Old 09-26-2006, 05:05 AM   #1
boatdoc's Avatar
1973 Argosy 26
Norristown , Pennsylvania
Frame dillema.
Hi Folks; After bringing home new to us 1973 26' Argy on the 15th of September from Ohio, it was stripped and shell was removed for total restoration. One thing that have noticed that the frame is 5" and not 4" as I have read in one of the threads. Although the frame is repairable we have chosen to build a new one from 0.090" wall Stainless Steel box tubing. The shape will provide greater stability comparing to 0.125" formed "C" channel. Since I own a fabricating facility it is more cost effective for me to build new rather than sandblast repair and paint the old one. However, I have jumped the gun and never checked the tongue weight prior to dismentling the unit. Unless someone helps me with average tongue weight I will have to guess, or do a lot of componnent weighing in order to come up with proper tongue weight. My Argy did not have a grey water tank so placement of the new one within the frame can help with the balance. The old frame without axles will be available for adoption if someone needs one, after the new one is compleeted. Thank you "boatdoc".
boatdoc is offline   Reply With Quote
Old 09-26-2006, 06:04 AM   #2
fastrob's Avatar
1976 25' Tradewind
. , Maine to Arizona
It took a while in Search
I found the link you are looking for. It has the gross and tongue weights of the trailers.
http://www.airstream.com/airstream/p.../weights-1.pdf
R
fastrob is offline   Reply With Quote
Oval Window Frame Replacement MikeMikeMI Windows & Screens 8 12-30-2007 10:49 AM
year frame size reduced yukonsilver Airstream History 1 04-19-2004 12:53 PM
Cracked door frame 77caravaner Doors & Locks 5 10-11-2002 06:43 AM
Window Frame Replacement Charles D. Bennett Windows & Screens 20 08-16-2002 06:03 PM
Window Frame Removal 64GT Windows & Screens 4 04-09-2002 12:40 PM
