Old 04-21-2015, 06:40 PM   #1
Tiger Tail's Avatar
1986 31' Sovereign
Jacksonville , Florida
hold down plates
The hold down plates in the back of my 86 Sovereign are bent over at the plate. There is about 3" of 1/4 x 28 All-thread bent over. How is the plate bolt secured on the bottom side? Is there a nut or is the frame threaded? I am looking to remove the bolts so I can remove the rotted flooring and slide new plywood under the C-channel.
Name:	2015-04-21 20.22.58.jpg
Tiger Tail is offline   Reply With Quote
Old 04-22-2015, 06:41 AM   #2
1975 31' Sovereign
Davin , West Virginia
Doing the same job on my 75 sovereign currently, only a few steps ahead of you. What I did was grind what was left of the bolts off flush with an angle grinder. To reinstall the plywood and channel, I am moving the bolt locations just an inch or so left or right, also adding some more bolts. I found at Ace Hdwre some 3/8 self-tapping lag bolts which are working great. Drilling 5/16 pilot holes and letting the screws cut their own threads into the hold down plate. Click image for larger version
Name:	ImageUploadedByAirstream Forums1429706471.834747.jpg
Name:	ImageUploadedByAirstream Forums1429706322.892079.jpg
Hillbilly75 is offline   Reply With Quote
Old 04-24-2015, 06:58 AM   #3
1975 31' Sovereign
I found out that you can get to the other end of the bolts by reaching inside the bumper storage compartment. Feeling around in there also will help you understand what you have underneath to bolt to when you reassemble. I wondered why the factory had located several bolts all the way rearward in the c channel. Turns out those were the only 3 that were through the cross member. All the rest missed rearward and weren't really holding the whole thing down to the frame.
hold down plates Tiger Tail Repairing/Replacing Floor &/or Frame 3 04-22-2015 06:58 AM
Paper plates or real plates? What about utensils and glassware? cantdrv55 Our Community 85 12-08-2014 02:37 PM
Goin' down, down, down... Aironius Axles 12 08-23-2014 08:09 AM
Hold down for Rock Guard uwe Rock Guards, Segment & Window Protectors 5 04-24-2003 05:01 PM
Jack Plates Jack Plates Inland RV Center, In Our Community 4 03-19-2003 03:34 PM
