Old 08-15-2015, 06:56 AM   #29
1978 Argosy Minuet 6.7 Metre
1971 27' Overlander
1973 31' Sovereign
Griffin , Georgia
Images: 14
I have an aluminum subfloor and no channels. I just put down 5/8" plywood and it made a big difference in the stability of the camper. I then treated the plywood with a waterproof sealer. After screwing the plywood down, I plan to treat it with the waterproof sealer again... Wait a few days. And install the new floor...
paddle whisp is offline   Reply With Quote
Old 08-16-2015, 07:49 PM   #30
1979 23' Safari
Wayland , New York
Originally Posted by AlbertaBound View Post
your c channel did not change so most rivet holes will line up. the ones that may change will be your front hold down plate. my holes lined up close enough that, with the larger 5/32 rivets, i reused the same holes.
Alberta bound, pretty ingenious routing the bottom of the floor instead of the top. WISH I'D THOUGHT OF THAT! Would keep all the skin/shell holes the same wrt the c channel except hold down plates and belly pans, which I have replaced all. I would have probably still had problems with the channels for the wheel wells.
marine plywood vs plywood vs osb bweldon Repairing/Replacing Floor &/or Frame 35 07-13-2015 06:29 AM
Help choosing subfloor plywood and protection method AtlasCoffee Repairing/Replacing Floor &/or Frame 30 06-16-2013 01:54 PM
Man-made subfloor? No Plywood please.... Zstream Repairing/Replacing Floor &/or Frame 25 08-17-2008 03:15 PM
Subfloor - Replacing Rotted Plywood traveller_nc Repairing/Replacing Floor &/or Frame 11 06-14-2007 10:00 PM
Plywood - How thick is the original? Marlboro Mafia Repairing/Replacing Floor &/or Frame 11 04-08-2004 10:09 AM
