Old 05-13-2013, 10:25 PM   #15
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Atlascoffee.. have you read this post?
http://www.airforums.com/forums/f36/...al-104474.html
Mcdenny... any thoughts on using the product in the above post?
Peace and Blessings..
Channing
WBCCI# 30676
Old 05-13-2013, 11:02 PM   #16
Kyle401's Avatar
1969 27' Overlander
SW , Missouri
If the waters aren't already murky enough, have you considered AdvanTech?
Kyle401 is offline   Reply With Quote
Old 05-13-2013, 11:15 PM   #17
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
That's what I used in my Bambi II project. A friend used it as a cover for his firepit outside for a year & it looks just fine. I figured that was good enough for me! It has a 50 year warranty & I'll be long gone by then! I'm sure there is controversy over it as well.
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 05-13-2013, 11:34 PM   #18
Kyle401's Avatar
1969 27' Overlander
SW , Missouri
I used AdvanTech for my Overlander as well. I have an 18"x18" scrap of it that I decided to put under firewood when splitting. It held up great until I missed with the maul a couple times (OK more than a couple.) Even now with the cuts from the maul, it hasn't broken. I leave it outside on top of the wood pile.
Old 05-14-2013, 08:07 AM   #19
Marine city , Michigan
Regarding the Thermo-Light "tough" board referenced above:
3/4 4x8 sheet weighs 52 lbs, costs $195 plus freight (ball park $200-$250 for a few (several?) sheets). Strength (they cite flexure modulus 407 kPSI)
18mm Hydrotech plywood weighs 72 lbs, costs $120, available at specialty lumberyards (I.e., no freight charge). Strength (bending modulus of Mertanti, I'm pretty sure it's the same as flexure modulus) 1,700 kPSI.
Adding epoxy to the wood adds maybe 5 lbs and $30 and a lot of work, at least a couple of hours per sheet, perhaps more.
My take, wood is half the price, 4x the strength and a lot more work (because of the need for epoxy) and a lot easier to get.
A relevant question is how strong does the floor need to be. That depends on the frame support spacing and your tolerance for a "springy" floor. I have no idea how important the floor strength is to the overall trailer shell strength.
Denny Wolfe
www.wanderingourway.wordpress.com
Mcdenny is offline   Reply With Quote
Old 05-14-2013, 08:25 AM   #20
I looked this up too. The co website is long on praise and short on hard data but it does say "not for exterior use", it is heavier than plywood, and about 30% stronger. I didn't see any cost data.
It looks like a premium brand of OSB. That's wood chips glued together, just like particle board is sawdust glued together.
These products have their place, particularly where low cost is important. The little bit of this stuff (not Advantech brand) I have used suggests it is much heavier and not as strong, certainly for its weight, as real wood.
Even if these products are made with water proof glue, as soon as you cut it you have unprotected wood exposed and need to epoxy or paint the cut edge to keep out water.
Denny Wolfe
Old 05-14-2013, 09:40 AM   #21
Mixter's Avatar
1976 27' Overlander
I'm at this same stage too. I went with Marine Ply for $57 bucks each. I've been debating over what to do now.... I do see the point mentioned that my AS is nearly 40 years old so whatever I do should last a long time, BUT my floor is rotton.... AND I would imagine that my floor was rotting for many years based on what it looked like. I dont want that to happen... stinky mildew wood- even once doesnt sound good.
I like the idea of a "penetrating" sealer VS a topcoated Kilz primer or comparable, but not sure which one yet. I've considered something like Rot Doctor, but that stuff is expensive. Although the majority of my rot was in the edges, it does not neccessarily "the perimeter" of the coach. The water damage extended across the coach on the edge attached to the cross members. Therefore, I'd be treating ALL the edges... I'd bet I would use a good 2 gallons which would be $200. I would still probably want to at least prime the middles of of each piece too...
I ran into this product at the industrial adhesives distributor I've been buying my Vulkem from... This has definitely intrigued me... The only down side I can think of is that I dont think anything would stick to it once its treated. i.e. stick down flooring, primer, paint, adhesives, etc. Not sure that's a problem for me, because I think I'm going to ultimately be using a nail down 3/8" real wood flooring, OR a floating Pergo- type flooring. The other thing I was going to do, is use industrial adhesive to attache foam board to the bottoms of the subfloor for insulation, but not sure I need insulation or not- there are many different schools of thought there. If I really want to insulate, I can use fasteners and attach to the frame under the flooring. I guess I would have also liked to see a nice painted wood sub floor when I open the truck and side hatches, I guess I can live with just bare wood if I know it is extremely water repellent.
This stuff was $40 / gallon and has a mineral spirits base. It is breathable, and completely repels water. The guy did a demo for me, and the wood stays completely dry- even in the middle of a Florida downpour- just beads right up.
I can lay out my wood and just spray it down with a little $14 Roundup, chemical resistant garden sprayer from Lowes. Application should be quick and easy.... no other treatments/ paints, etc. I think I can do BOTH sides with 2 gallons. Also, since it should penetrate through my 1/2" ply, any holes I drill will already be sealed.
Awfully tempting... and I pretty certain its the way I'm going to go. Havent seen anyone else in the AForums speak of it, so interested to see if anyone has any experience with it.
I'll be watching!
Mic
Mixter is offline   Reply With Quote
Old 05-14-2013, 10:09 AM   #22
I'll be watching!
