Old 07-12-2015, 01:50 PM   #1
1978 Argosy Minuet 6.7 Metre
1971 27' Overlander
1973 31' Sovereign
Griffin , Georgia
Images: 14
HELP?? how thick should plywood subfloor be?
I'm about to turn the corner, from gutting to remodel on my '78 Argosy Airstream. All furnishings and cabinets have been removed. How thick should the plywood subfloor be?
paddle whisp is offline   Reply With Quote
Old 07-12-2015, 02:07 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Personally if I was going to all that trouble and expense I would use a 1/2 inch composite material. Never have to worry about rot again.
MICHAEL
Old 07-12-2015, 04:05 PM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Did you measure the original material? It is pretty critical that you match the original, otherwise the rivets in the front hold-down plate won't match up with the rivet holes in the shell.
Old 07-12-2015, 08:58 PM   #4
1979 23' Safari
Wayland , New York
You need to check the original thickness. My '74 has 3/4, my '79 has 15/32". Need to match especially if c Chanel has wrap around plywood edge. Also so hold down plate holes will match, although you can replace the hold down plate to use a thicker floor. I had to replace mine because of corrosion.
Old 07-13-2015, 07:57 AM   #5
Belegedhel's Avatar
Houston , Texas
My '73 AS had 3/4", but it was a seriously tight fight getting it back into the wrap-around C-channels. I had ordered brand new C-channels as mine were corroded, but the new ones, despite being for 70's era trailers, had a mouth that was too small to accommodate the 3/4" flooring, so I had to use the old stuff. You might be able to get an indication of the thickness of the original floor by seeing what can be squeezed into your C-channels or, if the shell is still on the frame, you might have a chance of measuring the distance from the undersid of the front C-channels to the frame, in the vicinity of the front hold-down plate.
good luck!
Old 07-13-2015, 10:33 AM   #6
59' Globester
twolanehwy's Avatar
1959 18' "Footer"
1957 26' Overlander
Three Rivers , California
what type of composite?
twolanehwy is offline   Reply With Quote
Old 07-13-2015, 12:34 PM   #7
1972 27' Overlander
Sioux City , Iowa
I always thought if I had to do a shell off floor replacement I'd use that white plastic cutting board material, available in 4x8 sheets and most any thickness.
sdsmarts is offline   Reply With Quote
Old 07-13-2015, 12:42 PM   #8
1973 25' Tradewind
Beautiful , Oregon
In order to get full 3/4 inch ply ( if that is what you are matching up to something else) I used marine grade fir. All others were less than 3/4". If not matching to something you might be ahead of the game, as previously mentioned to go with regular fir which will be less than generic call out.
Tony
Tony S is offline   Reply With Quote
Old 07-13-2015, 01:50 PM   #9
1998 31' Excella 1000
Clear Lake , Minnesota
Wish I had known
I recently had to replace bedroom floor in 87 Excella 32 and went looking for such but no one seemed to know if it even existed. The best they could offer was marine grade plywood, which they did not stock. I was appalled to discover that AS used particle board and then sabotaged it by creating openings in the perimeter belting which let the rain water just pore in. I ended up just using ACX plywood which I sealed with a brush applied minwax polyurethane product and hoped my searching out and filling with a high-end calking product ($17.90/tube) the leaking entry points will be successful. I found two major entry points under a port door hinge an opening the length of the hinge 1/8 in wide as well as entry from the utility tray under the rear bumper. That is not a job I want to do again.
Devananda-E9 is offline   Reply With Quote
Old 07-13-2015, 02:39 PM   #10
SuzyHomemakr's Avatar
1972 29' Ambassador
Boynton Beach , Florida
3/4" Eurolite marine ply from World Panel in Riviera Beach, FL!
SuzyHomemakr is offline   Reply With Quote
Old 07-13-2015, 07:03 PM   #11
1978 31' Excella 500
Huntington Beach , California
Wow, I need to repair around the Toliet. Might have to inspect further!
Jerry Ski is offline   Reply With Quote
Old 07-13-2015, 08:04 PM   #12
Slats's Avatar
1966 24' Tradewind
Kansas City , Missouri
Anyone used this stuff?
