Old 07-15-2015, 05:31 AM   #15
flygrrl
flygrrl's Avatar
1962 19' Globetrotter
Winchester , Ontario
No more rot
I am going to use a product called Densilite to replace my subfloor. It cuts and screws like wood but will never rot.
Densilite XP Plastic Sheet | Plastruct Polyzone - Polyzone Plastic Solutions
TV: 2007 Jeep GC Laredo diesel
Toy: 1995 Jeep YJ
Experience is what you get from not having it when you needed it.
flygrrl is offline   Reply With Quote
Old 07-15-2015, 11:37 AM   #16
59' Globester
twolanehwy's Avatar
1959 18' "Footer"
1957 26' Overlander
san francisco , California
Well I spoke to a rep regarding this product and it sounds like the real deal.
Solid core colors, a composit, non-composite which is paintable, waterproof, will hold threads, structural (besides vertical applications it will support weight comparable to plywood).
twolanehwy is offline   Reply With Quote
Old 07-15-2015, 11:49 AM   #17
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Sounds great. Price?
BambiTex is offline   Reply With Quote
Old 07-18-2015, 09:35 AM   #18
59' Globester
twolanehwy's Avatar
1959 18' "Footer"
1957 26' Overlander
I called most of the suppliers in US and it is unavailable. they are not able to keep up with demand.
Dealers tell me they don't get called back with pricing or availability.
I have gotten a couple of prices for 5/8" between $200 to $300 per sheet 4'x8'.
Old 07-25-2015, 04:52 AM   #19
tailchaser7's Avatar
1969 31' Sovereign
naples , Florida
Sub floors or cabinet woods
For anyone in Florida or the Carolina's area you absolutely should contact Wood Panel Products in Riviera Beach Fla and N.C. They have over 500 wood and laminate, plastic floor and cabinet products some that are 50-60% lighter than plywood and rot resistant. I am restoring a 69' Sovereign 31' and that's where I am getting all my exotic woods and laminate flooring to really trick this baby out.
tailchaser7 is offline   Reply With Quote
Old 07-28-2015, 09:40 PM   #20
AlbertaBound's Avatar
1975 Argosy 28
1975 Argosy 22
1978 Argosy Minuet 6.0 Metre
Camrose , Alberta
the original floor will be 1/2". I went with 5/8" to help with some flex between frame rails. It will require you to router out a groove where the outside wall channel fits as it has a 1/2" opening.
AlbertaBound is offline   Reply With Quote
Old 07-29-2015, 01:08 PM   #21
johnnywood's Avatar
1978 31' Sovereign
1968 24' Tradewind
Salem , Oregon
I was thinking about using 5/8" also. Can you elaborate on the "routing for the wall channel"? Are you talking about the c-channel?
Perhaps a drawing?
Thanks for your help
-johnny
johnnywood is offline   Reply With Quote
Old 07-29-2015, 04:43 PM   #22
Mission , Texas
My 75 Overlander has 3/4" plywood subfloor not notched or grooved.
nrgtrakr is offline   Reply With Quote
Old 08-01-2015, 10:19 AM   #23
1975 Argosy 28
1975 Argosy 22
Camrose , Alberta
i am talking about the c-channel. its not a true c channel so i don't feel comfortable calling it that. the opening is only 1/2 inch so you need to mill the plywood down an 1/8 inch to fit inside at the c channel. i cannot speak for all years but this was the case with mine.
Old 08-02-2015, 10:55 AM   #24
1987 32' Excella
1999 33' Land Yacht
Clear Lake , Minnesota
I simply used a hand router to remove the excess from the edge to be inserted into the channel and then once in place used Duram Rock Hard Putty to level out the finished surface.
Devananda-E9 is offline   Reply With Quote
Old 08-03-2015, 05:33 PM   #25
1979 23' Safari
Wayland , New York
I used 15/32" in my floor. Replaced original size. Really isn't much flex between the frames since there are cross and longitudinal supports under there.
Thing I wished I'd done is put down a bead of polyurethane or something else on top of the frame and other rails to prevent squeaks. The original fiberglass sandwiched in there did this function.
Keep in mind you'll need a little gap on the inside of the channel for the old interior wall sheet metal to fit down into. Attachment points to walls will be shifted up meaning new holes since the shell will be same height, but everything inside will be lifted by difference between old and new floor thickness.
Old 08-12-2015, 04:36 PM   #26
1966 24' Tradewind
Kansas City , Missouri
Originally Posted by Belegedhel View Post
Did you measure the original material? It is pretty critical that you match the original, otherwise the rivets in the front hold-down plate won't match up with the rivet holes in the shell.
I have a '66 Tradewind with a 5/8" plywood subfloor. I'm thinking that if I replace it with 3/4" that I can modify or replace the front hold-down plate and there looks to be enough slop in the c channel sides to allow for new rivet holes, but is there a cascading effect brought about by the 1/8" difference in floor thickness, e.g., relationship of the shell to the banana wrap, wheel wells, etc?
Slats is offline   Reply With Quote
Old 08-14-2015, 09:56 PM   #27
1975 Argosy 28
1975 Argosy 22
Camrose , Alberta
your c channel did not change so most rivet holes will line up. the ones that may change will be your front hold down plate. my holes lined up close enough that, with the larger 5/32 rivets, i reused the same holes.
Name:	frame cross section.png
Old 08-15-2015, 06:39 AM   #28
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
I'm not sure how the c channel is configured on your trailer, but yes you are right, wheel wells, banana wraps will all be slightly off.
marine plywood vs plywood vs osb bweldon Repairing/Replacing Floor &/or Frame 35 07-13-2015 06:29 AM
Help choosing subfloor plywood and protection method AtlasCoffee Repairing/Replacing Floor &/or Frame 30 06-16-2013 01:54 PM
Man-made subfloor? No Plywood please.... Zstream Repairing/Replacing Floor &/or Frame 25 08-17-2008 03:15 PM
Subfloor - Replacing Rotted Plywood traveller_nc Repairing/Replacing Floor &/or Frame 11 06-14-2007 10:00 PM
Plywood - How thick is the original? Marlboro Mafia Repairing/Replacing Floor &/or Frame 11 04-08-2004 10:09 AM
