02-08-2011, 11:08 AM
1971 21' Globetrotter
1965 17' Caravel
1951 15' Cruisette
Austin
Help with removal of rusty Bolts/Screws
Hello All!! Thanks in advance!!
What is the best way to remove the rusted bolts/screws from the C channel? I have a multi tool but the blades don't seem to work well to cut the bolts off from above. Is grinding them off from under the BP the best way?
02-08-2011, 11:20 AM
1977 27' Overlander
1963 19' Globetrotter
Naples
I use a 4" angle grinder with a cutting wheel in it. Dave Just don`t start a fire!!!
02-08-2011, 11:21 AM
1978 28' Ambassador
Morada
A HD Saws-all should cut right through em' if you use the proper metal cutting blades...
Ray & Pat; Morada, CA
02-08-2011, 11:42 AM
Jupiter
I plunge cut with thinnest (0.8mm?) high speed cutting wheel down the bolt shank to separate a 40-50% chunk off the nut off and then twist it off with vice-grip pliers...
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
02-08-2011, 01:46 PM
Austin
For the ones that come up from the bottom and have the nut on the top, grab a pair of vice grips and bend the bolt shaft back and forth a couple of times. They'll often just snap right off. For the ones that go topside-down, you'll need access to the under side to do that.
02-08-2011, 02:00 PM
1965 17' Caravel
1951 15' Cruisette
Austin
Thanks for all of your input! Since I have the tools for all of these methods, I'll give them all a try and see which one works best! Doing the full monte on my '71 Globtrotter and while it is challenging, nothing has come too easy in this refurbishment......
02-08-2011, 02:02 PM
1981 27' Excella II
mays landing
, South Jersey
Dont forget eye protection. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
02-08-2011, 02:08 PM
x
XXXX
, XXXX
katy I agree with utee94 and Wabiteer. The fastest and easiest way is to snap them off with vice grips. I tried several methods and then just ended up using the vice grips and was done in no time at all.
02-08-2011, 02:31 PM
1965 17' Caravel
1951 15' Cruisette
Austin
I think that will work fairly well, but there are several self tapping wood screws that are so rusted that my drill phillips drill head cannot get a grip to unscrew them. Thus, i thought the multi tool could get in between the wood and the c channel to cut it loose.
02-08-2011, 02:41 PM
x
XXXX
, XXXX
Katy for those little wood screws just grind the heads off them or if you want to go to the trouble of removing them grind a notch in them and remove them by hand with a regular slotted screwdriver.
02-08-2011, 04:17 PM
1965 17' Caravel
1951 15' Cruisette
Austin
DUH!!! I am such an idiot! That is a great idea...it is so simple it is brilliant. Thanks Wasagachris.
02-09-2011, 08:26 AM
Sioux Falls
, South Dakota
I just cut the screw heads off with a sharp Stanley wood chisel. The bolts, I cut off with a metal cutting blade in a Sawzall.
