Old 01-20-2013, 02:01 PM   #337
pullswitha40's Avatar
ogden , Utah
Originally Posted by DON GUBRUD View Post
I live at the North Texas Airstream Community. It is an all AS community and you must own an AS to live here.
So discrimination is polity correct still in Texas
pullswitha40 is offline   Reply With Quote
Old 03-30-2013, 12:29 PM   #338
1966 24' Tradewind
2005 22' Safari
Bastrop , Texas
it works
Originally Posted by dannydimitt View Post
This one shows the R Front axle mount --truss attachment area where the
4x4 3/16 square tube with the 2x2 1/4 inch tubing running through it is suspended below the axles with a u-bolt on the outside .
The axles act as very nice cross members for the truss and with part of the
weight of the trailer being applied to the axle tubing further out from the main frame the axles themselves will have gained strength from having less leverage at the fulcrum point.
after a trip out to fort Davis and Big Bend with the little fellow rolling on
P 235/75R15 cooper tires from Discount and with no load equalizer hitch , only the sway bar , the report is in and it has passed with flying colors !
No sag , No sway , pulled perfectly despite a crosswind from the depths of Hell ! ---- Full fresh water tank and all our STUFF loaded, two spare tires for the Dodge, Airstream and little one wheel generator trailer, and full load of diesel. "over 1500 mile round trip with zero fuel stops"
Next trial run is up through Alberta, British Columbia , The Klondike gold fields of the Yukon, then up through Alaska. and back.
dannydimitt is offline   Reply With Quote
Old 04-02-2013, 05:50 AM   #339
2003 22' International
hillsboro , Texas
Good report Danny. Looks like you found one way to solve the problem. I wish the AS factory had your skills. For what it is worth I think you should use the load equalizers however.
DON GUBRUD is offline   Reply With Quote
Old 04-05-2013, 06:47 PM   #340
1966 24' Tradewind
2005 22' Safari
Bastrop , Texas
Rivet Thanks Don !
Howdy Don,
have ya got that bumper on yet ? Have given much thought about the equalizer hitch and having pulled the bigger 66 AS with and without with much lighter vehicles "the 71 International travelall HAD to use one at all times. While my old 64 F-100 with load range E tires handled it flawlessly without." Pulling the AS back home from Wisconsin with the equalizer hitch without the bars in place with the Dodge Cummins it towed perfectly even with the Ball being farther from the rear axle than it is now with a normal hitch stabbed in the receiver .
The trailer weighed 4000 lbs on the axles before I beefed up the frame and axles . I added about 400 lbs of steel to the equation 90 % added to the trailer axles. The truck weighs 6100 pounds with most of that weight on the steering axle due to the heavy Cummins Diesel engine and cast iron 5 spd transmission . I added a 12000 pound capacity winch and mounting frame forward of the front bumper which added even more weight to the steering axle.
The distance from the trailer ball to the center of the rear axle is 51.5 inches . the distance between the rear and front axles center line is 141 inches . There are 52 inches from the center of the front axle to the front of the winch and mounting plate and frame.
Add the 6 to 7 hundred pound hitch weight to the rear of the Dodge and with the fulcrum at 51.5 inches with 141 inches to the front axle my feeble mind kinda figures that is putting all of the 6-7 hundred pounds on the drive axle plus taking roughly another 6-7 hundred pounds of weight off the steering axle and putting that weight onto the drive axle. 1400 pounds on the drive axle extra with the trailer hooked up .
The drive axle is rated 6000 pounds and the steering axle is rated 4630.
The little 22 foot Safari tows beautifully behind the Dodge at highway speeds without the weight distributing hitch using the sway bar. With no chance of overloading the trailer tongue or axles with the load equalizer hitch . If I were trying to pull the trailer with an suv or half ton pickup with P rated tires then that would be another story. the Dodge would pull a much bigger trailer with ease , but I like the little trailer back there, and feel safer than safe with it trailing behind us.
