Old 05-09-2009, 12:18 PM   #15
CrzyCorpsman's Avatar
1975 31' Sovereign
Biloxi , Mississippi
Shell Bracing - Take 2
Well, after a month's vacation from working on the Airstream it's time to get started back up again. I've since removed the bracing that I had in place, taking the advice from the ones above. I've got one set of the 4x4's in, but instead of bolting everything down, I just wanted to get your guy's take on my new bracing.
Here's a look with everything almost out. I left the diagonal braces in, but took out the ones going from wall to wall
Here you will see I've got the 4x4's down and using the best connector that I could find at my local hardware store (hurricane connectors), this is what I'll use to connect the "crossmembers" to the 4x4's
So if I do this on each brace and each side, should it be enough to hold everything together??
Just wanted to get your thoughts before I proceed further.
Thanks a bunch!!
Brian Schmock
'75 31ft Airstream Sovereign
Come check out my restoration progress:
http://crazycorpsman-silverbullet.blogspot.com/
CrzyCorpsman is offline   Reply With Quote
Old 05-09-2009, 02:57 PM   #16
Ambie '64's Avatar
1964 28' Ambassador
Oklahoma City , Oklahoma
Hey Brian, looks like you got a hold of fun one. I'm hardly an expert, not even a structural engineer, but I'd use some more steel connectors at the wood to wood joints. Nails won't hold over a long period of time that it might be in the air. Also, the Simpson PC-44 needs a few more nails in the holes (one ain''t gonna cut it). I used Simpson ST strap ties and A-35's to hold the pieces together. The last thing you want is to get it in the air and it starts to rack on you (one side goes forward while the other side goes rearward). One other thing is you might consider a triple point bracing to keep the top rigid. I lifted the 28' Ambassador off the subfloor by myself using jack stands and a floor jack. You might place some plywood across your frame to do what I show in the photos below.
Name:	A-S 4-1 Front end.jpg
ID:	79966   Click image for larger version
Name:	A-S 4-1 more bracing.jpg
Name:	A-S 4-1 Old Jackstands still work.jpg
ID:	79968   Click image for larger version
Name:	Brace Yourself.jpg
Ambie '64 is offline   Reply With Quote
Old 05-09-2009, 07:00 PM   #17
Overlander & Sea's Avatar
Gulfport , Mississippi
Images: 30
Brian,
I don't know a thing about pulling the shell off & bracing it, but would like to come check it out & learn. Your progress looks great.
Rick--Airstream of Mississippi www.foleyrvcenter.com
WBCCI #9275 TAC #MS-5 AIR #11800
Overlander & Sea is offline   Reply With Quote
27-28 advice needed seeleylaker On The Road... 1 12-10-2008 11:01 PM
Advice needed on a 1999 BLACK Chevy Suburban, K1500 XpeditionsTV Tow Vehicles 16 10-02-2007 09:34 PM
total floor replacement/shell removal durans54 Repairing/Replacing Floor &/or Frame 6 05-05-2006 01:22 AM
Toilet removal advice requested Lockwasher Sinks, Showers & Toilets 5 11-14-2004 08:43 AM
shell removal... nevisstudio Ribs, Skins & Rivets 2 01-27-2004 11:08 AM
