Old 04-01-2014, 07:25 AM   #1
Muskie's Avatar
1959 24' Tradewind
collingwood , Ontario
Frame Steel thickness
Hi folks, curious about a couple things;
I am ordering my steel today and getting some pre-cut for my welder for some needed back and front replacement of the frame. Its a 1959 Tradewind. I am away from my trailer and unable to measure its thickness, but I do have the lengths.
1- Curious about the thickness of the steel:
Is the 2x4 tubing and C-channel 1/4 thick or 1/8th thick on 1959 Tradewinds?
and......
2- Is it over-kill to replace the original rotted 2x4 C-channel steel with 2x4 tubing, thus beefing it up?
Cheers, and many thanks for helping.
-Muskie
Those that think they know don't know, those that know they don't know, know.
Muskie is offline   Reply With Quote
Old 04-01-2014, 07:46 AM   #2
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I can't speak for sure about your trailer , but on my 72 it is all 1/8".
Tube is stronger and better IMO, but its use will likely force a few changes, access, blind corners, etc.
(Tube really doesn't flex, this can be good and this can be bad depending on its use and placement)
But if I was starting with a blank slate on a frame, I would be looking really hard at using tube over channel .
Old 04-01-2014, 07:55 AM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
My 66 Trade Wind is 1/8 thick but 5" by 1 1/2 "C" channel, not the 4" older design. I don't know when Airstream changed to 5" frame rails. Some folks box in their "C" channel frame rails in high load areas, like after the axles. The stringers do fit inside the frame rails and are welded top and bottom giving the C channel more strength.
At least you don't have the very old "pipe" frame design!
David
Old 04-01-2014, 09:25 AM   #4
Muskie's Avatar
1959 24' Tradewind
Thanks folks, I will hold off and wait till I measure it then. Would hate to order the wrong stuff!
cheers
Frame Steel Alloy? judflor Repairing/Replacing Floor &/or Frame 9 10-12-2016 08:56 PM
The quest for a new stainless steel frame boatdoc Repairing/Replacing Floor &/or Frame 64 11-28-2015 07:43 PM
Is there corrosion between the steel frame and aluminum floor in Minuets? timzog All Argosy Trailers 10 06-17-2012 02:52 PM
steel or stainles steel screws remcolent Ribs, Skins & Rivets 11 03-30-2004 06:54 AM
Skin thickness Steve St. J Ribs, Skins & Rivets 1 09-23-2003 10:57 AM
