Old 05-27-2016, 12:33 AM   #1
dcole's Avatar
1964 22' Safari
Portland , Oregon
Frame modification to remedy rear leaking
I've seen a lot of talk about different approaches to dealing with water entering the tail end of the trailer around where the bumper box attaches to the shell.
I'm considering notching my frame 1/2 to 3/4" deep at the rear edge of the shell and add some sheet metal to extend the shell down into the notch. Also, modifying the bumper box lid, probably just shorten it and leave a drainage gap so it doesn't touch the shell (adding a piece of angle to attach the bumper box lid to).
Has anyone else tried a similar approach?
Name:	2016-05-26 20.35.20.jpg
dcole is offline   Reply With Quote
Old 05-27-2016, 01:02 AM   #2
dcole's Avatar
1964 22' Safari
Portland , Oregon
Here are more imagesClick image for larger version
Name:	2016-05-22 11.56.30.jpg
Name:	2016-05-26 20.34.14.jpg
Old 05-27-2016, 10:54 AM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
The approach that many of us (including myself) have taken is to leave the frame as it was designed, but then to insert an "L" shaped piece of aluminum along the back edge as sort of a flashing. The idea here is that water will run down the shell, and then instead of hitting the bumper trunk and being directed straight at the edge of the plywood, it will hit the horizonatl part of the "L" and get channeled away from the body of the trailer.
good luck!
Belegedhel is online now   Reply With Quote
Old 05-30-2016, 07:51 AM   #4
blickcd's Avatar
Milford , Ohio
I'd like to see a photo of this fix and get a bit more detailed description. Not sure if the angle "flashing" is inside, outside, or between the two skins.
Christopher
Its a camper, therefore it leaks.
blickcd is offline   Reply With Quote
Old 05-30-2016, 12:05 PM   #5
Belegedhel's Avatar
Houston , Texas
The vertical part of the L shape goes up inside the outer skin.
Old 05-30-2016, 01:02 PM   #6
1973 23' Safari
1970 27' Overlander
Boerne , Texas
dcole - I was thinking of doing the exact same thing. I am thinking that if one wanted to retain the same size bumper box, the frame would have to be extended slightly. Would love to keep updated on this - I many months away from this aspect.
Greg
Greg1410 is offline   Reply With Quote
Old 05-30-2016, 04:01 PM   #7
dcole's Avatar
1964 22' Safari
Portland , Oregon
I'll post photos when I finish my approach. I may not modify the frame rails. I'm most concerned with the flat plate that extends beyond the back of the shell. I plan to use angle iron to fabricate a frame cross support that follows the curve of the shell, and not extending beyond. Too bad I don't have access to a plasma cutter!
BTW, I'm not keeping the original black tank, so I don't have constraints that others may.
Old 05-31-2016, 07:41 PM   #8
1972 27' Overlander
Just make sure to seal it correctly under the flashing to prevent 'wicking'. The flashing won't help that part... but it is a step in the right direction.
I do like the notch idea, if that is sealed correctly it could work.
sir_tob is offline   Reply With Quote
Old 10-07-2016, 10:00 PM   #9
dcole's Avatar
1964 22' Safari
Portland , Oregon
Here are some follow up photos of what I did. I didn't end up notching the frame rails. I did replace my last cross member with one that is curved to match the rear of the shell. The original was pretty rough with rust and over zealous notching. I marked the shell curve on a piece of angle iron and cut it with an angle grinder with cutoff wheel. The first pic shows it tack welded in place and double checking position with the rear trunk cover. Click image for larger version
Name:	ImageUploadedByAirstream Forums1475895531.382488.jpg
ID:	273066Click image for larger version
Name:	ImageUploadedByAirstream Forums1475895586.893323.jpg
ID:	273067Click image for larger version
Name:	ImageUploadedByAirstream Forums1475895614.850144.jpg
What's the remedy for keeping the blinds in their little clips at the bottom? cantdrv55 Upholstery, Blinds, Walls & Interior Finishes 5 12-09-2014 08:26 PM
AC condensation drain leaking inside window frame, running down screen Aggie90 General Repair Forum 0 04-11-2014 08:25 PM
Water heater does not shut off (NEED REMEDY) Ttuck118 Water Heaters, Filters & Pumps 3 07-12-2010 04:38 PM
Tarp/faux leather Softening Home Remedy Sought Distantdrummer Off Topic Forum 2 08-08-2009 04:15 PM
Rear air bag modification? bencbailey Airstream Motorhome Forums 9 08-06-2005 10:31 AM
