Old 06-19-2011, 06:43 AM   #1
1959 28' Ambassador
Great Falls , Montana
Hindenburger frame & floor
The objective is to take a 59 Ambassador and build it from the ground up into a mobile food vending attraction. The project started 4 May with a gutted trailer. Working through heat and rain we have made good progress in 45 days. Stage 1 was the prep and seperation.
Name:	A1 - Get the project started.jpg
ID:	132741   Click image for larger version
Name:	A2 - First panel removed.jpg
Name:	A3 - Removing Panels and Rivets.jpg
ID:	132743   Click image for larger version
Name:	A4 - Ripping it out.jpg
Nashville is offline   Reply With Quote
Old 06-19-2011, 07:00 AM   #2
1959 28' Ambassador
Frame-a-saurous Rex
The frame was rotted out (big surprise) and was rebuilt to support a modern commercial kitchen. Weight was increased by 40% over the original frame. Choice of frame steel was solid and heavy. It's a critical trade off for strength that we had to make for the kitchen. (static or short tow trips)
Name:	A7 - Separation complete.jpg
ID:	132746   Click image for larger version
Name:	A9 - stripped frame.jpg
Name:	AB1 - Frame build1.jpg
ID:	132748   Click image for larger version
Name:	AB2 - frame build 2.jpg
Name:	AB3 - frame build3.jpg
ID:	132750   Click image for larger version
Name:	AB4 - frame ready for Sblast.jpg
Name:	AB5 - new suspension old school.jpg
ID:	132752   Click image for larger version
Name:	AB6 - 1 of 2 new axles.jpg
Old 06-19-2011, 07:04 AM   #3
1959 28' Ambassador
Frame sandblast prep prime and paint
In keeping with the retro look of the American Icon Airstream we went with bold with the color...
Old 06-19-2011, 07:19 AM   #4
1959 28' Ambassador
Lady in Red
What's great about America? Airstreams.... and the freedom to push the envelop of conventional comformity. We are having fun with the design....... with the intent for her to be rock solid...yet elegant.
Name:	AB6 - 2 ready for prime.jpg
ID:	132754   Click image for larger version
Name:	AB7 - Sand blasted and primed1.jpg
Name:	AB8 - S&P2.jpg
ID:	132756   Click image for larger version
Name:	AB9 - Red paint frame.jpg
Name:	AC1 - Red and Ready.jpg
ID:	132758   Click image for larger version
Name:	AC2 - New hitch.jpg
Name:	AC3 - Gray tank installed (16 gal from VTS).jpg
Old 06-19-2011, 07:24 AM   #5
1959 28' Ambassador
Hillbilly Rotisserie
After reading the threads and blogs regarding belly pan replacement we knew that flipping her over was the only solution. Our technique is as old as the pyramids.....substitute John Deere...
Old 06-19-2011, 07:32 AM   #6
1959 28' Ambassador
John Deere
Need a strong frame to pull this off
Name:	AC4 - sealed & painted 3 qtr  plywood.jpg
ID:	132761   Click image for larger version
Name:	AC5 - floor ready for custom cut.jpg
Name:	AC6 - World largest surfboard.jpg
ID:	132763   Click image for larger version
Name:	AD1 - Deere rotisserie 1.jpg
Name:	AD2 - DR2.jpg
ID:	132765   Click image for larger version
Name:	AD3 - DR3.jpg
Name:	AD4 - DR4.jpg
Old 06-19-2011, 07:39 AM   #7
1959 28' Ambassador
Custom belly pan mods
In order to access the bottom of the trailer easier we modified the belly pan a bit. This way we can access systems with a full off beely pan removal. We also built strong custom wheel wells for inside of the kitchen.
Name:	AD5 - Belly job1.jpg
ID:	132768   Click image for larger version
Name:	AD6 - belly job 2.jpg
Name:	AD7 - Belly job 3.jpg
ID:	132770   Click image for larger version
Name:	AD8 - belly job 4.jpg
Name:	AF1 - custom wheel wells.jpg
Old 06-19-2011, 07:52 AM   #8
1959 28' Ambassador
Back upright with floor covering and C channel
All hands were busy rotating her back over....so there were none available to take pics.....it was essentially the same as originally flipping her over....just more delicate due to belly pan. Floor covering choice was in keeping with the retro look.. C channel was custom fabricated in our shop from stock.
