Old 08-06-2009, 11:51 AM   #1
MJMarkhams70's Avatar
Profile:  1970 27' Overlander
Katy , Texas
Frame Repair...
I posted an idea/question in our build thread in the overlander section. I have about 1/2" of frame sag in the rear half of our 27'. My plan of attack is to put jack stands under the front and rear of the frame and load the center of the frame to take the downward curve out. I am considering putting about 1/4" of upward curve to the frame. then I am going to box in the rear half to add strength and rigidity back to the rear. with the slight up curve, when the body and interior are all replaced, it is my hope that it brings everything back down to level and flat. I hope that made sense...
Thoughts/Ideas?
Michael
MJMarkhams70 is offline   Reply With Quote
Old 08-06-2009, 01:53 PM   #2
VIKING's Avatar
Profile:  1964 22' Safari
Boulder Creek , California
It is not necessary to have a flat frame. It only needs to have the rear floor-to-shell connection built-up stronger.
Rich
See my blog: http://1964airstreamsafari.blogspot.com/
VIKING is offline   Reply With Quote
Old 08-06-2009, 03:10 PM   #3
PizzaChop's Avatar
Profile:  1973 31' Sovereign
Danielsville , Georgia
Images: 197
Michael,
To add to Rich's comment, the Airstream is built so that the shell supports holds up the frame and the frame supports the shell. There's a certain degree of flex which is inevitable and planned for.
The rear joint (shell,floor, frame-no separation) must be intact, the axles fresh, and the running gear balanced or you'll end up with the dreaded sag.
What typically happens with these older units is the plywood floor rots at or near the rear joint creates "play" between the shell and the frame. With old, stiff axles and rough ride, the joint gets slapped back and forth and at some point, something gives. (Usually the frame, then the shell.)
Just make sure your rear joint is good and tight. (see pic)
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is offline   Reply With Quote
Old 08-06-2009, 03:25 PM   #4
silverleeper's Avatar
Profile:  1967 22' Safari
1960 18' "Footer"
Edmonds , Washington
I did something similar to what your describing. On my 67 the frame looked slightly flexed just after the axle so to boxed in that area and the next section toward the back. I did jack up the frame a bit when I did the welding. A boxed frame is stronger but you still need the frame to flex.
Both Rich and Ron are correct about the frame. After years of wear and tear each frame seems to have it's own set of different problems. Good luck!
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 08-06-2009, 04:13 PM   #5
VIKING's Avatar
mjmarkhams70, to add to my last post, when you are ready to attach the frame to the shell again you should level the frame by blocking up the back of the frame to eliminate the sag, then set the shell back onto it. If everything is done correctly the holes in the shell should line up with the holes in the C-channel again.
I reinforced my rear end(so to speak) by adding curved metal sections that wrap around the back corners from the frame rails to the last full-length outriggers. I bolted the floor to these and added two bolts through the C-channel into the frame rails, too.
Rich
Old 08-06-2009, 06:03 PM   #6
Katy , Texas
thanks guys for the comments/suggestions. I will do some investigation on securing frame/floor/body together...
MJM
shop repair of 1970's rear frame separation (non elephant ears repair) RV shop review simonhanbury Repairing/Replacing Floor &/or Frame 49 06-24-2008 10:16 AM
What is the best way to repair hole in frame toastie Repairing/Replacing Floor &/or Frame 2 04-08-2008 09:44 PM
Frame Repair Aluminati Belly Pans & Banana Wraps 2 10-12-2007 07:55 AM
Frame Repair or New Frame muddy_hollow Brakes & Brake Controllers 14 09-26-2006 06:55 PM
Frame Repair greg176 Repairing/Replacing Floor &/or Frame 40 07-29-2004 10:05 PM
