Old 07-16-2005, 05:02 PM   #1
pinkflamingoes's Avatar
1967 24' Tradewind
Alameda , California
Images: 38
Send a message via AIM to pinkflamingoes Send a message via Yahoo to pinkflamingoes
help, quick!
Hi,
Husband started cutting plywood for the new floor today. What bug got in him in this mini-heatwave I'll never know, I'm too happy to ask.
Any advice?
Bolts: what size, and what kind? Stainless steel?
Last question: Anyone wanna come help? Free iced tea and BBQ tonight.
"Let's look Death in the face and say, 'Whatever man.'"
~ Hurley
ingrid
1967 24' Tradewind #19104 ~ Forums #4449
pinkflamingoes is offline   Reply With Quote
Old 07-16-2005, 09:37 PM   #2
early's Avatar
Ingrid can't help on the floor, but the iced tea and BBQ sounds good. It would take about 3 days for me to get there. I didn't think people outside of the south drank iced tea. sweet I hope.
Dawn
early is offline   Reply With Quote
Old 07-16-2005, 09:37 PM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Originally Posted by pinkflamingoes
Hi,
Any advice?
Ingrid,
If you are talking about the bolts on the outriggers I used 1/4"-20x 3" stainless steel cap screws.
Aaron
WBCCI #XXXX AIR #2495
Old 07-16-2005, 10:49 PM   #4
greg176's Avatar
Gabriola Island , British Columbia
Ingrid
Glad to see things progressing.Do a search for elevator bolts.Lots of info here on the forums.I used zinc plated steel.In the outer "U" channel I used 1/4" bolts that were 1 1/4" long. They were also zinc plated.I would also suggest that they be grade 5 bolts (3 lines on bolt head) anything cheaper will just break.
greg176 is offline   Reply With Quote
Old 07-16-2005, 11:48 PM   #5
desi arnaz's Avatar
got a good recipie for sweet tea? how do they make it taste sooo good?
desi arnaz is offline   Reply With Quote
Old 07-17-2005, 07:35 AM   #6
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
It's a simple recipe.
1-Add 1 quart fresh-brewed tea to 1 cup sugar.
2- Stir.
3- Drink.
4- Fly around the house.
Old 07-17-2005, 08:25 AM   #7
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Here is OUR recipe
Get a 2 quart sauce pan
Put about 1.5 quarts of water in it
add 1-1/14cups of sugar
bring to boil, remove from heat
add tea bags...we use the family size and use 5 of them
allow to cool at least for 1/2 hour
pour over ice in a gallon pitcher and add enough water to make a full gallon.
Now if my wife it making it...double the sugar
Aaron
Old 07-17-2005, 08:32 AM   #8
Well Preserved
1993 21' Sovereign
Originally Posted by wahoonc
Here is OUR recipe
Aaron
I agree, see step #4 of my recipe above...
Old 07-17-2005, 10:13 AM   #9
desi arnaz's Avatar
it never taste's the same as it dose in the south..........
Old 07-17-2005, 10:24 AM   #10
Well Preserved
1993 21' Sovereign
Unhappy
Aaron and I are both in the South. I am so far South, I am almost in the North...
Old 07-17-2005, 03:48 PM   #11
sd90mac's Avatar
I use 1/2 cup splenda in tge hot tea after the tea maker is done, and the tea is great.
Marie
When people lie to you, and refuse to honor their word, don't regret trying to follow a dream, new adventures and friends await you.
sd90mac is offline   Reply With Quote
Old 07-17-2005, 06:59 PM   #12
1967 24' Tradewind
Images: 38
DOESN'T ANYONE CARE ABOUT MY FLOOOOOR??????
just kidding. you all crack me up.
BTW; iced tea is sort of passe' here in we-think-we're-so-hip Northern CA. If it's not a flavored water or a super-caffeinated herbal whatever with a rock and roll name, it's "nothing". Especially if you can get it for less than $50 a case.
So, here:
Decide how many teabags you wanna brew. Split them in 1/2, half being black tea (Lipton) and the other a fruit flavored tea. Brew. Add ice, sugar and some passe' sweetener like Equal or Sweet'n'Low, Splenda if you can afford it, and drink.
Don't tell anyone I drink iced tea! They might mistake me for someone with a trailer in my driveway.
Pictures of the floor battle soon.
~ Hurley
ingrid
Old 07-17-2005, 07:16 PM   #13
Well Preserved
1993 21' Sovereign
Splenda if you can afford it, .
Ingrid, everyone KNOWS us Airstream millionaires can afford Splenda.
At least we were discussing tea, and not what we just found in our holding tanks...
Old 07-17-2005, 07:37 PM   #14
87MH's Avatar
1978 31' Sovereign
Images: 292
....Bolts: what size, and what kind? Stainless steel?...
Ingrid:
On the bolts - use as large a washer as will fit in the "C" channel to distribute the clamping and pull-through forces on as large an area as possible. Use large washers on the underside, also, if no other metal is present as the bolt heads will quickly wear a hole through the naked plywood.
I feel that the use of a "Nylock" or similar nut on the bolts is very important to prevent the bolts from loosening...as hard as they are to get to after you button up the interior. The "Nylock" nut has a sort of plastic insert on the end and replaces (or assists) the conventional "lock washer".
I drilled and installed a few more 1/4" bolts around the rear perimeter of the '78 sovereign than Airstream originally had...I tried to put a bolt wherever a steel crossmember met the "C" channel.
On the final fitting - don't force it - I remember well the words of an old farmer uncle of mine - "if it don't fit easy it ain't fit right".
The aluminum will give a bit if you try to force the floor, but a perfect initial fit is much more prefered.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Quick education needed on bringing old LP tanks into compliance, please Rog0525 LP Gas, Piping, Tanks & Regulators 5 05-09-2003 08:10 PM
Need HELP! Need help quick - dropping the belly pan escapeez Belly Pans & Banana Wraps 8 12-30-2002 07:03 PM
Just a quick ThanX to everybody. BobbyW Our Community 0 10-29-2002 09:49 PM
quick question is it a 77 or a 76 overlander Our Community 23 10-03-2002 08:21 PM
waterhose quick disconnects John Fresh Water Systems 3 04-19-2002 07:58 PM
