Old 04-18-2014, 09:25 AM   #1
tadpole7
Don Tucker's Avatar
1970 31' Sovereign
Frame Repair
I have a 23' Safari. When I started to install scissor jack I discovered the frame had rusted so bad that I could not install the jacks. How can I repair/replace the entire under frame?
Don Tucker is offline   Reply With Quote
Old 04-18-2014, 09:57 AM   #2
1981 31' Excella II
New Market , Alabama
You really need to remove the bottom skins and see how extensive the damage is. Usually the rear end of these trailers rots off from leaks at the rear of the trailer. Spend some time over at the floor and frame forum here and post some photos once you get things opened up.
Perry
Old 04-18-2014, 11:00 AM   #3
batman's Avatar
1964 22' Safari
modesto , California
Tadpole7
To replace the entire frame, you will need to remove the shell (can of worms, see forum).
If your frame is in that bad of shape you probably have leaks that caused it, since it is enclosed by skins underneath. One bad thing seems to lead to an other, such as axles, sub-floor, plumbing, leak repair, etc, etc. You can rebuild the whole coach before you finish.
Dennis
batman is offline   Reply With Quote
Advice on gaucho/jacknife frame frame & wall remodel chiefbrody General Interior Topics 0 01-30-2013 04:38 AM
Beatrice era frame experts if you please. Odd frame issue Kevin245 Repairing/Replacing Floor &/or Frame 5 08-25-2012 09:55 AM
shop repair of 1970s rear frame separation (non elephant ears repair) RV shop review simonhanbury Repairing/Replacing Floor &/or Frame 49 06-24-2008 09:16 AM
Frame Repair or New Frame muddy_hollow Brakes & Brake Controllers 14 09-26-2006 05:55 PM
Frame Repair greg176 Repairing/Replacing Floor &/or Frame 40 07-29-2004 09:05 PM
