Old 04-02-2012, 03:16 PM   #1
macstrange's Avatar
1968 26' Overlander
Tucson , Arizona
Here's my restoration. How's yours going?
If you look closely in the lower rear quadrant of the photo you can see ductwork. I'm assuming this is not typical. All the yellow stuff is spray foam insulation. Comments?
Shawn Bradley
macstrange is offline   Reply With Quote
Old 04-02-2012, 06:04 PM   #2
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
Not sure if this the "before" or "after" resto, but looking good! I think you can re-use much of that insulation, possibly in a dog house, or just to hold the ductwork up off the ground.
tphan is offline   Reply With Quote
Old 04-03-2012, 07:34 AM   #3
macstrange's Avatar
1968 26' Overlander
Tucson , Arizona
Lifted shell off about 2weeks ago. Stripped plywood deck. Cutting stabilizers off to remove belly skin. Found wire harness encased in insulation. Will need to replace that since PO cut hookup off. Tank will probably need replacing also. Duct work going away. Don't like the idea of floor penetrations.
Shawn Bradley
Old 04-03-2012, 11:01 AM   #4
macstrange's Avatar
1968 26' Overlander
Tucson , Arizona
It looks as if the duct is original. there's a 7' section that could only have been installed at the factory, I'm assuming. Does anyone have any insight on this? I'm thinking it needs to go so I can properly clean, prime and paint the frame.
Shawn
Shawn Bradley
Old 04-03-2012, 12:00 PM   #5
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
No duct work beneath the floor on my '72 but ALL the above floor ones were mouse spice-road super-highways complete with dung dunes. That said, I would have no hesitation removing duct as long as there are no plans to restore it back to original.
I think that may be poured (sub-floor) foam insulation - sure looks remarkably free of rust, has that trailer stayed in the SW area its whole life?
That sure looks like a lot of frame for a mere 26' trailer! Looking good so far, keep the momentum up and don't let the devil in the details distract you... or something to that effect, anyway.
Old 04-03-2012, 12:39 PM   #6
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
No under-floor ductwork in my '72 either; would that have been to keep the water and waste tanks from freezing?? In any event, doesn't sound like you need it. Have fun with your Large Resto!
Old 04-04-2012, 10:02 PM   #7
JFScheck's Avatar
Rockville , Maryland
Images: 33
Unless you are in extended cold weather I guess it wouldn't be a problem, but since she is naked, why not add so to protect you from such a "chilly" occurance?
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 04-15-2012, 10:18 AM   #8
salzburg , salzburg
Mine had that ductwork and that crappy yellow insulation, i dumped my ductwork, but saying that i dumped my frame as well!!
mrgreen is offline   Reply With Quote
Old 04-15-2012, 12:23 PM   #9
Splitrock's Avatar
Sioux Falls , South Dakota
"dung dunes" Hahaha!!!! THAT'S funny!
Good one! Thanks for the laugh!
Old 04-18-2012, 09:03 PM   #10
Tool Hoarder
West , California
Shawn
I had the exact same set up. I strangely had no evidence of mice in my trailer whatsoever (lots of wasps nests) I removed mine so I could work on my frame. I wish I would have put in new duct in its place. I have to run duct work behind cabinets now. If I could travel back in time and have a chat with my past self I would tell him to plan your interior prior to floor replacement. You have a big frame with a lot of space for ducts, grey tanks, fresh water tanks etc. It can free up a lot of living and storage space, just sayin...
marzboy is offline   Reply With Quote
Old 04-18-2012, 09:13 PM   #11
1974 Argosy 20
Kooskia , Idaho
I had a '68 22' with ducts below the floor and spray foam insulation, all from the factory. The duct system was great, well insulated and took up no room in the unit at all. The heat was forced out of the furnace, down into the ductwork and through the length of the trailer (but it was short). With the body stile change in 1969 they went with the above floor ducts which cluttered up the cabinets. I always liked the '68 system.
Old 04-18-2012, 10:29 PM   #12
1968 26' Overlander
West Richland , Washington
I tore into my 68 26' Overlander last year and also found the ductwork within the frame and factory sprayed insulation (and the spray insulation was not applied very well or throughly). My ductwork was not insulated and I cut it out. It also had a small hose to blow heat onto the black tank.
I've installed grey and and fresh water tanks within the frame. Heater ducts will be within the cabinets.
JIMandPJ is offline   Reply With Quote
Thank goodness I found you...now how do I?? SnailLip Member Introductions 28 09-24-2012 08:30 PM
Finally polishing my 34' c_lewis77 Cleaning, Stripping & Polishing 106 08-25-2012 02:34 PM
I have a strong mildew smell coming into the rear Bedroom of my 34 foot classic. Emh142 General Repair Forum 8 04-03-2012 06:26 AM
How to reseal windows 92landyacht Land Yacht/Legacy Motorhomes 8 04-03-2012 06:16 AM
Need suggestions to get my tires fixed wavemaster Working on the Road 5 04-02-2012 02:47 PM
