Old 11-06-2008, 09:13 AM   #1
1973 31' Sovereign
Help I am About to Put in New Flooring
I removed the carpet from my 1973 31ft Rear Bath sovereign and found a small rotten spot by the door (1" x 5") I was going to fill that with bondo auto body filler and sand. Will that work?
My big concern before I put down the flooring is that the plywood seam between the kitchen area and the bedroom does not meet cleanly. The bedroom piece seems to be free floating at the seam. Is it supposed to be this way and if not how do I fix. Can I put a threshold there and install flooring?
Thanks for any help
AustinAir is offline   Reply With Quote
Old 11-06-2008, 09:33 AM   #2
cameront120's Avatar
1972 25' Tradewind
A threshold would make the most sense if there is a seam that has any movement. That seam will transfer to the flooring and will be quite visible (assuming you're using a vinyl flooring of some description). As for the small rotten bit, once the leak is repaired, you could cut that bit of rotten plywood out and scab in a new piece. Fill any seams with a non-shrink wood filler.
North Vancouver, BC
Old 11-06-2008, 04:26 PM   #3
1973 31' Sovereign
My flooring guy way able to secure the piece of plywood with some wood screws and we chiseled out the bad wood and bono in the spot. The leak had already been fixed.
Thanks for everyone's help.
Old 11-06-2008, 06:18 PM   #4
vinstream's Avatar
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
FYI....Please do not use Bondo... It is great for filling the problem but I would try to find something that has more strength... Fiberglass or floor leveling compound with layers of mesh would be the way I would go... GOOD LUCK!!!
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
vinstream is offline   Reply With Quote
I put something in my oil? ArtStream Tow Vehicles 4 10-24-2007 11:22 AM
Where should one put a stereo? gergstuff All Argosy Trailers 11 06-14-2007 06:09 PM
Put me in a harness... bevman Batteries, Univolts, Converters & Inverters 10 04-02-2007 01:03 PM
Wasnt for sure of where to put this.... Angel73 General Interior Topics 15 05-05-2006 07:31 PM
And Now to put it back together. 59toaster Cabinets, Counter Tops & Furnishings 50 10-23-2005 06:56 AM
