Old 03-15-2012, 04:50 PM   #1
1963 30' Sovereign
Vancouver , British Columbia
Frame Parts for 1963 Sovereign?
We are just about ready to start frame repair on our "project" Airstream - a pretty rough 1963 Sovereign. The central beams seem ok but what I think are called the stringers or "joists" front and rear are very bad and will need replacing. I thought I saw somewhere a supplier for pre-cut steel stringers but can't find it now. Does anyone know where they might be available in bundles for Airstreams?
ID:	153493   Click image for larger version
lunadog is offline   Reply With Quote
Old 03-15-2012, 05:45 PM   #2
x
XXXX , XXXX
Inland RV lists both crossmembers(stringers as you call them) and outriggers for 1969 to 1993 units. I would call them to see if they will work or if they sell ones for your year trailer.
Inland RV Center - The Nations Leading Expert in Airstream Innovations
Inland RV Center Inc.
wasagachris is offline   Reply With Quote
Old 03-15-2012, 06:18 PM   #3
Tool Hoarder
West , California
The crossmembers for the early to mid 60's are a bit different. Greg at Inland told me to use 2 2" steel angle. I actually had some custom bent out of mild steel, piece of cake. Those outriggers look pretty shot. I chopped them off mine and bought em from Inland. Yours might have to be cut down a bit. Nothing an angle grinder cant fix.
marzboy is offline   Reply With Quote
Old 03-18-2012, 12:09 PM   #4
1963 30' Sovereign
Thanks for the info! I am going to start a new thread with more photos and of course more questions. We are using the search feature and learning so much.
Old 03-21-2012, 09:18 PM   #5
Tool Hoarder
West , California
Ask away! I was in the same boat as you a year and a half ago. Your brain is gonna get so big youll need some new hats.
1963, sovereign
Source for old thetford toilet parts? bbqmama Sinks, Showers & Toilets 13 09-18-2015 01:42 AM
Looking for 1967 or 1968 Safari if Anyone Sees One, Thank you! Mary Burris 1966 - 1968 Safari 5 04-27-2012 04:38 PM
Under Consideration: 1970 Sovereign Int'l CarrieSue Trailer Values 19 04-01-2012 10:01 PM
where to find tail lights for '78 esmaytum Lights - Interior & Exterior 2 03-15-2012 01:08 PM
Gaskets for 1970 Sovereign CeloNC Windows & Screens 2 03-15-2012 07:17 AM
