Old 04-20-2013, 05:44 AM   #1
1967 17' Caravel
georgetown , Texas
Gutted '67 Caravel - laminate questions
I have a gutted 67 Caravel and am almost done with the subfloor.
I was most likely use trafficmaster allure laminate strips or tiles.
Should I tile the entire subfloor?
Or can i get away with just the parts i walk on? Is there a need to tile under the fresh water tank and gaucho? Seems like i could buy half as much tile if i just tile the middle area that is walked on.
Thanks!
knishiya is offline   Reply With Quote
Old 04-20-2013, 07:05 AM   #2
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
There isn't a real need to tile under everything. It's a lot EASIER to tile under everything because everything will be sitting on top of the flooring rather than having to trim your flooring around it. I tiled under everything in my Bambi II (same size as your Caravel) and have--oh--about 2' of flooring showing. But it was very easy to install. It's really your call!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 04-20-2013, 08:14 AM   #3
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
I did carpet in mine. I left the floor bare under the cabinets, etc. I'm glad I did because it's easy to spot and dry out leaks.
Stephanie
Old 08-16-2013, 04:06 AM   #4
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
Okay I have searched all of your threads and have not found any pictures so please give us a peek of your prize? Just like to see how it looks now thank you
Cliff
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 08-20-2013, 12:38 AM   #5
1967 17' Caravel
georgetown , Texas
As you know, these projects keep getting pushed back. Two jobs, Two kids and a move to California have eaten up all of time. I havent started back on my caravel yet. I got the subfloor in, had an electrician rewire the thing and thats it. No flooring yet.
But my plans are: Im going to leave what is under the bed, gaucho and furniture plain subfloor. Really no need. Im not camping in cold weather, no need for the insulation. I like what one poster said about being able to see water penetrations with bare floor. Easier to spot issue.
So i will only have to floor a small area maybe 5ft by 5ft. I will probably go to home depot or lowes and buy some of the thicker trafficmaster stick on planks. It will be easy to clean and easy to replace if needed.
caravel
Caravel :: 1967 Airstream Caravel youngestmeyn Airstream Registry Discussions 0 11-29-2011 09:31 AM
Caravel :: 1967 Airstream Caravel C Johnson Airstream Registry Discussions 0 08-19-2011 08:31 AM
Toilet over laminate? willbrackman Floor Finishes 0 07-11-2011 12:31 PM
67 Caravel Help: to sway or not to sway vonzellen Hitches, Couplers & Balls 15 01-26-2011 05:07 PM
