12-11-2013, 07:10 PM
#41
1981 31' Excella II
New Market
, Alabama
I would pull the belly skins and see what you have to work with. I expect that the worst of the rust is concentrated in the front A-Frame and the rear bumper area. Rear end rot is common are a result of some design issues. You probably have rear end floor rot under bed (s) in the rear. I think the A-frame can be fixed relatively easily. The worst of the rot is in the corner. If you cut all the bad stuff out and get some new steel and cut it to fit the missing areas and a welder can put it back together. It won't hurt to add some gussets to make it a little stronger. Now you can pull it to a place where you can finish the R&R. Without the skins in the way you can see what you have to work with. The fiberglass insulation gets water logged and really increases the frame rot.
Perry
12-12-2013, 05:13 AM
#42
1966 17' Caravel
Newport
, North Carolina
I agree with dropping the belly pan and doing the patch repair! You can do this!
Cliff
Gotta get busy! Have a great day! Now where did I put those revits?
12-12-2013, 05:51 AM
#43
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Too far down the road for an objective opinion here.....I would turn it loose.
Do you want to use it or work on it?
If time is not a concern, spend some more of it on a thorough stem to stern bottoms up inspection.
Anything can be restored with $$$ & effort.
Your TV has most likely accelerated the frame separation.
"About My Tow Vehicle
1996 Ford F-350 XLT 7.3L DRW"....pretty stiff.
Good Luck...
12-12-2013, 08:41 AM
#44
1986 34' Excella
West Palm Beach
Hey all,
Will be out and about today, going to pick up steel plates and several bolts, and plan on tackling the inspection and temp repair tomorrow and will be sure to document the process in this thread.
Thanks for the support, everyone!
12-12-2013, 09:21 AM
#45
1981 31' Excella II
New Market
, Alabama
It does not look like he is using a load distributing hitch. I think using one will put more stress on an already weak frame. What sort of hitch arrangement do you have?
Perry
12-12-2013, 10:07 AM
#46
1986 34' Excella
West Palm Beach
Perry
I've got a Reese hitch with 1200lbs. spring bars in stirrups.
12-12-2013, 02:21 PM
#47
1967 26' Overlander
Huntsville
, Alabama
That setup will crack a new frame
Originally Posted by DmcrtcTrvlrs
...1996 Ford F-350 XLT 7.3L DRW...
Wow - that'sa really stiff setup!
If you are interested, a little more insight into spring bars can be found at this link:
Tuning a Reese Hitch
While the author appears to have an uncanny insight into the topic, his writing style is boring as all get-out. Try to stay awake till the end.
But good points are made.
Tom
12-12-2013, 03:02 PM
#48
1986 34' Excella
West Palm Beach
Tom
Yeah, I'm just learning now that I need to drop down to probably 600# bars after some discussion with other folks over email. Will probably leave them off until a permanent fix is in place.
12-12-2013, 04:13 PM
#49
What grade bolts/nuts and lock washers did you get?
Enjoy,
Paul Waddell
12-12-2013, 04:17 PM
#50
1972 Travelux Princess 25
Cobourg
, Ontario
How big a trailer? Unless it's a 34 foot you may not need any spring bars at all.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
12-12-2013, 04:44 PM
#51
1981 31' Excella II
New Market
, Alabama
It is a 34 and he is pulling it with an F-350 Diesel so he might be better off structurally leaving them off. The truck can handle the load I am sure. I am worried about the frame more than the truck. I would think a thick walled 2x2 box beam welded across the bottom would hold it together for a while.
Where are you going to pull the trailer to? You are in West Palm now?
Perry
12-13-2013, 12:47 PM
#52
1986 34' Excella
West Palm Beach
Hey gang,
Quick update. Pulled the corner banana wrap off and got a better look at the area:
We went to a steel fabrication place and the welder I've been talking with over the phone is putting together a 1/4" thick, 18" long U-channel that will wrap around the whole area. He recommended keeping the number of holes drilled to a minimum, so we decided on two 1/2", Grade 8 bolts to go all the way through both sides of the U-channel/beam unit. We also picked up a proper drill bit for the job, some washers, and locking nuts. I also plan to throw on some Loc-Tite for good measure. Altogether, about $82.
