Old 06-03-2007, 02:27 PM   #1
psundstrom
Profile:  1976 31' Sovereign
horse shoe , North Dakota
frame schematic for 1976 sovereign
is there any where online that I can view a frame of the 31 sovereign to get the general measurements spacing. If not how many main members are there; and what is the spacing between them. Thanks.
psundstrom is offline   Reply With Quote
Old 06-03-2007, 02:35 PM   #2
Excella CM
Excella CM's Avatar
Profile:  1978 31' Excella 500
Venice , California
There is a picture of the frame floating around somewhere, I think in one of the popular trailer books. I'll try to find it. It shows the frame and skeleton from the right front. It's a view that doesn't normally exist, since the the trailer isn't built in that sequence. To get spacing for the frame members you can look at the rivet lines inside and outside and the bolt lines on the floor.
"Not all who are lost are wondering" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 06-03-2007, 02:37 PM   #3
JimGolden
JimGolden's Avatar
Profile:  1977 31' Excella 500
I have a '77 Excella that I took the belly pan off and measured where all the cross members and outriggers were. I've got that data somewhere. I could dig it up and send to you if you like. I would imagine they're the same. I was planning to build a new frame for mine and wanted to find out where all the stations were. In general, the outriggers are located on 24" centers. Cross members are generally 48" on center. There are exceptions to both, but that is the general arrangement.
What do you have in mind?
- Jim
JimGolden is offline   Reply With Quote
Old 06-03-2007, 03:47 PM   #4
psundstrom
This is a little unorthox, I bought this sovereign from a fellow who purchased it for salvage. It was in St Pete and one of hurricanes that came through dropped a tree right down the middle of the back. He was parting it out on eBay when I found it. I bought what was left for $700 and I'll have the nose end which has the living room and I'm thinking I can get back to the 16 or 17 ft mark which is where the center bath is. I want to cut it off at that point.
Now the plan: I think that I'll have about 2500 lbs of airstream left. I will also want to drop the belly plan and reduce some weight where possible.
But this Baby is going to be a tree house. It's not going to be delivered for a couple of weeks so I'm trying to spot where I want my telephone poles to get this girl about 10 feet off the ground. I'm also gonna need to locate the front 3 windows, because those were sold off. I really appreciated your fast response.
Old 06-03-2007, 04:10 PM   #5
Lumatic
Lumatic's Avatar
Profile:  1971 25' Tradewind
1962 28' Ambassador
Estancia , New Mexico
Cool. What else goes with the tree house? Tarzan swings, sprial slide, crows nest? Can I come over and play?
To quiet slumbers when the day is o'er
And night above me spreads her spangled tent
Lit by the dying cresset of the moon
Ay, That's it I am homesick for the camp/ Boker
Old 06-03-2007, 04:17 PM   #6
psundstrom
Sure Marshal Your getting the general idea. Let the Imagination run. Polished aluminum and a firemans pole to come down. only access from a cable off the deck of my house 50 ft away. I've got a couple of neon palms for my deck. This tree house is gonnab
Old 06-03-2007, 04:41 PM   #7
Excella CM
Excella CM's Avatar
Venice , California
Here's the frame pic. Looks like an Excella, but should be about the same.
Old 06-03-2007, 06:06 PM   #8
dwightdi
Profile:  1977 31' Sovereign
McHenry , Illinois
This is taking a trailer tree house to another level.
Old 06-03-2007, 06:07 PM   #9
psundstrom
Wow!!!, that is a really useful schematic. Now when I do the surgery: I have been told that a skill saw works better than a sawzall to cut through the skin. I have to separate this at the rib after the midsection bathromm. Any feedback is appreciat4ed
Old 06-03-2007, 06:31 PM   #10
Lumatic
Lumatic's Avatar
1962 28' Ambassador
I think electric shears would get throgh the skin quick and easy
Old 06-03-2007, 06:34 PM   #11
LI Pets
Silver Mist
LI Pets's Avatar
Riverhead , New York
Also a wiz wheel
'77 Sovereign Intl 31' CB
'07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper | Airbags
WBCCI
Time's a-changing Say no to Lawrence Welk attitudes
LI Pets is online now   Reply With Quote
Old 06-03-2007, 06:53 PM   #12
psundstrom
thanks, I was thinking of the electric shears.. Well a wiz wheel means something different to me. I guess that I would ask for it a supply house. Some told me they use a skill saw blad and it got ben up when it hit he wiring harness. To me it seems like the electric sherars could avoid hiting the wire harness. Not sure about a wiz wheel. I think you could control the depth of cut.
Oval Window Frame Replacement MikeMikeMI Windows & Screens 8 12-30-2007 10:49 AM
'78 Sovereign Awning Joan D'Andrea Awnings 6 01-03-2006 07:34 AM
yr frame size reduced yukonsilver Airstream Trailer Forums 1 04-19-2004 12:53 PM
1978 AS Sovereign and doing my own repairs JLD Our Community 2 09-05-2002 11:28 AM
Window Frame Removal 64GT Windows & Screens 4 04-09-2002 12:40 PM
