Old 09-05-2010, 02:44 PM   #1
banjobill
wmarsha's Avatar
2000 30' Limited
battle ground, , Washington
frame or electrical forum??
Hey all you guys and gals out there that have done a frame off resto-is the frame tubing intact and hollow all the way? I want to run some wire down the dang thang and before I wrestle a fish tape through to some dead end, I thought I'd ask...anybody have an answer-course the A/S in question is my 95, not one that has been frame off'd (yet).
thanks
bill
wmarsha is offline   Reply With Quote
Old 09-05-2010, 03:00 PM   #2
x
XXXX , XXXX
Hi wmarsha my 73 frame is an open C Channel type frame and only the front few feet is boxed in. Even that section is easily accessable because there are several holes punched in in to reduce weight. The only section that is not open is the front A frame that is in front of the trailer. Thw wiring for the brakes and tongue jack go through there. If you intend to rewire that tie a rope to the old wires before you pull them out and you can use the rope to pull in the new ones.
wasagachris is offline   Reply With Quote
Forum Feedback... What do you think of this forum site? Andy R Our Community 37 04-11-2012 11:29 PM
all new electrical... Help! photocodo Electrical - Systems, Generators, Batteries & Solar 9 09-20-2009 09:27 PM
Frame Repair or New Frame muddy_hollow Brakes & Brake Controllers 14 09-26-2006 05:55 PM
electrical kent osborn 1966 - 1968 Safari 13 05-08-2005 08:09 AM
Airstream Forum Blues-suggestions for forum usage hex Our Community 18 10-20-2002 11:12 AM
