Old 01-05-2013, 05:47 PM   #295
pullswitha40's Avatar
ogden , Utah
Originally Posted by Inland RV Center, In View Post
Seems to, is an opinion, that has nothing to do with safety.
Your truck, is not a means of "magic".
To tow that trailer without a load equalizing hitch, is jeopardizing the safety of your passengers and the other people on the roads.
Should you lose, for any reason, control of your rig, and damage property or hurt someone, in plain language, "YOUR DEAD MEAT" to any attorney that decides to sue you, as you would have "ZERO" defense.
Your towing that rig is really in violation of safe towing standards.
Then adding air bags, is a waste of money, and will "NOT" in any way increase safety.
Get a small rating load equalizing hitch, with sway control, like 600 pounds.
Your uninformed passengers and the public, will look up to you for doing so.
If your truck needs air bags for another use, that's fine.
"BUT" when you hook the trailer up to the truck, reduce the air pressure to absolute minimum. In that way, the air bags will not interefer with the load equalizing hitch.
Andy, first I hear a big truck with a equalizer hitch will tear up a trailer frame, then I hear I'd be a hazard to my passengers without it.....do I need to leave the trailer in the driveway or what???
pullswitha40 is offline   Reply With Quote
Old 01-05-2013, 06:14 PM   #296
1966 24' Tradewind
2005 22' Safari
Bastrop , Texas
Rivet
Originally Posted by pullswitha40 View Post
Well I guess I'll be good with the 3/4 Dodge crew cab 4x4 Hemi.....
The hitch on the 46 Spartan looks pretty standard, but ho equalizers.
Do have me thinking some about the 40 Ford.....it's got independent suspension, disc brakes and a 9 inch rearend, but it is very light in the rear.
I don't know how much I intend to use the 40 due to it is also rather narrow and the mirrors do not stick out far enough to get a good look behind my other trailers.
It does have a 400 small block chevy and auto trans with good trans cooler so pulling is a lot easier than a flat head ford.
Nice looking old truck ! Damn near bought a 40 pickup , but that was back in 1970, the guy wanted 350 bucks for it and I figured that was a bit steep . I have a 64 F-100 4x4 , used it to pull the 66 24 ft Land Yacht. Handled it just fine with just the ball and a sway bar. Had 10 ply tires on the truck.
4.11 gears and a granny 4 spd.
dannydimitt is offline   Reply With Quote
Old 01-05-2013, 07:49 PM   #297
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Maybe some people need to realize there are not very many 1973 Chrysler station wagons available any more for towing our 2013 Airstreams, and make recommendations based on what is currently available as far as tow vehicles go.
My new 3/4 ton truck rides much more smoothly, and is a lot more refined, than almost any 1/2 ton pickup, or even most SUVs of 10 years ago. In fact, it tows our Sovereign much more smoothly, with less jarring and bouncing, than the 1/2 ton Dodge I traded in on it. If you want to consider ride, the new truck rides more smoothly than my wife's nearly new Focus.
Old 01-05-2013, 08:18 PM   #298
ogden , Utah
dannydimitt, feel like I have hi-jacked this thread....lol....thanks for the complement on the 40......it's a 20 footer, but drives like a dream.....I bought it with the help of a friend and got it cheap.
I'll start a thread of my own soon and tell more.
I had a 65 3/4 4x4 390 4 speed forget the gears, but it was a workhorse and rode like a tank
Old 01-06-2013, 05:21 AM   #299
2003 22' International
hillsboro , Texas
Originally Posted by overlander63 View Post
NTAC= North Texas Airstream Community.
I do get down your way occasionally. How do I find you?
Check out NTAC'S web site at: www.ntaci.org
DON GUBRUD is offline   Reply With Quote
Old 01-06-2013, 05:34 AM   #300
Well Preserved
1993 21' Sovereign
Take I40 East to exit 208, turn right, then right. Drive .4 mile then turn right again into the driveway. I can be almost anywhere on the property.
BTW, yours would not be the first 22 I have referred to the factory for frame repairs.
Old 01-06-2013, 10:37 AM   #301
No, I think you did not read all of the post.
A larger than necessary truck, is absolute "overkill".
A stiff suspension tow vehicle, is what should be avoided.
With regard to hitch ratings,an excessive rated set of hitch bars, also transfers more road shock.
The heavier the tow vehicle suspension and/o the heavier than necessay hitch bars, is the cause of the damages.
