Old 01-07-2009, 03:47 PM   #1
Commercial Vendor
Dan4odm's Avatar
Profile:  Currently Looking...
Colfax , North Carolina
Frame Repair Plate
I have been getting a lot of questions about bent frame repair. I thought I would start a thread about the service bulletin concerning units 1982 to ????? Non-widebody.
Dan
PS To all that have asked questions, thanks! It always helps to know what you are needing help on.
Out-of-Doors Mart
In the heart of North Carolina
Dan
Last edited by jcanavera; 04-05-2009 at 04:07 PM. Reason: Link to OP's commercial site
Dan4odm is offline   Reply With Quote
Old 01-07-2009, 06:55 PM   #2
Kevin245's Avatar
Profile:  1976 31' Sovereign
Rock Hill , South Carolina
Good idea Dan...I've read several posts about weak frames. It's nice to actually see the plates and read the SB. Is there a way to make the picture display larger?
Kevin
Experience isn't always the best way to learn...You usually get the lesson first...And the instruction afterwards...
Kevin245 is online now   Reply With Quote
Old 01-09-2009, 10:19 PM   #3
Commercial Vendor
Dan4odm's Avatar
bigger picture
Kevin
I tried to make it bigger but it just gets grainy, and does not show any detail.
Dan
Out-of-Doors Mart
Dan
Old 02-17-2009, 08:20 PM   #4
Distantdrummer's Avatar
Profile:  1975 31' Sovereign
, various
Dan,
The bent frame bulletin you link to in your post #1 goes nowhere. What's up with that?
I also went to your store website and could not find anything about said bulletin.
Could you direct those of us who are interested to that bulletin please?
thanks
__________________________
____ d'drummer ____
...aahh..rumm..pu..tum..tummm...
Distantdrummer is offline   Reply With Quote
Old 02-19-2009, 09:07 PM   #5
Profile:  1974 31' Sovereign
beautiful downtown Aurora , Ontario
Send a message via ICQ to Aage
Originally Posted by Distantdrummer View Post
Dan,
thanks
Works fine for me...
The road to a friend's house is never long. (Old Danish Saying)
Aage is online now   Reply With Quote
Old 02-20-2009, 05:18 AM   #6
Commercial Vendor
Dan4odm's Avatar
working now
It is working for me now, too. I guess the server was down at the time.
I would be happy to send it to anyone who emails me and asks.
Dan@outofdoorsmart.com
Dan
Out-of-Doors Mart
Dan
Old 02-21-2009, 02:32 PM   #7
CrzyCorpsman's Avatar
Biloxi , Mississippi
Was wondering if the reinforcement plate above would work on a '75 31ft Sovereign?? Just found two cracks in my frame today and looking at options.
Brian Schmock
'75 31ft Airstream Sovereign
Come check out my restoration progress:
http://crazycorpsman-silverbullet.blogspot.com/
CrzyCorpsman is offline   Reply With Quote
Old 02-21-2009, 03:43 PM   #8
Commercial Vendor
Profile:  Corona , California
The frame plate, is a beef up kit "only".
It does not fix anything, nor does it stop the frame from cracking rearward of the plates, when proper PM is not performed.
We have repaired many frames, that had the plates, but still got rearend separation and/or more frame cracking.
Adding the plates, as far as we are concerned, doesn't do anything but lighten your pocketbook, and add weight to the trailer.
Your fatigue cracked frame is caused by several things, or a combination of them.
1. Out of round tires.
2. Lack of proper running gear balance.
3. Bad axles.
There is a myth around that the frames are not strong enough.
NOT TRUE.
Check the axles, first.
Andy Rogozinski
Inland RV Center
Corona, CA
Inland RV Center, In is online now   Reply With Quote
Old 02-21-2009, 05:45 PM   #9
Andy,
Thanks for the info. I'm very aware that my axles are bad and is the likely candidate of why my frame got fatigued, which is why I haven't towed the trailer since I bought it. (it makes me sad every time I want to go hit the road).
Here are some pics of the crack:
It seems to me that the PO must have hit a large pot hole or something, as the frame just beneath the crack is also bent.
Any suggestions on the proper way to repair this. I'm not a welder, but I know that I better become friends with one real soon. I'm starting to consider pulling the frame out to fix everything, but don't know if I'm ready to do that yet.
Brian Schmock
Old 02-21-2009, 09:41 PM   #10
Commercial Vendor
Andy,
Clean the cracked areas.
Weld the cracked areas, both sides if possible.
Sand or grind the cracked areas flush.
Plate the cracked areas.
Change out the axles and have the running gear properly balanced.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 03-04-2009, 12:59 PM   #11
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
Andy,
Your picture clearly shows a downward deflection at the point where the frame is cracked. Can you explain how or when that deflection occurred?
Could that deflection be the cause of the crack? I can't see it being the result of the crack. Is the cross member also cracked just inside the frame?
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
HowieE is online now   Reply With Quote
Old 03-05-2009, 08:04 AM   #12
Profile:  2003 22' International
hillsboro , Texas
frame failure
howieE
that crack is very similar to the ones i have had and it is caused by metal fatigue not hitting any bumps. i had a mechanical engineer look at mine and that is what he concluded. this guy took a lot of measurements of my frame and ran a computer model---if you never tow the tr and kept it in an air conditioned building it will last a very long time he said. other than the design problem the protective coating (paint) is poorly applied and not effective. the frame should never rust under normal circumstances. mine is rusting all over and i live in central Texas.
DON GUBRUD is offline   Reply With Quote
Old 02-21-2009, 03:47 PM   #13
HowieE's Avatar
Images: 11
Please clarify. You mention above that the plate is used on 1982 and up Airstreams. The Service Bulletin says they have been used on production models since 1982. Which is correct?
Old 02-22-2009, 05:19 AM   #14
Profile:  1977 31' Sovereign
McHenry , Illinois
The crack shown started at the bottom flange of the frame. The bottom flange of the frame should be in compression, if the crack is rearwards of the mounting point of the axles. As a mechanical engineer, I do not see how this crack could have occurred. I do see some local buckling of the flange which does make sense since, that occurs when there is and excessive compression force generated due to bending. That does not explain the crack. The Airstream designed plate reinforces the frame to resist bending forces caused by excessive tensile loads due to the long overhang on the rear 70 an 80 trailers. It helps resist the tensile deformation of the upper web of the frame and cracks forming originating from the top of the frame. It will do little to repair whatever has caused the tensile fatigue failure that has started from the bottom of your frame. I would suggest you reweld the crack area and then reinforce the bottom flange of the frame by welding on some flat stock to the bottom of the frame. I would suggest that the repair strap should b twice as thick as the existing flange and be at least 12 inches long. I would also look closely at both sides of the frame on the upper flange to see if there are any cracks there. If there are maybe the Airstream provided frame stiffener might help.
dwightdi is online now   Reply With Quote
frame repair plate
shop repair of 1970's rear frame separation (non elephant ears repair) RV shop review simonhanbury Repairing/Replacing Floor &/or Frame 49 06-24-2008 10:16 AM
Small metal plate on end of frame Lothlorian Repairing/Replacing Floor &/or Frame 8 03-30-2008 04:32 PM
Frame Repair or New Frame muddy_hollow Brakes & Brake Controllers 14 09-26-2006 06:55 PM
AS License Plate Frame. Safari Tim Our Community 7 08-19-2004 11:50 AM
Frame Repair greg176 Repairing/Replacing Floor &/or Frame 40 07-29-2004 10:05 PM
