Old 08-23-2008, 09:42 PM   #1
1966 26' Overlander
Conover , Ohio
hidden damage at the edges
I am replacing the rear floor section of my 66 Overlander. I am currently cleaning up the frame for the POR-15. Since I have gone this far, is there any reason for me to peel up the bottom part of the interior skin to check for any other floor rot. I can see every square inch of floor from the bottom, and all but the outside 1 ĹĒ that is under the walls from the top. I see no signs of problems at all and I donít want to waste my time chasing my tail. Could there be any problems that would only show by pulling up the wall a bit? Anybody been there? Thanks, TomE
air66stream is offline   Reply With Quote
Old 08-23-2008, 09:49 PM   #2
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
not sure you'll see anything new pulling those off, since it will be covered with the c-channel. I mean if you're looking for things, you could find something, but might be more productive to use an ice-pick instead.
goransons is online now   Reply With Quote
Old 08-23-2008, 11:27 PM   #3
Olielulu's Avatar
1972 25' Tradewind
Webb Lake , Wisconsin
I agree that you will not find anything relating to floor rot, although you may find a bunch of other things and decide "I should fix that since I've got it this far" Be careful, It's like a giant black hole and will suck you in. before you know it you have the whole thing tore apart.
You will have to pull it off in the area that you are replacing the floor though. there are supposed to be bolts holding the C-channel to the frame in there, and pulling those panels is the only way to get at them.
Good luck!
Olielulu is offline   Reply With Quote
plastic trim that holds headliner edges k44g Upholstery, Blinds, Walls & Interior Finishes 3 05-27-2008 10:11 PM
Rubber or plastic piping on cabinet edges? durans54 Cabinets, Counter Tops & Furnishings 12 03-28-2007 09:07 PM
Speaker locations - hidden? SilverToy Audio, Video & TV 5 03-25-2005 10:19 PM
Hidden wiring. Joe62984 Electrical - Systems, Generators, Batteries & Solar 6 02-27-2004 08:13 PM
Hidden Brake Controllers Dr. Harold Becker Brakes & Brake Controllers 4 07-13-2003 08:13 PM
