Old 10-24-2010, 06:51 AM   #99
2005 22' International CCD
Woodland Park , Colorado
One Frame Problem Solved..
I am really sorry to hear more and more people reporting frame problems with their 22' Internationals. It's a terrible knot in the gut, thinking the trailer you spent so much money on (and are still paying for) may become lawn furniture long before its time.
My 22' was a later model than most having problems, and a significant contributor to my frame issues were the tow system my Airstream dealer set up for me with too heavy WD bars for my 1 ton truck and wimpy framed trailer. My hope was that, after the frame was repaired, not running any WD bars whatsoever would be gentle enough on my frame that it would hold up. Still, I never knew... Then there was also the fact that, even though my 1 ton truck never even noticed the 5000# trailer attached to it, if I ever had to execute a radical maneuver while towing, the lack of WD bars could allow the trailer to take control of things, resulting in a not so desirable outcome...
My frame issue was resolved on by an act of God, a freak hailstorm in Colorado on 4 July. Golfball size hail can certainly do a number to thin aluminum. While not as bad as the pictures of some of the hail damaged Airstreams on this forum, the damage was enough to total my trailer. When the insurance company asked if I wanted to buy back the trailer on salvage it didn't take much thought for me to answer "No thank you."
I was relieved when they came and towed away the trailer that had certainly brought me enjoyment but with it a lot of worry and disappointment.The timing couldn't have been better as I had been living in the trailer full time until only a month before the hailstorm. Like I said, an act of God..
I still like the look and image of Airstream trailers, though I don't think I will buy another one, certainly not a new or late model. They are just too expensive and, at least in my experience, not built well enough to justify that expense.
Sorry to go off topic; I guess technically this would be considered a highjack. However, I figure since I have previously contributed on this thread with my own "frame failure" issues, it is fair for me to post how my frame issue was resolved.
Again, I am sorry to hear of those with catastrophic frame failures and even more disappointed that Airstream does not appear to be standing behind what certainly seems to be a systemic problem resulting from a poor design. Best to you all and God bless. jk
JK3500 is offline   Reply With Quote
Old 10-24-2010, 08:41 AM   #100
2003 22' International
hillsboro , Texas
Originally Posted by clancy_boy View Post
All true, and add mine to the list of 13 22' CCD's, including the one up there at the same time that I have know of as mine that they said had nothing in common with my damage. That one was only 4 SN's less than mine, probably the same day or couple of days off the line, what could they have changed in that time.
I now do have the frame kit installed - much to their disagreement that it would solve my or anyone elses issues with floor rot and frame warp.
I will quote them "It's all how you maintain your trailer, it's not Airstreams fault!"
Good luck to all of you, Mike
I did not know there are 13 of us suckers. With the degree of damage you have a totally new frame is your best bet. Second option is remove the body and rebuild your frame. Third option is '' hope '' you get in a wreck and the trailer is totaled [and nobody gets hurt] and your insurance will pay off. Right now your insurance will not cover factory defects. Right now your RV is untowable and unuseable. And the factory will not help you, it is out of waranty. Good luck.
DON GUBRUD is offline   Reply With Quote
Old 10-24-2010, 10:01 AM   #101
Airstray's Avatar
2003 22' International CCD
1977 31' Excella 500
1966 26' Overlander
Shelton , Washington
Images: 13
Explanation of Airstray's photos!!! Pic. 1, shows the length of the frame stiffeners. I was sent one for each side. Pic. 2 & 3 are the horizonal cracks in frame under the step. Pic. 4 is 2 & 3 combined. Pic.5, 6 & 7 is the curbside frame just behind the rear axel and yes, the vertical section is distorted enough to drop the rearend approx.2 in. Pic. 8 is the outrigger stiffener. I was sent 8. Pic. 9 is the frame stiffener and the last pic. is the thickness of both frame and outrigger (band aids). I took my AS back to the local RV dealer where it was purchased and they are making the repairs at no cost to me. They have a BBB rating of A+. Go on line and check out AS's rating. Hoping for the best. Thanks for all the support. If we stick togather, we can get help. Airstray P.S. Clancy Boy. Where did you obtain the #13? Add me.
Airstray is offline   Reply With Quote
Old 10-24-2010, 10:13 AM   #102
Airstray's Avatar
1966 26' Overlander
Images: 13
JK, Can you refer a good rainmaker/hailmaker? Maybe I can park under a rotten tree. Joking aside, like you I'm considering another make. Beware!!!! Thor, who makes AS's is buying out numerous RV Company's. Check out, www.thor.com. Airstray
Old 10-24-2010, 10:41 AM   #103
HowieE's Avatar
Princeton , New Jersey
Images: 12
Thanks for the explanation of each photo.
As for the cracks under the stair. There is no way the trailer load or travel would cause those cracks. I am at a loss to explain them.
The replacement of the outriggers will have no effect on the drop of the rear of the trailer. If the outriggers had failed the body would have dropped around the frame rather than the frame bending. The failure was the frame.