Name:	AF2 - ready for floor covering.jpg
ID:	132773   Click image for larger version
Name:	AF3 - floor ready.jpg
Name:	AF4 - mobile dance floor.jpg
ID:	132775   Click image for larger version
Name:	AF5 - Dizzy yet.jpg
Name:	AF6 - floor rear.jpg
ID:	132777   Click image for larger version
Name:	AG1 - c channel corner.jpg
Name:	AG2 - c channel side.jpg
ID:	132779   Click image for larger version
Name:	AG3 - c channel corner 2.jpg
Name:	AG4 - waiting for her dress.jpg
ID:	132781   Click image for larger version
Name:	AG5 - f and f.jpg
Old 06-19-2011, 07:52 AM   #9
Aluminum Falcon Mechanic
Darkspeed's Avatar
1972 31' Sovereign
Wesley chapel , Florida
Fantastic work!
Darkspeed is offline   Reply With Quote
Old 06-19-2011, 08:05 AM   #10
1959 28' Ambassador
Time to get the shell back on
She was braced pretty solid so the chasis fit back beneath her very well. With the typical fudging and squeezing we dropped her back on....no worries... well...a few.. We used straps to tighten and hold her down while we clecko'd and riveted her back together. With the shell back on..we are ready to........
Name:	AG6 - rivet side.jpg
ID:	132783   Click image for larger version
Name:	AH1 - fitting her back.jpg
Name:	AH2 - front fit.jpg
ID:	132785   Click image for larger version
Name:	AH3 - back again.jpg
Name:	AH4 - ready to drop.jpg
ID:	132787   Click image for larger version
Name:	AH5 - rear fit.jpg
Name:	AH6 - fitting strap.jpg
ID:	132789   Click image for larger version
Name:	AJ1 - rear hatch.jpg
Name:	AJ2 - rear hatch floor.jpg
ID:	132791   Click image for larger version
Name:	AJ3 - rear hatch out.jpg
Old 06-19-2011, 08:09 AM   #11
1959 28' Ambassador
Sweat
Ohhhhhh...is it hot inside an aluminum can in Mobile Alabama in June. Thank goodness we have our hillbilly air conditioner window unit.....necessity is the mother of invention.
Name:	AJ4 - Hot hot does it get inside a can.jpg
ID:	132793   Click image for larger version
Name:	AK1 - Hillbilly Air conditioner.jpg
Old 06-19-2011, 08:45 AM   #12
Ottawa , ON
Fabulous project
I love what you are doing, looks great!
But what calculations did you do that makes you fee the single axle will support all the weight you have added, as well as the weight of the equipment that you will add to it in order to have your mobile restaurant?
Perhaps there was another thread where you discussed that, but I didn't see it, if there is.
Shorter trailers than that, ones that are only destined to be campers, have two axles today...
Old 06-19-2011, 08:49 AM   #13
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Picture seven of post two clearly shows mounting for two axles...
Old 06-19-2011, 08:57 AM   #14
1959 28' Ambassador
running gear
It's a 2 axle rig. Each axle is rated at 5100lbs.... suspension springs heavy duty.....wheels are rated at 2600lbs each.....tires will be 15s rated at 2800lbs + each
She will be beefy..... so we will have the heavy running gear to support her...
Newbie needs soft floor repair advice lbdesign Repairing/Replacing Floor &/or Frame 20 09-10-2012 11:32 PM
Between new floor and frame? surfpod Repairing/Replacing Floor &/or Frame 11 07-01-2011 06:21 AM
'69 Overlander frame repair colin57 Repairing/Replacing Floor &/or Frame 6 04-25-2011 10:45 AM
frame reinforcement - rear end separation silversafari Repairing/Replacing Floor &/or Frame 1 03-17-2011 10:16 AM
The frame is ok ~ Patching the floor. LawChick Repairing/Replacing Floor &/or Frame 12 01-30-2011 02:39 PM
