Old 01-07-2007, 10:40 AM   #1
geezernbabe's Avatar
1970 31' Sovereign
Rogue River , Oregon
Frame Repair 1970 31'
Boy it was nice to here from all you nice people. We are about half way done on the floor part of the 1970 31'. I am giong to try my hand at putting some pics in here. I had C clannel made to put inside of the frame so I removed the cross members put it in and rewelded everything. We are putting a new grey water tank at the rear axel and a new black in the cell right behind it. We found the electric leveling jacks in the local paper for sell in the box for next to free an boy were we suprised when we looked at the price on the internet. Por 15 is in the UPS truck as I type this so it looks like I will put the rear floor down next week and then take up the front and see what fun it has in store for the next part of the fun. Thanks again for all stuff I have learned here. The floor has a few bad spots but it may stay that way till I fall in a hole.
geezernbabe is offline   Reply With Quote
Old 01-07-2007, 10:44 AM   #2
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Nice work! Keep up the fine job you are doing and one day we'll see you at a rally. How's the floor on the Safari? Hope you don't need to do this twice.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 01-07-2007, 04:28 PM   #3
1970 31' Sovereign
With the help of a new friend, Bob, I hope to get the right pic's on here yet.
ID:	30554   Click image for larger version
ID:	30556   Click image for larger version
ID:	30558   Click image for larger version
ID:	30560   Click image for larger version
Old 01-07-2007, 08:27 PM   #4
PizzaChop's Avatar
1973 31' Sovereign
Danielsville , Georgia
Images: 220
Sweet! Been there, done that...finally starting the coast downhill.
How's the front part of your frame? I had some pretty bad rust and a rotten freshwater tank support (1" plywood) that I had to repair/replace due to ancient plumbing leaks (freeze).
Looks good and at least you'll know what you're riding on.
Hang in there, it's a long road!
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is offline   Reply With Quote
Old 01-07-2007, 08:27 PM   #5
fastrob's Avatar
1976 25' Tradewind
. , Maine to Arizona
Great Project
Thanks for posting the pictures.
Please post problems or difficulties that you solved brilliantly.
There are others in the same boat.
R
fastrob is offline   Reply With Quote
Old 01-08-2007, 07:39 AM   #6
1970 31' Sovereign
The front part of the frame is in pretty god shape. The only part I have not seen is under the water tank. Still working on the pic deal but like all thinks time has a way of making things work out.
Old 01-23-2007, 03:27 PM   #7
1970 31' Sovereign
Well I got the front plywood up and it looks ok with the standard rust from the pink insulation. The one question I have, has anybody had the one piece of angle iron that goes between the fresh water tank on a 1970 31' have a 3/4 hump in the center of the trailer? It looks like the outriggers are all in line and straight. It is almost like the angle is a bit long. The fram rails measure the same distance apart everywhere. Hope I am not the first.
Old 01-23-2007, 04:24 PM   #8
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
I'd be careful with those eletric levelers you're putting on. I don't think the frame can handle being forced to be level. It's pretty flimsy in design.
The trailers are really setup to have stabelizers with just enough pressure to take the bounce out when you walk around inside. But not to try and level the trailer by lifing the frame from the corners.
You level the trailer by using blocks under the wheels on the low side.
You may end up tweaking your frame.
-Tim
theVAP - Airstream Podcast
Old 01-23-2007, 04:44 PM   #9
1970 31' Sovereign
Thanks Tim I got those out of the paper for $80.00 for all 4 so I could not pass up the deal. But I agree with what you are saying about the frame. I will be using them more as stabelizers and not jacks but thanks for the input it all helps. I have the crank downs on my 23'. Just thought it will be fun for price. Dave
Old 01-23-2007, 04:55 PM   #10
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Cool. Glad you had it in mind!