REGARDS !
Danny , Rachael and Fred
Old 07-03-2013, 06:54 PM   #341
1966 24' Tradewind
2005 22' Safari
Bastrop , Texas
OK , we are now in Alaska , having put another 5000 miles on the trailer over
some very rough frost heaved , and gravel and dirt roads through Brirish Columbia and the Yukon , can report the frame has performed flawlessly and the 60 dollar each P 235/75R15 Cooper tires from Discount still look brand new and no flats at all !!!!
Old 07-04-2013, 01:09 PM   #342
2003 22' International CCD
Hillsboro , Texas
GOOD SHOW!! Enjoy yourself and have a trouble free trip.
Don
dongubrud is offline   Reply With Quote
Old 08-23-2013, 06:30 PM   #343
flyrc's Avatar
1962 22' Flying Cloud
Yakima , Washington
62 Flying Cloud frame sag
Originally Posted by Inland RV Center, In View Post
Early frame failures are usually due to grossly out of balance running gear, or, towing with a super heavy duty tow vehicle and an excessively rated hitch bars, or a combination of those.
Hi Andy. I know you keep track of things here on the forum so I hope you see this post. I have a 62 FC that went around the world with the 63/64 caravan. The trailer carried a bumper mounted spare and I believe that the extra weight has caused the frame to sag.
My thoughts for fixing the problem is to box the frame. Is this a good idea and will it work?
Thanks for your help, Wally H.
Wally H.
Parts needed
1962 Street side corner tub
range or parts
Dometic 50 or parts
flyrc is offline   Reply With Quote
Old 03-29-2015, 11:13 AM   #344
2005 22' Safari
Palmer Lake , Colorado
OK, so just to clarify, I've looked through this whole thread and it appears I might be ok with my 2005 Safari 22'?
joelisac is offline   Reply With Quote
Old 03-29-2015, 07:34 PM   #345
RichardT's Avatar
This is a lot to read does it apply to all 22' 2002
Internationals or just CCD model the trailer I am curious about is a rear kitchen model.
RichardT is offline   Reply With Quote
Old 03-30-2015, 07:53 AM   #346
Hillsboro , Texas
The frame problem is a design problem and applies to all 22' Int made in that year. The frame has since been beefed up. A failure will depend on how many miles you put on it and driving conditions.
Old 03-30-2015, 07:55 AM   #347
Hillsboro , Texas
Yes, you should be ok.... you lucky duck.
Old 03-30-2015, 06:56 PM   #348
1966 24' Tradewind
2005 22' Safari
Bastrop , Texas
Sorry to be the one to be the bearer of bad news, my 2005 22 ft Safari double axle was about to loose the entire wet noodle frame before I caught it and spent countless days beefing it up with about 500 pounds of good steel. Don G has seen it and you can read my posts and pics on this thread for details
Old 04-09-2015, 04:27 PM   #349
RichardT's Avatar
can someone provide the part number or service bulletin for the upgraded outrigger?
Old 04-09-2015, 06:50 PM   #350
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
It seems to be pretty much all 22' models of the '02-'06 era.
Currently Active Users Viewing This Thread: 9 (1 members and 8 guests)
steinVT
1984 Airstream International 34 foot, 3 axle Travel Trailer eBay Watch Airstreams on eBay 0 02-13-2012 11:50 AM
1973 31 foot airstream sovereign international eBay Watch Airstreams on eBay 0 02-06-2012 11:10 AM
1984 Airstream International 34 foot, 3 axle Travel Trailer eBay Watch Airstreams on eBay 0 12-08-2011 08:10 PM
1984 Airstream International 34 foot, 3 axle Travel Trailer eBay Watch Airstreams on eBay 0 09-26-2011 07:20 PM
Frame Failure dmm9623 Repairing/Replacing Floor &/or Frame 9 08-12-2011 10:03 AM
