Old 09-01-2003, 07:06 PM   #1
Send a message via Yahoo to Fun-Lovin
Frame Sag Repairs
Well here we go.
I went to the authorized airstream repair facility in the southeast usa. For you guys that cant find parts this place purchases all obsolete parts from airtsream and they have just about everything. Real nice people as well. They are set up to do major damage repair as well.
Picked up frame kit friday and elevated my a/s on a 6X8 block, also put jack stands under the front and rear to stabilize. Wasn't able to work on it friday night and had to work saturday.
here is where i supported the rear
Name:	rear jacks 4x3.jpg
Greg
1976 Soveriegn 31'
F250 Turbo 7.3L Diesel
WBCCI # 3516
Fun-Lovin is offline   Reply With Quote
Old 09-01-2003, 07:14 PM   #2
I jacked up the front and stabilize with jack stands using an I-beam and the front jacks. I didnt feel the stabilization jacks would have held the weight of the entire trailer so I don't suggest that these are use for anything other than to give the trailer some extra stability.
Name:	front block small.jpg
Greg
1976 Soveriegn 31'
WBCCI # 3516
Old 09-01-2003, 07:15 PM   #3
87MH's Avatar
1978 31' Sovereign
Images: 292
The authorized airstream repair facility in the southeast usa.
Do you have a phone, website, contact, address, etc. for the authorized airstream repair facility in the southeast usa?
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 09-01-2003, 07:25 PM   #4
Ok Took the tires off and entire a/s was supported only by the above jack stands. The floor jack here is not supporting anything just in place as a precaution.
The Authorized repair facility doesn't have a website but They are "Camper Repair Center" (205) 665-2531 south of Birmingham AL.
Name:	tires off small.jpg
Greg
1976 Soveriegn 31'
WBCCI # 3516
Old 09-01-2003, 07:37 PM   #5
Here is the road side frame stiffing plate. These must be used in pairs and are designed expecially to fix frame sag.
Name:	plate small.jpg
Greg
1976 Soveriegn 31'
WBCCI # 3516
Old 09-01-2003, 08:04 PM   #6
Tools required to do this job: atleast what I used.
1/2 inch drill Corded
3/8 inch cordless drill not required but there were placed I couldn't get the 1/2" into
4 6 ton jack stands
Grinder can come in handy
5 ton floor jack
impact wrench
torque wrench
2 alignment bars
wire cutters (brake wires)
2 scissor jacks
1/2" drive ratchet handle
3/8" ratchet handle
1 15/15" socket 1/2"
1 15/16" wrench
1 9/16" socket 1/2"
1 9/16" deepwell socket 3/8"
1 9/16" wrenches
1 3/4" socket 1/2"
1 3/4" wrench
1 lug wrench
extention cord
A few other tools that are not necessary
1 fan
lights
don't think that this is an easy job "ITS NOT"
It can be done by anyone that is compentant using tools, but there is alot of work involved
My first question was "who was the gorrilla that tightened these lug nuts"
Ok here is part of the problem that im having its broke.
Name:	broken small.jpg
Greg
1976 Soveriegn 31'
WBCCI # 3516
Old 09-02-2003, 04:41 PM   #7
Oh Yea, this is a better look at it after the axles have been removed. Yep severe break. I did find out the cause for the sag/breakage on these trailers. During the energy crises years mid 70's until they changed this, look at the frame where there are cutouts evenly spaced. This was done to save weight but in its attempt weakened the frame, then when the waste water tanks aren't emptied expecially in the rear bath models excessive weight and going down the road the bounce would stress the already weakened frames thus the sagging or broken frame.
Name:	broke close small.jpg
Greg
1976 Soveriegn 31'
WBCCI # 3516
Old 09-02-2003, 04:49 PM   #8
Thumbs up Excellent!
This is an excellent class on repairing The Sag!
Thanks for taking the time-John
John is offline   Reply With Quote
Old 09-02-2003, 04:50 PM   #9
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
THat's down right scary to see that crack! Are you going to weld it up before installing the brace? I see welding that as mandatory and possbly a stitched patch on the oposite side as the brace is installed.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 09-02-2003, 05:01 PM   #10
Good question. I was going to weld it with a plate on the back side but there is a cross member right at the break. I decided to not weld it until after I put up the frame stiffener. It will be welded from the back side where i can sew up the frame. I did install extra steel to strenghten the stiffener plate.
Here is where I have added the plate to the curb side and started drilling holes, yes there is alot of holes to drill. Notice the 2 scizzor jacks on the opposite side they are on either side of the break.
Name:	plate started small.jpg
Greg
1976 Soveriegn 31'
WBCCI # 3516
Old 09-02-2003, 05:18 PM   #11
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
Man what a mess. That must have been a pretty common problem for that brace to have been made.
So what axle does it crack over?
What's the thickness of the brace?
DO you think worn axles agrivated the problem by possbly bottoming out?
Out of ballance wheels?
Do you think the heat from the cross member being welded in may have caused a tempering problem?
DO you think the brace is just moving the problem further back given enough time?
It seems to me it doesn't extend far enough and has the potential to possbly crack at the end of the brace. Couse I see where going any further would involve dropping the pan.
Sorry for all the questions. I do a little welding myself and trying to get a clear idea of what could be done to make it a better repair and what other factors may have been involved in the failure.
1959 22' Caravanner
Atlanta, GA
Old 09-02-2003, 05:19 PM   #12
Alright here is the final result.
Frame stiffening kit
1 - can of primer
1 - 3 1/2" flat stock 32" long
64 - bolts and nuts
128 - star washers
4 - 3/8" drill bits
3 wore out 1 broken
one extremly tired body!!
All the work was done in one weekend (2) days.
This is before I painted and put the axles back up.
Name:	broke finished small.jpg
Greg
1976 Soveriegn 31'
WBCCI # 3516
Old 09-02-2003, 05:35 PM   #13
The rear axle.
Approx 1/4" I didn't measure.
Don't think so as there is no sign of bottoming out.
Not sure but possible vibrations are deadly.
Entirely possible as when you heat metal it can become brittle
intresting not the part of the frame that is cut out is backed
by what appears to be 5" channel but it too is thin.
No I have to believe the engineers did their job to correct the
frame sag problem as its bending on a pivot point. (the axles)
I suggest doing this job only if you have the proper tools, time, and experience, the axles were quite easy to replace but now I have created a new problem (replacing the shocks) but I will figure a way around this problem. I will fabricate some new shock mounts.
Name:	finished small.jpg
Greg
1976 Soveriegn 31'
WBCCI # 3516
Old 09-02-2003, 06:11 PM   #14
logicfix's Avatar
Send a message via AIM to logicfix
What years/models are susceptible to rear sag?
logicfix is offline   Reply With Quote
Frame rust Ken J Repairing/Replacing Floor &/or Frame 5 07-13-2003 06:39 AM
Twin Bed Frame pepper48 General Interior Topics 2 01-14-2003 07:27 PM
Distorted door frame Pahaska Doors & Locks 16 12-26-2002 07:52 PM
Window Frame Removal 64GT Windows & Screens 4 04-09-2002 12:40 PM
