Old 07-05-2011, 07:24 PM   #1
musicmaster's Avatar
1976 31' Sovereign
Greenwood , South Carolina
Front Tie Down
I'm fastening my new frame and shell back together and came accross a question, it was just sitting there. Ha Ha Anyway, on the front tie down plate, with the two rows of rivets holding it to the body. There is nothing attaching it to the actual frame, I thought maybe it pulled up against the angle iron cross member but the original one did not, it just hung down into the space between the a-frame.
Is this correct?
Thanks, Musicmaster
musicmaster is offline   Reply With Quote
Old 07-05-2011, 08:12 PM   #2
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
No, I'm pretty sure it should be welded to the chassis. If it isn't, you can't call it a hold down plate because it won't be holding anything down.
Mine was attached to the A frame.
This is a pic of the old chassis.
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Old 07-05-2011, 08:30 PM   #3
1976 31' Sovereign
That was what I thought. Where is yours welded ? Mine was just loose.
Of course the body hasn't flown off for 35 years.
Old 07-06-2011, 05:14 AM   #4
DanielB's Avatar
Best I can tell it is welded to the inside and top of the A-frame rails.
- Andrew Carnegie
Old 07-06-2011, 06:20 AM   #5
1976 31' Sovereign
Thanks for the information, you been a great help. I wonder if riveting it to the angle crossmember would work ? I would hate to move the trailer before I finish all of the body attachments. It is sitting leveled on stands, and I don't have a welder at home.
Old 07-06-2011, 08:56 AM   #6
Aluminum Falcon Mechanic
Darkspeed's Avatar
1972 31' Sovereign
Wesley chapel , Florida
There is a steel angle section that goes between the two frame rails, it sits directly under the front shell mount. Mine was welded to that
Darkspeed is offline   Reply With Quote
Old 07-06-2011, 09:00 AM   #7
Darkspeed's Avatar
1972 31' Sovereign
Angle is between the A frame
Front plate/tag holder t7389sg Classic Motorhomes 13 06-15-2011 07:24 PM
Replacement LED fixture under front cap Pat Conway Lights - Interior & Exterior 2 04-12-2011 01:22 PM
Replace missing front window with jalousie? Cruisette Windows & Screens 6 03-31-2011 04:23 PM
Front window leak fix? BarnacleBill Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 7 01-18-2011 05:04 PM
