Old 04-21-2015, 06:30 PM   #1
Tiger Tail's Avatar
1986 31' Sovereign
Jacksonville , Florida
hold down plates
The hold down plates in my rear C channel of my 86 Sovereign have been bent over at the plate. About 3" of the thread is bent over. How do I remove these and reinstall new bolts so as to slide my new flooring under the C channel. Is the fame threaded or is there a nut on the bottom?
Tiger Tail is offline   Reply With Quote
Old 04-21-2015, 07:02 PM   #2
1981 31' Excella II
New Market , Alabama
A dremel tool with a cutoff wheel works. If you can get to the heads on the bottom side you can grind them off with an angle grinder. They bend the screw so the nut won't come off. Try not to damage the c-channel in the process.
Perry
Old 04-22-2015, 06:45 AM   #3
1975 31' Sovereign
Davin , West Virginia
When I put a socket wrench on the bolts, they were so rusted they just wrung off and I easily got the channel out. I think I had to cut one with a cutoff wheel, but it wasn't hard to get to.
Hillbilly75 is offline   Reply With Quote
Old 04-22-2015, 06:58 AM   #4
1981 31' Excella II
I would put stainless steel bolts with Nyloc nuts going back in. mcmaster.com will have all the bolts you need.
Perry
Paper plates or real plates? What about utensils and glassware? cantdrv55 Our Community 85 12-08-2014 02:37 PM
Goin' down, down, down... Aironius Axles 12 08-23-2014 08:09 AM
Black rubber T-handle hold-down, latch iowaroots Commercial Listings 0 09-10-2004 08:33 AM
Hold down for Rock Guard uwe Rock Guards, Segment & Window Protectors 5 04-24-2003 05:01 PM
Jack Plates Jack Plates Inland RV Center, In Our Community 4 03-19-2003 03:34 PM
