Old 09-12-2015, 11:36 AM   #1
1976 31' Sovereign
Utica , Ohio
Question Getting ready for lift off of shell on 1977 31ft
I have most of the rivets out and then I will remove anchor bolts. The plan is to replace the floor. Thanks to the forum I have gotten this far. I have my gantries built and am a little confused on what I should use inside the trailer to lift against the shell and the amount of bracing that should be used. I have read various methods would like to see pictures if you have along with description of method used. Thanks
SILVER BEE is offline   Reply With Quote
Old 09-12-2015, 05:26 PM   #2
truckasaurus's Avatar
1960 33' Custom
Athens , Georgia
I used an aluminum ladder today to brace the shell for lifting. It was an extension type so I split it and used half at each end of the trailer. It's my new fave technique.
truckasaurus is offline   Reply With Quote
Old 09-12-2015, 05:57 PM   #3
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
Any idea how the factory did it?
NavyCorpsman is offline   Reply With Quote
Old 09-12-2015, 09:42 PM   #4
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
I used a 2x6 extended past the vents with a rope tied to either end. No extra bracing. Sorry no pics.
Matt
rugjenkins is offline   Reply With Quote
Old 09-13-2015, 07:08 AM   #5
1972 25' Tradewind
fort lauderdale , Florida
My gantries were placed directly over my forward and aft vents.
I cut 2 4x4's long enough to span the closet she'll ribs, fore and aft of each vent.
Wrapped the 4x4 with a lift strap, connected the chain hoist to the strap and began to lift.
I will try to attach some pics tomorrow.
ehodg66 is offline   Reply With Quote
Old 09-13-2015, 07:22 AM   #6
Unka Jack's Avatar
Fonthill , Ontario
I just used 2 2x4's screwed together long enough to go from the first to the last rib. Made some short chain loops with shackles around the beam the the fore and aft vents. Then hooked up the chain hoists to the loops and hoisted away. Minor point, I placed the beam just off centre to the door side to counter the weight of that side and it went up nice and level.Click image for larger version
Name:	ImageUploadedByAirstream Forums1442146903.667150.jpg
ID:	247965fClick image for larger version
Name:	ImageUploadedByAirstream Forums1442146941.530221.jpg
Although it seem like I know what I'm doing, I'm just standing on the shoulders of giants who have done this before and kindly posted their journey.
Cheers,
Jack
73's VE3ZPW
Unka Jack is offline   Reply With Quote
Old 09-13-2015, 12:27 PM   #7
1989 34' Excella
minden , Nevada
Thumbs up lifting points
if you have a way to lift it off that's huge. I built a frame inside to not only support the shell sideways and long ways flex a bridge across the celing ribs to support the lift and snatch it through the vents .make some supports across the floor so you can set it down on some dolly's
then screw them to your supports so you can roll it around out of the way.
its all common sence from there. but don't get your self in a position to not to be able to handel the shell .think it through or youll have some major issues and damage Hugh from Sierra Airstream Restorations
775 309 7166
crewman is offline   Reply With Quote
Old 09-13-2015, 12:38 PM   #8
1960 24' Tradewind
Tipp City , Ohio
Hello Silver Bee,
Congrats on starting your restoration. I also am new to AS and a new member of the forums.
I am just starting the restoration of our 1960 Tradewind 24'. I am also planning a frame-off.
Since I learn better by actually seeing things I would like to visit, check out your gantry and offer any help you need during lift-off. I live near i75 &i70, Tipp City, so it is not a long drive. Except for some upcoming fishing trips, I usually have time available.
Let me know if I can help.
Cliff,
Streaming24@gmail.com
streaming24 is offline   Reply With Quote
Old 11-10-2015, 07:02 AM   #9
MACINRIC's Avatar
1977 29' Ambassador
Richmond , Virginia
wow, thanks for posting. I need to get my floors replaced in the near future. Plan to locate someone to do so in the spring. Might try it myself if I can find the courage.
-M
MACINRIC is offline   Reply With Quote
Shell on shell off? Newbie Dustycowgirl Repairing/Replacing Floor &/or Frame 28 03-12-2015 01:12 PM
Shell lift off question sawdawg1 Repairing/Replacing Floor &/or Frame 6 01-29-2012 08:03 PM
Shell on? Shell off? Althea68 Repairing/Replacing Floor &/or Frame 55 04-01-2011 10:35 PM
Shell Off vs Shell On Summary mbatm01 Repairing/Replacing Floor &/or Frame 82 01-09-2006 06:46 PM
Getting ready to get ready to think about an AS pinkflamingoes Our Community 22 10-04-2004 07:36 PM
