Old 04-12-2005, 01:50 PM   #1
somefun's Avatar
1974 27' Overlander
Puyallup , Washington
Holding tank support
I have a '74 Overlander (27') rear bath. The aluminum sheet that goes between the 2 subframes in the rear has started to sag, so I decided to replace it. Once it was removed, I noticed alot of rust on the angle iron frames that appear to be supporting the holding tanks. (There are 2 of them and they are hinged on the front). My question is, Is this the only support for the holding tanks? Because of their decaying condition, I'd hate to see my holding tanks in my rear view mirror!
Curt
somefun is offline   Reply With Quote
Can I use "regular" antifreeze in my holding tank? Luckydog Airstream Motorhome Forums 6 11-25-2002 07:01 AM
Holding tank valve pull's camphost Waste Systems, Tanks & Totes 3 10-31-2002 11:11 PM
Replacing Metal Box for holding tank Mike Waste Systems, Tanks & Totes 11 10-26-2002 03:40 AM
tradewind holding tank McGill Waste Systems, Tanks & Totes 3 06-22-2002 09:28 AM
Holding Tank Wiring 74Tradewind Waste Systems, Tanks & Totes 1 05-23-2002 04:22 PM