Mic
Again, a cheap and easy method to prevent rot has been the quest of wooden boat builders since Noah. Epoxy is the best, most expensive and most laborious way. It has a proven track record with now 40 year old boats. Lesser methods will have lesser results. What level of protection is good enough for you? Only you can answer. Probably the original floor had no rot protection at all and was thought "good enough" by the airstream factory.
If you want epoxy get real coating epoxy meant for boat building. Its better and cheaper than the general consumer products like Rot Doctor. You want 100% solids epoxy, zero solvents, which means it is pretty thick at 70 F, thinner than honey but thicker than olive oil. Things meant to penetrate rot are usually much thinner so they soak into the wood and are made thinner by mixing in solvents. The best product if you want to paint on thin epoxy is Smiths Clear Penetrating Epoxy Sealer. Used as primer by many boat builders; smells awful, I'd only use it outside on a windy day.
BTW: Nothing penetrates the flat grain of wood more than several .001". the end grain will suck it up maybe a 1/4" or a 1/2". Advertising claims that say "penetrating" never say how deep.
Denny Wolfe
Old 05-14-2013, 10:55 AM   #23
Central , Mississippi
I went the same direction as McDenny talks about, using a good grade of plywood and coating with RAKA epoxy. 3 gallons were more than enough and cost less than a local sheet of marine grade ply.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 05-14-2013, 05:27 PM   #24
AtlasCoffee's Avatar
1965 24' Tradewind
Pleasant Ridge , Michigan
I think I'm going this route too. Frame repair is this week so I have a few days to make a decision.
Thanks everyone for your input!
AtlasCoffee is offline   Reply With Quote
Old 05-14-2013, 10:38 PM   #25
Jewel65's Avatar
1965 17' Caravel
1965 17' Caravel
Memphis , Tennessee
Images: 21
For the coating I am using an oil base floor paint from Lowes at about $16/gal. It is called All Purpose Floor and Utility Paint. I used it on the wooden floor of my shed and it has held up well, so I am using it on the airstream. It is about the same gray color as Trempro and the oil base penetrates the wood grain well. I am painting all sides and the edges with 2 or more coats. I think it will last well.
1965 Airstream Caravel, 2003 Ford F150 SuperCrew, 2003 Miata Special Edition, 1993 Miata Black & Tan
Jewel65 is offline   Reply With Quote
Old 05-14-2013, 10:55 PM   #26
Maniacal Engineer
barts's Avatar
Menlo Park , California
We used regular 3/4" A/C construction plywood when patching our floor, and covered the old and new plywood with epoxyproducts.com "no blush" epoxy (3 coats IIRC). The first coat was thinned 10% w/ xylene to sink better into the water affected (but not completely rotted) areas.
We painted the epoxy with Aluthane, a moisture cure aluminum filled polyurethane paint by the same folks. This has worked very well, and we just use rugs over this. Note that this lets us find any leaks or other issues very easily.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 06-13-2013, 08:12 AM   #27
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
When we replaced the back 4 feet of our AS we used marine Grade 3/4 ply. It was about $75k, and we top coated it with fiberglass resin. We fully coverred the top, and then coated about 1 foot around edges on the bottom. The rest of the floor we primed with oil killiz and toped with a oil based floor paint. It came out pretty nice. I walked on it to soon, so there is a few off spots. I we have a floating floor to go on top, so not a big deal. The goal was to seal it up as well as possible.
Silverflames is offline   Reply With Quote
Old 06-13-2013, 08:29 AM   #28
1981 31' Excella II
New Market , Alabama
Where do you get real marine plywood?
Perry
Originally Posted by Mcdenny View Post
Hi, just joined the forum, been lurking for awhile.
I'm a wooden boat builder and have used a lot of plywood. Most all plywood has water proof glue. "Marine" plywood just refers to a higher manufacturing standard usually, few or no voids in the interior plies and equal thickness plies. Lesser ply will have paper thin face plies. Doug fir is heavy, strong, moderately durable and miserable splintery stuff to work with. I never use it in boats. Better options are Meranti or Okoume plywood. Meranti is 25% heavier than Okoume, more durable and half the price. Okoume is mostly used where strength and light weight is wanted, like a kayak. Both woods look like mahogany. Meranti is sold under the trade names Hydrotech and Aquatech. Either would be good for the floor.
Meranti is a bit lighter than DF and about the same price.
All the wood will eventually rot if not protected from moisture. Modern wooden boats (since the 1970s) have all the pieces coated with two or three applications of epoxy. (I get mine on line from RAKA).
If I were doing all that work, I'd use Meranti, cut all the pieces to their finished shapes, then put two coats on each side while coating the edges each time so the edges end up with four coats. If you later cut holes in the floor put a couple of coats on epoxy on the newly exposed wood.
Also note that plywood isn't usually exactly the thickness it's sold as. American ply is often 1/32 or 1/16 thinner than its 'size'. 1/2" ply is usually really 15/32". Exotic specie like Meranti or Okoume are made to metric dimensions but often sold as an inch dimension. There what is called 1/2" is really 12 mm. Don't know if this matters in a floor replacement.
Atlas, I see you are in the Detroit area. Public Lumber at Seven Mile and I75 carries Hydrotech. You can get WEST brand epoxy at West Marine at Nine and Jefferson. It's good stuff but 2x the RAKA price. It's all pretty much the same stuff in the jug.