If you want to keep the trailer I would find someone that can heat the frame while jacking the rear back into place and insert a box beam into the channel. That beam wants to be at least 2 ft either side of the current bend. Weld into place at each end and at the center, current bent point. There is no need to weld the complete lenght of the box beam as the new beam will be much stronger than the original. I would do both sides, as it is only time before the other side fails also. The new beam wants to be forced up against the top flange of the original frame before welding each vertical edge of the beam to the frame. It will not be possible to weld the top of the beam along the center of it but bolting through it and the original frame should work. I would use at least 3 1/2in. #8 bolts. It may be necessary to pre drill the box beam inset it mark the frame and then drill the holes in the frame starting with a 1/8 bit and working up as that hole will have to be drilled on and angle because of the drill motors size Inserting a beam inside to old 50 and 60 trailers is a common fix for the older 3 in. frames that have just rusted over time.
Inserting a beam in behind the axle flange plates and welding it is going to require cutting an access hole in the plate that is used to mount the axles. That hole should be fish plated over when done. Cutting it out completely is too risky as it is the alignment of the axles.
2004 Excursion 4x4
Old 10-24-2010, 06:08 PM   #104
Airstray's Avatar
1966 26' Overlander
Images: 13
This is the add from Thor Industries website.
Airstream
Airstream is the most thoroughly tested Airstream in trailer history. It is years ahead in engineering . the culmination of over 70 years of experience in trailer making, millions of miles of Caravan travel throughout the world; plus millions of miles more, run up by happy Airstream owners!
Airstray
Old 10-24-2010, 06:27 PM   #105
Airstray's Avatar
1966 26' Overlander
Images: 13
Thanks, HowieE
If you want to keep the trailer I would find someone that can heat the frame while jacking the rear back into place and insert a box beam into the channel. That beam wants to be at least 2 ft either side of the current bend. Weld into place at each end and at the center, current bent point. There is no need to weld the complete length of the box beam as the new beam will be much stronger than the original. I would do both sides, as it is only time before the other side fails also. The new beam wants to be forced up against the top flange of the original frame before welding each vertical edge of the beam to the frame. It will not be possible to weld the top of the beam along the center of it but bolting through it and the original frame should work. I would use at least 3 1/2in. #8 bolts. It may be necessary to pre drill the box beam inset it mark the frame and then drill the holes in the frame starting with a 1/8 bit and working up as that hole will have to be drilled on and angle because of the drill motors size Inserting a beam inside to old 50 and 60 trailers is a common fix for the older 3 in. frames that have just rusted over time.
I'm sure the failure of the rear frame and subsequent drop caused the outriggers to fail also. What I can't comprehend is why the curbside failure......as most of the weight is on the street side, ie. shower, cabinets, stove, fridge, etc. Granted, that isn't much weight but more than the dinette. Anyone have any input on that thought? Airstray
Old 10-24-2010, 06:33 PM   #106
Airstray's Avatar
1966 26' Overlander
Images: 13
Aluminum frame!!!!!
I've read pro's & con's on an aluminum frame, but numerous manufacturers are using them and under much longer rigs with only 2 axles. Check out the "Vinstream" website. Airstray
Old 10-24-2010, 06:43 PM   #107
Airstray's Avatar
1966 26' Overlander
Images: 13
Thor Industries
I just read Thor Ind. also builds buses and ambulances. Duh!!!!!
Old 10-25-2010, 05:25 PM   #108
steel/aluminum fabricator
2004 22' International CCD
Penticton , British Columbia
I would say the streetside is reinforcing the frame with all the cabinets,bath etc. The curbside on the other hand is flapping in the breeze. Add weight from the grey/black tanks being full? Its a head scratcher.
zedex is offline   Reply With Quote
Old 10-25-2010, 06:36 PM   #109
Tulsa , Oklahoma
Send a message via AIM to jimelmoreiii
zedex, have you had troubles with your 2004? Seems most of the frame problems are 2002 and 2003.
jimelmoreiii is offline   Reply With Quote
Old 10-25-2010, 08:19 PM   #110
No. I see no problems with my unit.
Old 10-26-2010, 12:09 AM   #111
I read this thead with interest, and sadness.
My suggestion... all of you with these problems get together, find a good Attorney that has experience in these matters and wave the big stick at them!
They have already admitted that the frame is not up to the job by providing a "reinforcement kit".
Airstream, as a company should be ashamed of themselves for not just pulling these units in and replacing the frames with something that is "right".
No mess, no fuss, just stand behind your product and show the world you do.
Old 10-26-2010, 09:23 AM   #112
TankerIP's Avatar
2002 22' International
Question Stiffener?
I have always been a bit confused about the recall #131. http://www.airforums.com/forums/f212...ing-40193.html Reading around, it seems something happened back then but how effective it was, I don't know. There is a rectangular piece welded on the side of the frame aft of my wheels. I made one phone call inquiry to JC a long while back and was told that the recall didn't apply to my model because the "fix" was applied on the production line.
Does everyone with this model have this piece of metal welded on the frame? For that matter, is this "patch" that I look at even the "stiffener" fix that I hear others talk about?
TankerIP is offline   Reply With Quote
1984 Airstream International 34 foot, 3 axle Travel Trailer eBay Watch Airstreams on eBay 0 02-13-2012 11:50 AM
1973 31 foot airstream sovereign international eBay Watch Airstreams on eBay 0 02-06-2012 11:10 AM
1984 Airstream International 34 foot, 3 axle Travel Trailer eBay Watch Airstreams on eBay 0 12-08-2011 08:10 PM
1984 Airstream International 34 foot, 3 axle Travel Trailer eBay Watch Airstreams on eBay 0 09-26-2011 07:20 PM
Frame Failure dmm9623 Repairing/Replacing Floor &/or Frame 9 08-12-2011 10:03 AM
