Old 07-20-2004, 09:08 PM   #29
JeepinAudiophile's Avatar
1968 24' Tradewind
Fort Myers , Florida
Images: 66
Send a message via AIM to JeepinAudiophile Send a message via Yahoo to JeepinAudiophile
update update!!!!!!!!!!!!!
The shell is off, and supported- YAY. Tomorrow in the light we will make sure that everything is out of the way, and will pull the frame out from underneath the shell.
Tow Rig: 2005 GMC Sierra Denali AWD, 6.0L HO- LOTS OF UPGRADES to help Towing (and Fun)
Trailer: 1968 Tradewind 24', Land Yacht trim (Shell-Off Rebuild and upgrades)
***Missing from my life***
WBCCI # 13657
++Take a look at my restoration photo album++
http://picasaweb.google.com/ChadsAirstream
JeepinAudiophile is offline   Reply With Quote
Old 07-21-2004, 06:23 AM   #30
Over59's Avatar
Putnam , Connecticut
Images: 37
How did you make out in those storms we had over the weekend? You're right down the road from us and it was pretty windy here.
Over59 is offline   Reply With Quote
Old 07-21-2004, 11:38 AM   #31
1968 24' Tradewind
Images: 66
I waited until after the storm to start lifting, so i was okay... It is up, and the frame is pulled out from underneath. Now to do just a little more bracing, then we're going to tie it down to the ground...I'm going to go take pictures of it now, i'll post them in a little while.
WBCCI # 13657
Old 07-21-2004, 12:02 PM   #32
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
Fun time isn't it? LOL Been there done that got the merit badge.
Now I'm trying to wrap it up.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 07-21-2004, 03:42 PM   #33
1968 24' Tradewind
Images: 66
got carried away and forgot to download the pictures to my computer... but here they are. Now I just have to make measurements of the holes in the floor, and document it all for cutting the new plywood.
WBCCI # 13657
Old 07-21-2004, 05:46 PM   #34
1973 31' Sovereign
Portland , Oregon
Images: 22
What display mode?
JeepinAudiophile,
I am curious what display mode setting you are using for viewing this thread. If you don't know what I am refering to I mean the settings on the "Display Modes" menu item at the top. I ask because I have been using the "Hybrid Mode" and I discovered that not all of the posts were showing up when I looked at the thread that way. When I changed to the "Linear Mode" they all appear with the most recent one at the top of the list.
Malcolm
malconium is offline   Reply With Quote
Old 07-21-2004, 08:55 PM   #35
1968 24' Tradewind
Images: 66
I am using the linear mode. I do not know why some of the posts would not show up in hybrid mode.
WBCCI # 13657
Old 07-26-2004, 01:36 PM   #36
1968 24' Tradewind
Images: 66
Talking
Update: the floor is off, and we are modifying the frame to put in a new black water tank, and add a gray water. The black water tank was destroyed since it had become the floor in the bathroom when the wood rotted away. So try not to be too jealous about this...lol We are installing 2 tanks... one for black and one for gray... 35 gallons each. I will continue taking pictures of the progress, but i begin work tomorrow so i will be left to working a few hours at night, and the weekends.
WBCCI # 13657
Old 07-26-2004, 02:24 PM   #37
yukionna's Avatar
Massachusetts
Images: 18
Send a message via Yahoo to yukionna
Will your A/S weight capacity be able to handle the load of two full 35 gallon tanks?
WBCCI Region One
Attitude is the only difference between ordeal and adventure
yukionna is offline   Reply With Quote
Old 07-26-2004, 03:24 PM   #38
1968 24' Tradewind
Images: 66
Talking
We believe so... i have a pair of 2500 lb axles, and the previous loaded weight was 4200. We will be adding roughly 350lbs of extra weight when both are full. The rear bath dictates where one of the tanks has to be- right below the toilet... so there's one of the 35g. tanks which will be length-wise sideways, almost the full width of the frame rails. The other one we have more room to work with, so it will be sitting agains the axles on one end (lengthwise with the frame) leaving it's loaded weight very close to the pivot of the frame. We also decided to add a bunch of frame support to strengthen the rear vertical load carrying ability. The designs are forming as we work, i can't wait to get it done and get out camping. To date i have taken slightly under 450 digital photos... so there will be plenty pictures of the project to see.
WBCCI # 13657
Old 07-26-2004, 03:35 PM   #39
2005 31' Classic
Gretna , Nebraska
I appreciate the above discussion. My "new" 31' (1986) had some bad floor areas which I have removed (the front 4 feet and near door). Also bad under toilet.
Questions:
#1 - I believe I have heard it recommended that a wax ring be used under the stool. Right?
#2 - I have not removed any interior shell. The floor was rotten enough in most places to be cleaned out of the outer groove with hand tools. I plan to replace by notching where bolts, screws come down. I there a structural reason not to do this?
#3 - Insulation. Do I understand that water inside is a given and I don't want insulation to lay on belly pan? It appears water has entered along the floor to shell seal, and I plan to seal it well with Vulkem outside & maybe some silicon inside. I would like to have it dry from the get-go. And place fibergalss bats on the belly pan.
Any help would be gratly appreciated.
Dwight
16595 is offline   Reply With Quote
Old 07-26-2004, 03:50 PM   #40
1968 24' Tradewind
Images: 66
I am learning as i go, the people in this forum have been greatly helpful in keeping my learning curve in the safety zone- so surely they will be able to help you as well. What do you mean by notching the bottom? The bottom of the inner skin?
WBCCI # 13657
Old 07-26-2004, 04:01 PM   #41
1968 24' Tradewind
Images: 66
I would also like to add to that, that you may want to check on the frame if the floor was that bad- surely it is in need to some repairs in that case. That was how we got started... it all started with pulling up the old gross carpet just to get it out... now all of a sudden i'm cutting, modifying, adding to the frame, replacing my single 17 gallon black water tank with a 35 gallon black water tank, and throwing in a 35 gallon gray water tank while we're at it. This may be taking it a bit far (53 additional gallons).... but it's the bug!!! My father is already talking about finding a 50's trailer as the next project. Be careful or you'll get bit, but also if you plan on keeping the trailer for a while- you should make sure the platform for which the trailer is constructed is in good standing order. I plan on towing my trailer around for an additional 36 years, i'm trying to modernize it without modifying the outward appearance and also re-juvenate it's life to get many more years of smooth, silver streaking out of it.
WBCCI # 13657
Old 07-26-2004, 04:10 PM   #42
2005 31' Classic
Gretna , Nebraska
My NOTCHES will be in the margins of the plywood flooring to fit around the bolts that hold shell to frame.
Anyone replace MH Front Wheel Bearings? swebster Mechanics Corner - Engines, Transmission & More... 17 06-27-2004 11:55 AM
front & rear wraparound want310 Windows & Screens 10 02-04-2004 02:17 PM
Front & rear windows clear or covered? Forrest On The Road... 9 07-15-2003 10:48 PM
Z71 or Z85? River Rat Tow Vehicles 7 05-09-2003 04:40 PM
replace twin beds in rear bedroom update femuse General Interior Topics 7 03-24-2003 09:25 AM
