Old 09-14-2006, 08:16 AM   #21
JimGolden's Avatar
1977 31' Excella 500
You guys have really got me thinking on this now. I'm going to research this deeper. Not just this specific trailer, but aluminum framed trailers in general. I see them all over the place and assumed they must be OK as they're so common. Heck, Mack Truck used to offer aluminum frame rails on their rigs. I don't know if they do now or not. I would have thought airplanes take more beating than trailers, but I could be wrong on that.
I'm going to dig into this. Report back when I have something.
Thank you for the info.
- Jim
JimGolden is offline   Reply With Quote
Old 09-14-2006, 09:43 AM   #22
Airstream construction methods are similiar to aircraft, but not the same.
Aircraft methods of construction methods are called "monocoque".
Airstream methods of construction is called "semi-monocoque".
"Monocoque" is defined as a "load bearing shell".
Aircraft do not have a frame, Airstream does.
Airstream has an incomplete shell, since it has a frame. The overall performance of the shell is therefore somewhat compromised, as opposed to an aircraft.
Accordingly, a semi-monocoque method of construction, since it's partially dependent on a frame, can punish that frame as the shell twists when in motion.
Aircraft twist in motion, but since they do not have a frame, there is no deleterious shell behavior, at least within the confines of the designed "G- force" limits.
The bottom line is very simple.
An aluminum framed travel trailer, "WON'T WORK," without sustaining severe structural failures.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 09-14-2006, 11:05 AM   #23
at_wanderer's Avatar
Jim,
I don't know if this information is correct, but it could help in your research. I was told that General Motors also put aluminum frames under their busses. Somewhere between 1948 - 1956(?) or even up to 1962 on the 4102 - 4106 models.
Sorry that is sketchy second-hand info, but it is something to look at to possibly see what their experiences were.
Brent
at_wanderer is offline   Reply With Quote
Old 09-14-2006, 04:05 PM   #24
Addicted to Aluminum
A-Merry-Can's Avatar
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
it would cost a lot more, but what about stainless? at least the tongue and rear section? she'd bling like a new quarter!
jp
8576 • • • • • • • •
there's always room for one more!
A-Merry-Can is offline   Reply With Quote
Old 09-14-2006, 04:16 PM   #25
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
I believe there would be a way of building a stronger enough AL frame. Just not in the same thickness as steel not in the same manner as steel. There are small (up to 25') power boats out there that work. And huge yachts that are made of that light stuff. The issue usually is cost for a production unit. Huge yachts are custom and one off so price while is some what of an issue it's not usually the only one. And this has to be considered after the thing is engineered. Or in this case since Skip doesn't have a lab to work in, I would suggest it needs to be over-engineered to survive.
And why do it?
To prove it can be done? OK knock your socks off.
To do a replacement on a unit that wasn't maintained and it rusted through? Just weld in a steel patch and move on. 'Cause if you don't, your off time may be spent entirely making something untried work. And camping is so much more fun than that.
>>>>>>>>>>>>>>>>>>>>>Action
Old 09-14-2006, 07:35 PM   #26
Carbon Fiber, anyone?........Hey, I'm not joking!
Old 09-14-2006, 08:00 PM   #27
JimGolden's Avatar
Now you're talking! We could do a new shell out of it too, and pressurize it. No more uncomfortable camping high up in the Rockies
Composites don't fatigue, have triple the strength of steel, don't corrode, are light and extremely stiff. Oh yeah, it just costs twenty times as much as aluminum...I knew there had to be a downside in there somewhere
Man it'd be cool though!
- Jim
Old 09-14-2006, 08:11 PM   #28
till's Avatar
Lisle , Illinois
Images: 108
Now I would pay to see a carbon fiber shell Airstream on a Stainless steel frame with gold plated rims. But all the name plates will have to be aluminum.
Tedd Ill
AIR#3788 TAC IL-10
No trailers...
till is offline   Reply With Quote
Old 09-14-2006, 11:09 PM   #29
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
We would have to change the name from Silver Bullet to Bullet proof.
>>>>>>>>>>>>>Action
Old 09-15-2006, 12:17 AM   #30
1960 24' Tradewind
santa barbara , California
Hello everyone , Well it is interesting to know that airstream did attempt
to utilze an aluminum frame ,testing and such .thanks Andy for that information ,too bad it was not sucessful .I agree on the twisting /flexing
would be detriment to the aluminum frame .As Jim golden pointed out with
riviting a frame instead of welding it.Had a jeep turbo 400 trans once with a
huge crack starting at 1 area of the bell housing going up over to the top side ,say 8 " long ,it was welded proffesionally and the bellhousing recracked
right on the weld and right along side the weld ,so both sustained cracks.a new case fixed the wagoneers transmission finally ,but I remeber that it was
quite a surprise to see that happen .aluminum is tricky and takes considerable
thought to fabricate somthing like a frame ,and to be successful .A frame is not a bellhousing ,but the stress on that cracked area was enough to rebreak it ,no loose bolts as I myself did the R&R of the trans both times , which was
what we thought must have happened before ,hard to say ,still broke.