NyloSheet | Composite Sheets, Lightweight Boat Panels
Slats is offline   Reply With Quote
Old 07-14-2015, 04:26 PM   #13
1988 34' Excella
Stanardsville , Virginia
I've used the nylo board to replace rotted floor in our AS "Maxime" and it is working very well. It came in 5/8 thickness and is very strong and totally waterproof. Don't want to have to touch that section of floor ever again. Someone on the forum said that it smells but we can't detect any smell at all.
madpiper is offline   Reply With Quote
Old 07-15-2015, 12:13 AM   #14
59' Globester
twolanehwy's Avatar
1959 18' "Footer"
1957 26' Overlander
Originally Posted by Slats View Post
I'm going to look into that for a complete floor. I'm doing a body off next year.
Reinforce the frame, sandblast and powder coat. That would be nice if it can be used as a floor product.
My other concern is adhesion of tiles to it. It does say "painy ready" so if paint sticks so should tile adhesive.
Old 07-15-2015, 05:31 AM   #15
flygrrl
flygrrl's Avatar
1962 19' Globetrotter
Winchester , Ontario
No more rot
I am going to use a product called Densilite to replace my subfloor. It cuts and screws like wood but will never rot.
Densilite XP Plastic Sheet | Plastruct Polyzone - Polyzone Plastic Solutions
TV: 2007 Jeep GC Laredo diesel
Toy: 1995 Jeep YJ
Experience is what you get from not having it when you needed it.
flygrrl is offline   Reply With Quote
Old 07-15-2015, 11:37 AM   #16
59' Globester
twolanehwy's Avatar
1959 18' "Footer"
1957 26' Overlander
Well I spoke to a rep regarding this product and it sounds like the real deal.
Solid core colors, a composit, non-composite which is paintable, waterproof, will hold threads, structural (besides vertical applications it will support weight comparable to plywood).
Old 07-15-2015, 11:49 AM   #17
1955 22' Safari
Laredo , Texas
Sounds great. Price?
55AS is offline   Reply With Quote
Old 07-18-2015, 09:35 AM   #18
59' Globester
twolanehwy's Avatar
1959 18' "Footer"
1957 26' Overlander
I called most of the suppliers in US and it is unavailable. they are not able to keep up with demand.
Dealers tell me they don't get called back with pricing or availability.
I have gotten a couple of prices for 5/8" between $200 to $300 per sheet 4'x8'.
Old 07-25-2015, 04:52 AM   #19
NAPLES , Florida
Sub floors or cabinet woods
For anyone in Florida or the Carolina's area you absolutely should contact Wood Panel Products in Riviera Beach Fla and N.C. They have over 500 wood and laminate, plastic floor and cabinet products some that are 50-60% lighter than plywood and rot resistant. I am restoring a 69' Sovereign 31' and that's where I am getting all my exotic woods and laminate flooring to really trick this baby out.
tailchaser7 is offline   Reply With Quote
Old 07-28-2015, 09:40 PM   #20
AlbertaBound's Avatar
1975 Argosy 28
1975 Argosy 22
1978 Argosy Minuet 6.0 Metre
Camrose , Alberta
the original floor will be 1/2". I went with 5/8" to help with some flex between frame rails. It will require you to router out a groove where the outside wall channel fits as it has a 1/2" opening.
AlbertaBound is offline   Reply With Quote
marine plywood vs plywood vs osb bweldon Repairing/Replacing Floor &/or Frame 35 07-13-2015 06:29 AM
Help choosing subfloor plywood and protection method AtlasCoffee Repairing/Replacing Floor &/or Frame 30 06-16-2013 01:54 PM
Man-made subfloor? No Plywood please.... Zstream Repairing/Replacing Floor &/or Frame 25 08-17-2008 03:15 PM
Subfloor - Replacing Rotted Plywood traveller_nc Repairing/Replacing Floor &/or Frame 11 06-14-2007 10:00 PM
Plywood - How thick is the original? Marlboro Mafia Repairing/Replacing Floor &/or Frame 11 04-08-2004 10:09 AM