As an example from the older days, a 700 to 900 pound tongue weight towed with a large car, should use a 1000 set of bars.
The same tongue weight towed with a 1/2 ton truck, should use 750 pound bars.
The same tongue weight towed with a 3/4 ton truck, or more, should use a 550 to 600 rated set of bars.
The theory is that the heavier tow vehicles can stand some bumper weight.
Therefore less tongue weight needs to be transfered to the front axle.
Keep in mind that an Airstream "MUST" have a soft ride.
Using a 1200 pound to 1400 pound hitch bars on a 3/4 ton or 4 X 4, will send most all of the road shock to the trailer. Therein lies the problem.
More hitch than needed, is going the wrong direction.
Why do many dealers outfit someone like that?
Easiest answer of all.
More profit and less liability.
Do they have the customers investment in mind?
Heck yes, only so they can dig deeper into ones pocket.
Ask those that have down sized the hitch bar ratings.
Not a single one of them, yet, has a negative answer.
Another way to put it, s be very easy on the trailer, with road shock.
The easier, the better. The worse, then be prepared to pay for many types of repairs.
Old 01-06-2013, 11:05 AM   #302
2005 22' International CCD
Aliso Viejo , California
I agree, I downsized my hitchbars from 1000lbs to 750 and the ride is noticeably softer with less stiff thrown around the trailer.
Davern1 is offline   Reply With Quote
Old 01-06-2013, 12:36 PM   #303
ogden , Utah
Thanks Andy
Now I'm learning.
Does anyone know if the single axle Spartans are a delicate as the Airstreams?
I have started a thread as promised for my Spartan
http://www.airforums.com/forums/f417...ah-100060.html
Old 01-06-2013, 02:34 PM   #304
1966 24' Tradewind
2005 22' Safari
Bastrop , Texas
Thanks Andy
Now I'm learning.
Forgive my ignorance,were all the old Spartan trailers built as live in full time trailers, and never built one for camping ?
They were built hell for stout and I'd bet your 20 footer is built FAR better than anything Airstream has built in the last 30 years.
Old 01-06-2013, 04:18 PM   #305
Phoenix , Arizona
It would be interesting to see pictures of the stripped down frames for an Airstream, an Avion and a Silver Streak. I'm curious to see the differences, side by side. Does anyone have pictures of these?
M2HB is offline   Reply With Quote
Old 01-07-2013, 09:42 AM   #306
ogden , Utah
Did I say 20'....ment to say 25'
As for travel trailer vs. park models I'm not sure.....when I get it torn down some I'll try to figure out if it had a holding tank or not.....
The longer models did come later and Spartan did get real serious with park models as time went on....even saw an add for a two story.
Old 01-07-2013, 10:15 AM   #307
r carl's Avatar
Lin , Ne
On page 9 you can see a pic of a 25' frame. Its made of boxed steel not C channel.
http://my.execpc.com/~drg/1972_Avion_Brochure.pdf
r carl is online now   Reply With Quote
Old 01-07-2013, 03:33 PM   #308
Phoenix , Arizona
Thanks for the link to the 1972 Avion catalog. That frame looks similar to what I can see on my 1988 Avion triple axle, 34' trailer. I don't know what kind of rubber suspension that the "Mor/Ryde" suspension was, but my 1988 trailer has an independant leaf spring assembly.
Does anyone have pictures of the Silver Streak frame.
Also, how did Avion attach their body to the strong frame without tearing it apart? It seems that everytime I bring up putting a stronger frame under an Airstream, the issue brought up by experts is that the shell will be destroyed. How did Avion do it? The shell seems to be very similar.
Currently Active Users Viewing This Thread: 8 (1 members and 7 guests)
steinVT
1984 Airstream International 34 foot, 3 axle Travel Trailer eBay Watch Airstreams on eBay 0 02-13-2012 11:50 AM
1973 31 foot airstream sovereign international eBay Watch Airstreams on eBay 0 02-06-2012 11:10 AM
1984 Airstream International 34 foot, 3 axle Travel Trailer eBay Watch Airstreams on eBay 0 12-08-2011 08:10 PM
1984 Airstream International 34 foot, 3 axle Travel Trailer eBay Watch Airstreams on eBay 0 09-26-2011 07:20 PM
Frame Failure dmm9623 Repairing/Replacing Floor &/or Frame 9 08-12-2011 10:03 AM
