Old 04-28-2017, 08:51 PM   #1
Grand Island , Arizona
Hardware/insulation
I've been doing a lot of research on this subject but haven't found a recent answer. What type of insulation goes under the floor. And what hardware do you use to hold the floorboards down? Old hardware heads are are large flat machine screws.
bugssmith is offline   Reply With Quote
Old 04-29-2017, 10:24 PM   #2
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
Use elevator bolts and FOAMULAR Extruded Polystyrene (XPS ) Rigid Foam Insulation. Fastenal or vintage trailer supply has the bolts and the box stores carry the insulation. I used 2 inch foam with 2 1/2 inch screws with fender washers to attach.
Matt
rugjenkins is online now   Reply With Quote
Old 04-30-2017, 06:04 AM   #3
Thanks for the info. Did you double up on the insulation? The frame cavity is 3-4" deep. Also, did you use that insulation on the walls? We are debating that or Reflectix.
Old 04-30-2017, 07:28 PM   #4
rugjenkins's Avatar
1975 Argosy 28
1 layer is good in the belly pan. The foamular insulation is not cheap besides the walls are only 2in max. For the walls, I did spray insulation. It's a personal choice so research the options and go with the one you like.
Matt
Old 05-01-2017, 05:08 AM   #5
Thank you, it's appreciated.
Insulation- Prodex or Foam Insulation Board? Danny Z General Interior Topics 7 08-26-2015 08:21 PM
Does old fiberglass insulation equal new fiberglass insulation? Petethefeet General Interior Topics 7 11-14-2010 12:16 PM
Sliding Cabinet Hardware LKappenman Cabinets, Counter Tops & Furnishings 5 10-20-2002 04:53 PM
Rusted through hardware on step - source? casarodante Steps 7 07-01-2002 10:48 AM