Scott
scottanlily is offline   Reply With Quote
Old 09-15-2006, 05:59 AM   #31
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I am not an engineer or metaluragist
however, I spent a fair share of my adult life working with metals. It possibly could be done. Cost effective I doubt it. There have been great strides in composites and metal alloys in the past 35 years. But if you really want to go first class...and light weight... why not titanium
Aaron
WBCCI #XXXX AIR #2495
Old 09-15-2006, 11:12 PM   #32
2006 39' Skydeck 390 SD
New Smyrna Beach , Florida
why not titanium
any idea how much the material cost for a 22 foot titanium frame would cost for the materials? -seriously- how much weight would it save over steel? I see there is a kit aircraft using titanium for the fuselage tubes, maybe that is the way to go?
looks like aluminum has been done and failed. at least this is more fun than actually building a bad idea.
SkipS is offline   Reply With Quote
Old 09-17-2006, 02:27 PM   #33
JimGolden's Avatar
Ti good stuff but hard to machine
Titanium is really hard to machine. Other than that, it's pretty good stuff. Weighs more than aluminum, but still a lot less than steel. Very expensive though. Unless you've got the inside source
Realistically though, you don't have to machine it very much. If you've got the pipeline, it's worth looking into!
- Jim
Old 09-18-2006, 06:54 AM   #34
till's Avatar
Lisle , Illinois
Images: 108
Also make sure that it is not pure titanium. The pure stuff is very flexable.
Tedd Ill
AIR#3788 TAC IL-10
No trailers...
Old 10-01-2010, 03:16 AM   #35
Althea68's Avatar
2012 23' International
North Everett , Washington
Images: 18
Also of Al
I am an A&P as well and I can attest to the frequency of Aluminium failures in many many jets. We inspect them though on a required regulated schedule and replace the questionable components. If you were into that kind of inspection and maintenance ritual you would probably be ok. However, what would you use for fasteners i.e. nuts and particularly bolts? You would certainly wind up with dis-similar metal corrosion at your fastener points. I don't believe you could find or use Al bolts that could hold up to the load and stress of the road.
Althea68 is offline   Reply With Quote
Old 10-01-2010, 04:34 AM   #36
Boatdoc's stainless steel frame is well documented here:
http://www.airforums.com/forums/f36/...ame-29294.html
If the cost of stainless is excessive, I would consider building a galvanized steel frame as used in the European Airstreams. (Is this still not available in the USA?). When I built my 6 ton wooden sailing yacht in the 1970's, all the fittings were hot-dipped galvanized, and they are still corrosion free, after 35 years in a salt water environment. If the local galvanizing tank is too small for a full frame, I would construct the frame in small sections, just small enough to go in the tank. Put it together with galvanized bolts, with electrolytic insulation between the frame, bolts and aluminium shell, and it will outlast most of us.
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 10-01-2010, 04:44 AM   #37
Florida galvanizers
Further to my discussion above, I've checked with the American Galvanisers' Association, and there are three galvanizers with tanks (kettles in their parlance) that would take your complete frame. They are in Miami, Tampa, and Jacksonville, so you're spoilt for choice. Here's the link:
American Galvanizers Association
Nick.
Old 10-01-2010, 04:59 AM   #38
Considerations when hot-dip galvanizing
Here's a few points to consider when preparing steel for hot-dip galvanizing:
1. Any completely sealed sections must have sufficient access holes made so that air is not explosively trapped, and the zinc must coat all sides of the steel.
2. Any holes drilled after galvanizing will breach the protective coating, so these should be minimized. However, the electrolytic nature of the protective layer means that the zinc gradually erodes at any scratches or breaches, rather than the steel.
3. Heat distortion of the frame can occur because of the high temperature in the kettle. Be prepared to check for this, and be prepared for some imaginative use of hydraulic jacks and levers. I don't know how relevant this will be in an Airstream frame, but the European Airstreams are built this way.
4. The frame and shell can be separated with a dielectric gasket and or paste, such as zinc chromate. Bolts can pass through dielectric bushes, such as nylon.
5. The steel must be bare of all coatings before dipping. If in doubt, I get the galvanizer to shot-blast the steel. They usually offer that facility.
Nick
Old 10-01-2010, 12:04 PM   #39
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Thanks Nick for your input. However the original poster only posted 3 times on this website. All 3 being in this thread and all 3 being over 4 years ago.
I wonder if he is still in the info gathering process?
>>>>>>>>>>>>Action
Old 10-04-2010, 05:05 AM   #40
1968 20' Globetrotter
I am the original poster. Unfortunately, my Airstream project is being used as storage for some of my other projects. Which is ok for since my retirement/travel plans have changed, but now that the government has told us the recession was over....
Seriously, I appreciate the responses to my original post, and continue to dream. SkipS
skipnsb is offline   Reply With Quote
year frame size reduced yukonsilver Airstream History 1 04-19-2004 12:53 PM
Stripping paint off aluminum tin can luv General Interior Topics 4 04-18-2004 09:32 PM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 05:49 PM
