Old 02-13-2009, 06:35 PM   #1
1969 21' Globetrotter
Cambridge , Massachusetts
Framing with 5" channel - outrigger source
Now that I've exposed the frame of my 1969 Globe Trotter, I see that the rear two cross frames and the main frame rails between are quite rusted out. I propose by cutting off the existing frame about 40 “ back from the bumper and splice on an identical layout but using the lightest 5” channel section and splicing to the forward part of the existing frame. If the calculated weight (which I havn't figured yet) seems excessive, I'll add holes in the webs of the cross members at appropriate locations. Frankly. I don't think the weight will be that much different. Any comments? My real question is this: can anyone direct me to a source of 5” deep outrigger? I think I will need at least one of these. Actually, before committing to the channel, I guess I should ask if the sheet metal sections used on the original frame are available anywhere. They appear to be from 1/16” or 3/32” plate.
JoePfznik is offline   Reply With Quote
Old 02-13-2009, 09:17 PM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
You can get them Here
Airstream Metal : ODMRV , Out-of-Doors Mart
I,m doing alittle work on my GT here
http://www.airforums.com/forums/f381...nte-26902.html
Old 02-13-2009, 11:33 PM   #3
We carry the Airstream outriggers, along with over 3300 different Airstream parts, in stock.
Old 02-14-2009, 03:56 AM   #4
imeynstein's Avatar
Texarkana , Arkansas
Hey Andy!!! How are you doing these days?? Hope all is well with you!!! Have a GREAT DAY!!!!!!!!!!!!
imeynstein
imeynstein is offline   Reply With Quote
u-channel down against the outrigger? cosmos Repairing/Replacing Floor &/or Frame 17 01-15-2008 09:18 PM
On the History Channel, "Back to the Blueprint" harestream Airstream "In the News" 27 07-19-2006 11:33 PM
Curtain "rods" ~ c- channel ??? CaddyGrn Upholstery, Blinds, Walls & Interior Finishes 9 06-26-2006 10:28 PM
"RV Today" on OLN channel BobbyW Our Community 3 09-26-2002 10:55 AM
Source of "Vintage" Dometic refer parts? 74Tradewind Refrigerators 3 08-16-2002 08:42 AM