-Tim
Old 01-23-2007, 05:58 PM   #11
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Humping
In my 73 Sovereign I have what you might call a hump in the middle of the floor in the galley area. I think it is in the area of the seam between the plywood sections. Could it be the screws or hardware that holds the plywood to the frame has come loose from 34 years of the frame flexing. I don't know what the best solution is. Screw it down or perhaps there is delamination in the plywood and I could drill some holes and inject some epoxy, or both. I haven't gotten to it yet as it does not seem to be getting progressively worse very quickly and I am working on other stuff. If anyone has any advice I would welcome it.
Old 01-24-2007, 06:29 AM   #12
PizzaChop's Avatar
1973 31' Sovereign
Images: 220
Geezer,
Can you post pic of the hump? I'm intrigued...I had the FW tank out and had clear view of the angle from below and didn't notice any hump.
Ron Kaes
Psalm 112
www.paparonnis.com
Old 01-24-2007, 07:40 AM   #13
Silver Mist
LI Pets's Avatar
Riverhead , New York
Take a belt sander and flaten it out, then a thin layer of 6oz fiberglass cloth with resin.
Old 01-24-2007, 08:41 AM   #14
1970 31' Sovereign
I will post a pic of it later today. It is one of the cross members that is 3/4 low for the plywood joint. If I lay a straight edge over the 3 cross members it hits the angle in the center. got to run and get more parts for the trailer. Time to sandblast.
Old 01-24-2007, 05:17 PM   #15
1970 31' Sovereign
Hi Mr Chop Here are 3 pics if they show up. They seem to on the site,sometimes all I see are little - marks and I have to click them. It might be hard to see from under but is pretty clear from above.
ID:	31259   Click image for larger version
Old 01-24-2007, 05:26 PM   #16
Gold Rivet Member
tgregory13's Avatar
Fuquay , North Carolina
did you possible bow that crossmember when you pulled the floor up?? i bowed a couple of the angle iron supports that run between my crossmembers becouse i didnt see that the had a bolt in them when i was removing my floor... tring to hurry
have a good 1...
Todd
(why do i have to press 1 for english??)
tgregory13 is offline   Reply With Quote
Old 01-24-2007, 06:29 PM   #17
1970 31' Sovereign
Ah it could be I will have to look into that. I can stand on it and it will spring down if I put pressure on it . But my pressure is about 256lb. Thanks
Old 01-29-2007, 08:28 AM   #18
PizzaChop's Avatar
1973 31' Sovereign
Images: 220
Geezer,
I definitely think that's what happened. You need to drop the FW tank and straighten it out. (You probably should drop it anyway because it is likely you'll have a few issues there as well.)
Sliding the 1" plywood out which supports the tank after you remove the front channel (two bolts) is best accomplished with two persons but can be done (as well as reinstalled) with one. If your plywood is rotten, you should replace it.
Make sure all water connections are disconnected before the tank is dropped and tank is emptied (as much as possible, anyway). It will also give you a chance to really clean it out with chlorine bleach (let it sit in the sun for a day or so and it'll look really good).
Ron Kaes
Psalm 112
www.paparonnis.com
Old 01-29-2007, 09:42 AM   #19
1970 31' Sovereign
Pizza,
As I type this the tank is in the sun with bleach. It already looks better. I am going to take out the angle and put in a little stronger piece of channel iron in. Now that I could measure everything it looks like the angle is a bit long from the get go. But on the bright side the 1" plywood looks brand new and so does the 1970 penny that was right in the center under the tank.
Old 01-29-2007, 12:04 PM   #20
PizzaChop's Avatar
1973 31' Sovereign
Images: 220
You lucked out on the plywood!
Ron Kaes
Psalm 112
www.paparonnis.com
Tail sag and separation Dan Phariss Repairing/Replacing Floor &/or Frame 117 01-29-2013 09:45 AM
Oval Window Frame Replacement MikeMikeMI Windows & Screens 8 12-30-2007 10:49 AM
Bed Glide Repair Tamara General Interior Topics 16 08-31-2006 08:28 PM
year frame size reduced yukonsilver Airstream History 1 04-19-2004 12:53 PM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 06:04 PM
