Old 09-24-2003, 11:49 AM   #99
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
Re: Full Monty
Originally posted by markdoane
Be sure you get the hardened 2117-T4 Brazier head rivets, 5/32. Check this web site: http://www.aspenrivet.com/items.asp?cat=260&subid=41
5/32? I thought the stock rivets were 1/8th and only need 5/32 if you went with the Olympic that needs a larger hole. I'm bucking the exterior rivets.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 09-24-2003, 12:06 PM   #100
Images: 59
Rivets
Then I'd check very carefully. The body rivet holes I removed would pass a 5/32 drill bit, maybe a little tight which I assumed was work hardening. Very loose with a 1/8"
Also, I think "Modified" Brazier heads are the closest in head size to what I took off.
Old 09-24-2003, 01:11 PM   #101
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
Re: Rivets
Hmmm Look at this thread. This is where I got the 1/8 from.
http://www.airforums.com/forum...ght=drill+bits
Now the weird thing is Andy sells a 5/32 drill bit in this thread.
1959 22' Caravanner
Atlanta, GA
Old 09-24-2003, 03:46 PM   #102
Images: 59
Rivets
Again, I'd wait until you get a lot of them drilled out, then check the hole sizes. I was very careful not to wallow out the holes. Many of them I would pop the head off with a #21, then switch to a #30 to drill out the stem. This left a nice clean hole. When I carefuly removed what was left of the stem, the hole was a lot bigger than 1/8. The ones that were slightly smaller than 5/32" I assume are from "shrinking" the aluminum as the rivet head is worked.
When rivets are installed, we assume that the rivet tail expands to fill the open space between the tail and the hole. That's true, but there is also a slight amount of cold flow of skin aluminum toward the rivet shaft. This is my explanation for why some of the holes were a few thou smaller than 5/32.
Anyway, I planned to ream all the holes out to 5/32, rather than have some loose and some tight.
The Mod. Brazier head rivets have the same head size as the rivets I took out.
Let me know. Maybe they ran out of 1/8" rivets the day they built mine, and had to use the next larger size. I know for a fact that the belly and side skins of my tradewind have never been repaired or modified
Old 09-24-2003, 04:08 PM   #103
greg176's Avatar
Gabriola Island , British Columbia
If the 1/8 drill is not a tight fit you should ream holes to 5/32.That would be a MS20470-AD5-6 rivet. The formula for rivet lengh is the thickness of the material riveted plus 1 1/2 times the diameter of the rivet used.That works out to about a 5 1/2.The length is in 16ths.
The tool you bought is used to trim the rivets to the correct length.
greg176 is offline   Reply With Quote
Old 09-24-2003, 05:06 PM   #104
Images: 59
Rivets
Greg: Thanks for the part number. Why did you go with Universal head (MS20470) instead of the modified Brazier (MS20456)? I think the mod. Brazier looks more like the original.
Old 09-24-2003, 05:19 PM   #105
greg176's Avatar
The ms20470 rivets are the ones I can get cheap here.
Old 09-24-2003, 05:43 PM   #106
Images: 59
Rivets
Cheap is good. I like cheap. Keep up the good work. How is your project going, eh?
Old 09-24-2003, 06:07 PM   #107
greg176's Avatar
The frame is a real mess.I will have to wait till I,m on afternoon shift again(two weeks) till I have time to visit local suppliers and figure out what my options are.
The frame main c channel is rotted pretty bad by the front jalousie window (40 years of leaking).I can rebuild it with lots of work for cheap or pay a couple thousand for a new frame.I am keeping trailer on frame right now as I have no place to put it and I will need it for shelter as rain will be starting here soon.It is a bit of a problem as I would like to tow frame around to local trailer repair outfit and maybe to a place where they rent a big sanblaster.
Old 09-24-2003, 07:12 PM   #108
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
Greg:
How far are you from Surrey? I have an internet buddy that was working fabricating trailers in that area. He's the guy I pester when I have welding questions. Any way I am going to send him a link to your other post and find out where exactly the place is he works. I'll get you that info.
I'll let you know something soon.
1959 22' Caravanner
Atlanta, GA
Old 09-25-2003, 06:03 AM   #109
greg176's Avatar
I'm only a few miles from Surrey. Would appreciate any info.
Old 09-25-2003, 06:18 AM   #110
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
Just heard from him. He is not longer doing trailer work, he is now doing tooling. Here is where he recomended in the area.
I don't work at the trailer place anymore. The place I work at now builds aircraft tooling. Right now we're doing a ton of tooling and support platforms for the new Airbus A-380 in Spain.
If I were him I'd go down to a place called LangFab, it's a little ways outside of Vancouver but they don't mind doing small jobs or dealing with the public. I'd get some new cross members formed at the very least, or even look at towing the old frame down there and having them copy it with all new steel.
The guys to talk to are either Joe or Adrian...it's been quite a while since I worked there but they aren't the type of place to rip a guy off. Their main bread and butter is gravel trucks and stuff, but they also build small flat decks and other custom work too. Hell, if I wasn't so darn busy with work and stuff I'd build him a new frame myself.
LangFab :604-530-7227
www.langfab.com
Rene
1959 22' Caravanner
Atlanta, GA
Old 09-25-2003, 07:11 AM   #111
greg176's Avatar
Thanks for info. I wil definitely go by there when I get the frame loose.
Old 09-25-2003, 09:28 AM   #112
Images: 59
Lengthen Hitch
Toaster:
Got a little help from Ultradog diagnosing my frame. He discovered there is another length of tubing INSIDE the front tongue. We don't know where it starts and ends, but you should know about this for designing your new front assembly.
Twin Beds to Full Bed, A success story smily General Interior Topics 17 09-22-2006 08:18 AM
Private Messagebox full Stefrobrts Forum Admin, News and Member Account Info 6 04-09-2004 11:12 AM
Try a full size van Josh Lancaster Tow Vehicles 0 03-20-2004 08:12 PM
photo of the month ALANSD Our Community 4 04-24-2003 04:27 PM
