Old 07-18-2005, 07:19 PM   #1
Really Cheap
tmcdougald's Avatar
Gap between floor and shell
I got my new floor installed in the rear and I noticed a gap up to a quarter of an inch between the floor an floor channel both sides of the rear. Should I try to jack up the rear frame then attach the shell? I understand the shell holds up the frame and the frame holds up the shell but not this much! What should I do?
Jevons paradox: Increases in efficiency lead to even larger increases in demand.(Basically means that there is no hope for the energy and resource problems on this planet.)
tmcdougald is offline   Reply With Quote
Old 07-18-2005, 07:57 PM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Definitely jack up the frame and make this gap disappear.
Look at the outside perimeter first, make sure the skin is not sitting on top of the floor. The floor should be tucked closely inside the skin.
Uwe
www.area63productions.com
Old 07-18-2005, 08:08 PM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
The last outrigger is under the corner post where the straight side meets the beginning of the curved end. One bolt should tie the outrigger, floor and C-channel together at this point. The frame doesn't support any more of the floor edge until you are at the very back and the two longitudinal beams should have a similar bolt connection through the floor and C-channel. Between these two points there were multiple screws driven through the C-channel to hold up the floor going around the curve. If that's all that needs to be corrected I'm with Uwe -- the ply edge should be just up inside the side skin.
5 meter Langford Nahanni
Old 07-18-2005, 08:26 PM   #4
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
Jackit up!
When I dropped the shell on I ran the tongue jack down and jacked up the bumper to make the floor bow up at the ends. Made my end wall line of rivets and lowered the bumper till the side walls all lined up.
Make sure there is a bolt through each of the outrigger ends through the floor and the C-Channel like Canoe stream pointed out.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 07-19-2005, 05:44 PM   #5
87MH's Avatar
1978 31' Sovereign
Images: 292
Originally Posted by tmcdougald
[font=Verdana][size=3][size=2]....I got my new floor installed in the rear and I noticed a gap up to a quarter of an inch between the floor an floor channel both sides of the rear. Should I try to jack up the rear frame then attach the shell?....
I had about the same gap (a little less) when I replaced the rear section of plywood on the '78 Sovereign. I put a stationary jack under each of the frames at the rear (avoided llifting on the bumber that way) and ran the electric jack "down" - lowering the rear end on the two jacks at the rear under the frame (as 59toaster advised above).
Luck -
Please document and report your success (or lack of) here on the Forum.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
