Old 05-14-2007, 12:20 PM   #1
Cos
1973 21' Globetrotter
Middletown , Rhode Island
Frame dent - repair needed?
This is a 73 GT with the normal rear end floor rot/dis-similar metal skin corrosion issues. This dent is aft of rear axle where the added frame rails end. Other than the dent (and some cross member corrosion which I need to address) the frame seems solid with no detectable sag or mis-alignment. Can I just live with this dent?
ID:	37326   Click image for larger version
Cos is offline   Reply With Quote
Old 05-14-2007, 01:24 PM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Hi Cos -- That dent looks like it came from some road or parking hazard? (aka rock) It looks small potatoes compared to most frame issues. Your beam stiffness comes from the good integrity of the vertical part of the C-channel and the dent seems like a minor thing. I would live with it. I don't think banging it out would make it stronger.
5 meter Langford Nahanni
Old 05-14-2007, 01:26 PM   #3
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I'd have to agree with Bob, doesn't look all that bad. You notice anything knocked out of form, like the door or windows that don't close nicely? If not, I'd be inclinde to try a good wrench or some sort and see if I could put a good deal of weight on it to bend it back, or leave it be since you might just make it worse?!
Old 05-14-2007, 01:48 PM   #4
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
That looks like it is Joe Somewhen jacking trailer up from frame rail, not axle plate. Note even exhuberant lifting from stock aluminum worm-screw stabilizing jacks will dimple the channel if someone puts a helper on the lever and tries to compensate for seriously uneven ground - mine has a couple of them too; just too easy to throw jack under there and bend iron. I painted them over and will forget all about them soon.
Old 05-14-2007, 02:02 PM   #5
Excella CM's Avatar
1978 31' Excella 500
Venice , California
The damage is cosmetic, but if it offends you , take a large adjustable wrench and slip it over the lower edge and pull it back down.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Dash Repair Questions JW84345 Airstream Motorhome Forums 15 07-15-2012 08:59 PM
Oval Window Frame Replacement MikeMikeMI Windows & Screens 8 12-30-2007 10:49 AM
Bent Door Repair Road Ruler Doors & Locks 6 09-02-2002 07:27 PM
Window Frame Replacement Charles D. Bennett Windows & Screens 20 08-16-2002 06:03 PM
Window Frame Removal 64GT Windows & Screens 4 04-09-2002 12:40 PM