My plan is to slide the U-channel into place, and then put two jack stands under either end of it, and one on the other side of the A-frame. Then take some of the weight off the tongue jack so that the weight of the trailer starts to push the A-frame flush against its new splint. The U-channel will have the holes already drilled when I get it back from the shop, so I'll then drill through the frame, using the U-channel as a pilot. I'll bolt it up while it's still on the jack stands, and then hopefully that will be it. Thoughts?
Thanks again for all the advice and support - classic AirForums. I'll post pictures as soon as I get the U-channel from the shop, but it might not be until Monday.
12-13-2013, 01:18 PM
#53
1977 23' Safari
Niagara on the Lake
, Ontario
I would use at least 4 bolts - 2 on either side of the crack.
The channel is a good start but you need to tie the repair in to the front cross member.
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2022 Toyota 4Runner SR5
12-13-2013, 02:57 PM
#54
Moderator dude
1966 26' Overlander
Phoenix
I would take the trailer bolted with the repair and have the repair welded with a weld connecting the new U-channel repair to the cross channel. Spreading out the the load of the repair in other directions will create greater stability in the trailer.
While you are waiting for the repair piece ...... clean up the existing frame sections and coat them. POR 15 would be a good solution. Bolted, welded no matter what your solution stopping the corrosion from spreading to the new patch is smart.
Stop Rust with POR-15® - We Know What Permanent Means!
>>>>>>>>>>>>Action
12-13-2013, 05:33 PM
#55
Cobourg
, Ontario
That looks nasty. I don't know if you have enough good metal to bolt the reinforcements to.
You need to be careful bolting to a hollow box like that. When you tighten the bolts they squeeze or collapse the box and never get tight. That is if you use long bolts that go all the way through.
You need to use short bolts that just go through the metal. To do this you need a hole or some way to get the bolts inside the box. Trailer hitches come with a wire gadget that pulls the bolts thru the hole.
12-13-2013, 06:27 PM
#56
1981 31' Excella II
New Market
, Alabama
It looks like it is confined to a relatively small area. Chip the majority of it off and then wire brush it. A cup brush on an angle grinder works well for this. I agree with AldeanFan. You need at least two bolts on each side of the crack in order for it to do anything. Otherwise it is just a hinge. Take it from a rocket scientist. I would POR15 it before you make the final repairs. Also POR15 inside the frame members. You might want to wash everything with baking soda first to get that acid neutralized. Keep in mind that with very stiff tow vehicle suspension and heavy load bars even a good frame will take a beating and the connection between the shell and frame will suffer. Considering all the miles you put on the old girl and the years of neglect she held up pretty well.
Perry
12-14-2013, 03:36 PM
#57
1986 34' Excella
West Palm Beach
Perry
Yeah, I'm going to upgrade to two bolts on each side of the crack. I'll have the welder make sure to pre-drill the holes where I know the bolts won't be going through heavily corroded areas of the beam.
12-14-2013, 04:11 PM
#58
1981 31' Excella II
New Market
, Alabama
U bolts would be a good idea. U can get them at McMaster.com
Perry
12-14-2013, 06:57 PM
#59
1986 34' Excella
West Palm Beach
Perry
In what configuration?
12-14-2013, 08:07 PM
#60
1981 31' Excella II
New Market
, Alabama
If you can find the right size you can use them to hold the channel to the frame. You would need a plate with two holes in it on the top for the U-bolt to fit into and the U-bolt would wrap around the channel and hold it to the frame.
http://www.mcmaster.com/#u-bolts/=pt8n5q
Look at the square U-bolts. If you wanted to do some fab the welder could put some ears on the channel for the u-bolt to attach to.
Perry
