Old 01-12-2013, 07:40 PM   #15
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
I found the '73s wheel well lower tubs were best anchored to the shell and only loosely clamped between the floor and frame with a lot of evidence they had defeated all the asphalt weatherizing caulk tape moving with shell travel --- so they 'felt' solid. The top interior tubs were best anchored to the floor and only lightly attached to the shell. The gap between them was packed with fiberglass that amplified the 'solid' feel to them.
The gotcha a couple of us have found on shell-off's is the shell relaxes slightly in a curl (the end channels lose a couple of inches distance between them) and stretching the entire length of the trailer is a major hassle as the weight binds everything up once its resting against the floor.
Where I saw 'slop' the worst was the battery and water heater shell cut-outs where I had patched over them, what had been skinned over taut before pulling apart the shell/frame went back with an inch of bowing outward.
Rear End Separation Short term fix? Silverflames Repairing/Replacing Floor &/or Frame 63 09-08-2013 06:05 PM
Dreaded rear-end separation! Belegedhel Ribs, Skins & Rivets 20 08-28-2012 03:42 PM
Why no rear dinette on the shorter trailers? snakyjake Boondocking 22 02-15-2012 05:50 PM
Gap between floor & frame at the rear end ASNomads Repairing/Replacing Floor &/or Frame 6 01-30-2012 04:09 PM
Spare tire carrier under rear end. perryg114 Tires 21 11-02-2011 12:34 PM
