would not even have known where to start.
Old 10-25-2005, 05:06 PM   #4
till's Avatar
Lisle , Illinois
Images: 108
You should hook up with TomW. I think he maybe in your area.
Tedd Ill
AIR#3788 TAC IL-10
1967/8 Overlander International Twin w/ bunk/s.
Yes, four kids and two adults in the thing.
Happy wife, happy life.
till is offline   Reply With Quote
Old 10-26-2005, 04:09 AM   #5
barrie , ontario
you guys are the greatest, someone (an A/streamer) once told me its a cult, maybe it is ,but i love it!
twoguys is offline   Reply With Quote
Old 01-09-2006, 12:51 PM   #6
ankornuta's Avatar
Lowell , Massachusetts
Images: 22
Actually... I've been so busy removing my interior and prepping to remove the body that I haven't even considered where you'd jack one of thes trailers from. I suppose under the axle? Is that right... ?
ankornuta is offline   Reply With Quote
Old 01-09-2006, 01:10 PM   #7
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
That's what I did
www.balrgn.com
Old 01-09-2006, 01:19 PM   #8
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Axle jacking is bad! You can bend the thing a cause alignment problems of your wheels. From what I have read the pad that attaches the axel to the frame is the only place you should jack. I would ramp up the wheels to raise the trailer. You could build rams from scrap 2 x 6's fairly cheeply and it would be more stable.
Richard
Old 01-09-2006, 02:52 PM   #9
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I used one of these to lift our coach. Makes it real convenient to have the whole thing overhead to work on.
Old 01-09-2006, 09:00 PM   #10
ankornuta's Avatar
Images: 22
Geeze, that would be nice
Of course, my trailer has pretty sufficient clearance; without lifting it I was able to get under there and drill out all the belly pan rivets and remove the gas lines pretty easily. Sure, my neck was sore for a day or two, but it wasn't too bad.
Old 01-09-2006, 09:58 PM   #11
Wardinbb's Avatar
1964 24' Tradewind
Big Bear Lake , California
Gettin' it Up
DustyRhodes, Balgrn,
No experience with a two axil rig, but it may act like a single axil when lifted if supported adequately.
I used a standard solution found here on the Forum, a pair of car ramps. The hoist would be grand, if you've got one and the space. See K-Mart or Wal-Mart for a set of ramps. The extra clearance works wonders when spending any amount of time under the rig.
Have fun,Ed
Name:	Lifted forum.jpg
Wardinbb is offline   Reply With Quote
Removing the body shell and installing new floor completely - any one done this? williamhenshall Repairing/Replacing Floor &/or Frame 11 03-13-2006 11:21 AM
Question re new floor fitting on our 1958 Traveller williamhenshall Repairing/Replacing Floor &/or Frame 9 06-30-2004 03:08 PM
When lacking a floor to make a template... JrnymnJay Repairing/Replacing Floor &/or Frame 6 11-30-2002 06:28 PM
Front floor area and rebuilding dresser jeanarlene 1969 - 1973 Safari 10 09-05-2002 11:11 AM
Total floor replace 74Argosy24MH Repairing/Replacing Floor &/or Frame 1 06-27-2002 04:05 PM
